Metal chatter noise from under truck
Discussion in '2nd Gen. Tacomas (2005-2015)' started by surfrat, May 13, 2013.
  1. May 13, 2013 at 3:44 PM
    surfrat
    surfrat [OP] Well-Known Member
    LI, NY
    icon coilover, total chaos UCA, allpr expo, icon 2.0 rear,wet okole
    Been having an issue with a metal chattering( chain like metal tick noise) is the best way to describe it.. The issue only happens at low rpms under a load ,or uphill. If the transmission downshifts the noise goes away. I notice the noise during 12-1600 rpms up a slight hill, until the transmission downshifts to 2k rpms.. The problem seemed to start since i dropped my carrier bearing 3/4". Anyone else have any issues like this? truck is a 2010 DCLB auto
  2. May 13, 2013 at 3:57 PM
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    2009 Prerunner TRD AccessCab
    New Navigation DVD/CD/TV/AV/Bluetooth Stereo and seat mod spacers, 1" hubcentric spacers, seat heaters....
    3/4" drop?
    Is your truck lifted?
    If not, then I think you got some angles in conflict, 3/4" is a lot...
  3. May 13, 2013 at 5:08 PM
    surfrat
    LI, NY
    Yes truck is lifted.. I have all pro expos leafs
  4. May 13, 2013 at 6:03 PM
    anotherreject
    anotherreject Well-Known Member
    Mine does a similar nose in low rpms, its a heat shield rattling, goes away as i speed up too.
  5. May 13, 2013 at 6:39 PM
    lj973gm
    lj973gm Sold it, dont miss it yet.
    Ohio
    06 DCSB 4wd
    As stated likely a heat shield on the exhaust or underside of truck.
    Mine corroded away on the underside of the truck so the bolt head pulled through the heat shield. Added a washer and solved the problem.
    Bang on your exhaust pretty hard with a rubber mallet or shake it good to check for rattles. If nothing start to inspect heat shields for movement.
  6. May 14, 2013 at 11:48 AM
    surfrat
    LI, NY
    Thanks guys ill take a look
  7. Jul 30, 2013 at 7:28 PM
    surfrat
    LI, NY
    exhaust and heat sheilds are nice and tight. If i accelerate slowly right about 1800 rpms i get the knocking noise. once the rpms increase or the tranny shifts gear the noise is gone.. i also removed my CB drop and it made no difference..driving me nuts!
  8. Jul 31, 2013 at 4:49 PM
    surfrat
    LI, NY
    the crossmember seems good.. took a few hits around the exhaust with a rubber mallet.. everything was good.
  9. Jul 31, 2013 at 4:55 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Does it sound like a chain running over a sprocket ?
  10. Jul 31, 2013 at 5:18 PM
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2021 TRD OFFROAD 4x4
    Have you checked the u-joints for wear and grease?
  11. Aug 1, 2013 at 1:26 PM
    surfrat
    LI, NY
    yup basically...
  12. Aug 1, 2013 at 1:27 PM
    surfrat
    LI, NY
    they are nice a tight and lubed...
  13. Aug 1, 2013 at 1:28 PM
    Tylerm5000
    Tylerm5000 Well-Known Member
    Tyler
    Oregon
    1995.5 2.7l reg cab 4x4 5-speed red pearl
    Alcan stock height 4-leaf springs, greaseable main eye bolts, OME greaseable shackles, all energy suspension bushings, 2-row extra deep radiator, KYB gas-a-just shocks. ALL LED exterior and interior lighting including custom tail lights and blinkers.
    Catalytic converters make noise under load and going up hills.
  14. Aug 1, 2013 at 2:03 PM
    OZ-T
    Peter North
    British Columbia
    I hear the exact same noise
  15. Aug 1, 2013 at 2:12 PM
    surfrat
    LI, NY
    i agree with you. except the issue is now happening on flat terrain with little to no load. its is intermittent and only happens withing 1500-1800rpms
  16. Aug 21, 2013 at 1:29 PM
    surfrat
    LI, NY
    I am starting to lean towards a center bearing on the drive shaft. Im going to try to borrow my buddies go pro.
  17. Aug 22, 2013 at 2:54 PM
    surfrat
    LI, NY
    This afternoon i took the rear drive shaft out and drove around.. the noise still occured.. this rules out the rear drive shaft/ carrier bearing. I just took a crappy video but you can hear the noise. once i upload it i will post.. this is driving me nuts!
    It its starting to occur more frequently now. I noticed i cant really hear it unless my windows are up. There are moments when it gets extremely load and feels like something is going to grenade. If i give it quick gas i can replicate the noise anytime.
  18. Aug 22, 2013 at 3:13 PM
    surfrat
    LI, NY
  19. Aug 22, 2013 at 6:49 PM
    Skunkman
    Skunkman Well-Known Member
    Syracuse - Tug Hill
    2007 Tacoma Access Cab ,
    I'm no mechanic, but that sounds like the engine knocking under a load, due to crappy gas maybe? It sure don't sound good.
  20. Aug 23, 2013 at 12:56 PM
    surfrat
    LI, NY
    I thought about that as well. I doubt its the motor though. I did a simple foot on brake in drive test. no noise.. the truck has to be moving. I am almost convinced its something with the torque converter or transfer case.. My next step maybe getting a tranny flush.. Im at 80k so it wouldnt be a bad idea anyway. I will try some 93 octane next tank to see if its detonation related also. From what i read it could very well be spark knock. Plugs got 15k on them.. maybe ill change them again and try cleaning the MAF
