Metal in Engine Stuck to CPS after it was repaired
Discussion in 'Performance and Tuning' started by Logan808, Sep 7, 2012.
  1. Sep 7, 2012 at 1:55 PM
    Logan808
    Logan808 [OP] Member
    Logan
    Boulder, CO
    96 Tacoma 4x4 2.7L 4Cyl
    Let me start off by stating I'm not mechanically savvy. I just got my CPS replaced since my 96 tacoma 4x4 2.7 4cyl broke down on highway and wouldn't start today. Mechanic said there was bits of metal stuck to end of CPS...I'm thinking of changing oil and screen it to see how much metal is in there. Engine was rebuilt when I bought it and I don't know who did it or what might've resulted from the rebuild. Does anyone have any suggestions for things I should be looking out for or reasons for this. I'm no mechanic, but bits of metal in engine sounds bad.
  2. Sep 7, 2012 at 2:29 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Which weight oil are you using?
    If any thing, at least a 10w-40.
  3. Sep 7, 2012 at 3:13 PM
    Logan808
    Logan
    Boulder, CO
    Not sure what it has, just bought recently. Does it matter that I'm in Colorado (winter approaching), should I be using 5w-30/40? I'm more worried what the metal shavings mean, it has begun to be difficult to get into 1st gear from dead stop, not sure if that is related.
  4. Sep 7, 2012 at 4:05 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    You will still be good with a 5w-40.
    Sounds like a transmission issue or slave cylinder issue, with that last comment.
    But, let me ask, since I do not know. Is your clutch hydraulic or cable?
    Does it grind when trying to go into gear?
    If it is hydraulic, then check the fluid level. If it is full, and you have no idea how long it has been since it has been bled, then bleed it. If that doesn't work then there might be something wrong with the slave cylinder.
    If it is cable, then I cannot tell you what to do, since I have no experience with those.
    Also, if the transmission gear oil hasn't been changed in a while, you should do that as well.
    Just to be clear, by "CPS", you are referring to the crank position sensor, correct?
  5. Sep 7, 2012 at 6:06 PM
    Logan808
    Logan
    Boulder, CO
    yes, CPS was crank position sensor. I'm assuming it's hydraulic and level is full, so maybe it needs to be bled. I'm looking for online manuals to try and mess with it saturday on my day off. I might be taking it into a shop tomorrow since something in engine compartment rattles when rpms are high, sounds like shit. I'll ask them about transmission since they will test drive.
  6. Sep 7, 2012 at 6:09 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Not familiar with this particular engine, but I have never seen a crank sensor that was exposed to oil. They usually work off the flywheel or crank balancer. Metal might be from grinding the starter..... if it's in the back next to the flywheel.
