Metal oil filter housing
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Bigkracka, Jun 2, 2023.
  1. Jul 26, 2024 at 8:09 AM
    #41
    Smacky2020
    Smacky2020 Well-Known Member
    Bristol, VA
    2020 TRD ORDC - Cement
    Stock wheels and suspension. Random "utilitarian" mods featured on this great forum.
    Toyota also technically doesn't make the diff fill/drain plugs for the front member (they're a Lexus part) but many including myself have switched to them because they're a much better design.
    I'm all for replacing things with a better design. I'm not convinced the filter housing is that thing but maybe I'll change my mind if I ever have to destroy mine taking it off. So far after 5 changes, I haven't had issues.
    Kolohe07 likes this.
  2. Nov 27, 2024 at 9:12 AM
    #42
    apotter
    apotter Well-Known Member
    Southern Maine
    2023 Tacoma
    You are lucky for not having any issues - maybe you have the right filter wrench and it wasn’t over torqued. This was the first oil change I have done, and the plastic housing is shattered. I am a hand tight, quarter turn, hand tool mechanic, and this just blew my mind how fragile (in my case) it was. Is what it is, and very encouraged to hear not everyone is having the same kind of poor experience I have :thumbsup:
    TacoTime55 likes this.
  3. Nov 27, 2024 at 9:32 AM
    #43
    Carbender
    Carbender Active Member
    Lyric
    British Columbia, Canada
    2009 Tacoma TRD OR ACLB
    265/75/R16 General Grabbers...More to come
    Dude, double-check the part number on your current housing. That's the foolproof way. Your local Toyota parts counter can also look it up using your VIN.
  4. Nov 27, 2024 at 9:54 AM
    #44
    apotter
    Southern Maine
    2023 Tacoma
    You’re thinking it is the wrong PN bro?
  5. Nov 27, 2024 at 10:23 AM
    #45
    steel wheels
    steel wheels Well-Known Member
    2020-ACLB-4x4-Sport-M/T
    In case anyone wants one I'm selling stuff I had on my 2020 ACLB MT. Look in the Buy/Sell/Trade forum , look under 3rd Gen Tacoma Parts Market place.
    Look for: "Price cut-Taco gone, need this to go..."
    PM me if you see a gem you just can't live without.
  6. Nov 27, 2024 at 11:39 AM
    #46
    bmg88201
    bmg88201 Well-Known Member
    Brian
    Quitman, AR
    2022 Tacoma Limited
    I’m sticking with the OEM composite housing. I had a retired Toyota mechanic tell me to stick with the OEM housing. He said the bypass valve on after market ones might be up to spec. He said why take the chance. Makes sense to me. Since I keep vehicles till they decompose, I’ll probably get a spare OEM housing just in case for down the road. The dealer priced it at around $70.
  7. Nov 27, 2024 at 11:42 AM
    #47
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    I paid for a spare now instead of waiting until my fists of ham break the original and I am "inconvenienced". :anonymous:
  8. Nov 27, 2024 at 12:14 PM
    #48
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    My composite is my spare now.
    Barsoom likes this.
  9. Nov 27, 2024 at 1:58 PM
    #49
    Tacosauro
    Tacosauro Well-Known Member
    23 SR5 V6 & 24 TRD OR
    roof rack
    Trying to avoid breaking the plastic housing? like I did 2 weeks ago, wise man
    soundman98 likes this.
  10. Nov 27, 2024 at 2:01 PM
    #50
    RichochetRabbit
    The housing says "18 ft lbs", not "180 ft lbs". :boink:
    RIX TUX and soundman98 like this.
  11. Nov 27, 2024 at 2:18 PM
    #51
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    i agree with core statement, but don't really agree with his reasoning. for instance-- look at how many brands there are for most filter cans-- i don't think anyone can make the argument with any accuracy that any of them have a better/worse bypass spring than the rest.
    but i also believe that vehicles spend far more time cycling oil past the bypass spring than anyone truly expects. i suspect that only about 10% of oil is actually passing through the filter media at any given time, with the rest bypassing entirely...
  12. Nov 27, 2024 at 2:50 PM
    #52
    Houstoner
    Houstoner Well-Known Member
    Daniel
    2020 DCSB SR V6 4WD
    l ran the metal housing for 4 years 60k miles zero issues. If it scares you keep plastic, if you want to live on the wild side get the metal upgrade.
    MITaco6MT, RIX TUX and TacoTime55 like this.
  13. Nov 27, 2024 at 2:56 PM
    #53
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    check other paces for it cheaper
    bmg88201[QUOTED] likes this.
  14. Nov 27, 2024 at 2:59 PM
    #54
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    lol
    I'm picking up what you're putting down.
    I've seen some broken composites and made the decision to get Aluminum.
    I hand tighten now until the clip snaps on the flat section of the housing sphere.
    dryheat likes this.
  15. Nov 28, 2024 at 10:25 AM
    #55
    Smacky2020
    Bristol, VA
    Sucks you got stuck with it. I really think it begins and ends with dealers or quick lube places tightening the hell out of it.
  16. Nov 28, 2024 at 5:15 PM
    #56
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    The metal housing being discussed is OEM, just like the plastic/composite is OEM; both with the same internal parts. You probably did not make that clear to your mechanic - thus his otherwise good recommendation. From my understanding reading these threads regarding the plastic/metal debate the metal housing is used on Lexus vehicles with the same engine.
    In my opinion either housing is up to the job, with the proper knowledge not to over tighten either.
    TacoTime55 and Barsoom like this.
