Metal 'Flapper' Valve on Fuel Filler Inlet Missing?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by pgtr, Aug 10, 2014.
  1. Aug 10, 2014 at 1:17 PM
    pgtr
    pgtr [OP] Well-Known Member
    2014 DCSB SR5 PreRunner
    I noticed almost since I got the truck that there was no metal 'flapper' valve on the fuel inlet like on most cars. When you remove the fuel cap - there is basically a 'hole' straight down into the tank. On most cars there is a small metal sprung 'flapper' valve. I would guess it is to help keep small objects from accidentally falling in.
    Am I missing mine? Or does Toyota not install those for some reason?
    thanks
  2. Aug 10, 2014 at 1:24 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Normal.
  3. Aug 10, 2014 at 1:25 PM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    Normal on the 1st Gens-cannot imagine them adding it to the 2nds
  4. Aug 10, 2014 at 1:28 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    They don't have one. They are not need.
    They would only increase the cost of production at zero benefit to the consumer.
    Most all new cars and trucks have to have the filler cap on and tight for the emission control an to keep the Check Engine light off.
