Metal on Metal Clang/Clunk on Speed Bumps
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MountainMan227, Sep 19, 2024.
  1. Sep 19, 2024 at 1:29 PM
    MountainMan227
    MountainMan227 [OP] Active Member
    Hey yall,
    Ive been hearing this metal clank on my 15 taco and have had a hard time identifying the culprit. Ive taken it to numerous shops and have had the control arms, shocks, struts, axles, sway bars, and every other suspension piece you can imagine looked at. Everything appears to be in good shape with no issues. I only hear this sound when hitting a speed bump or deep dip in the road at low speeds. I do not hear it at medium or high speeds, regardless of the size of the bump
    Has anyone else had this issue? One shop was convinced it was the lower engine cover, so I allowed them to replace it and the sound persists. Any insight would be much appreciated. I attached two videos where you can hear the sound.
    https://www.kapwing.com/videos/66ec888b5dba190f83a03fb9
    https://www.kapwing.com/videos/66ec88d1c6d4422581648366
  2. Sep 19, 2024 at 2:05 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    MountainMan227[OP] likes this.
  3. Sep 19, 2024 at 2:10 PM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    I had a similar noise in my 2014 TRD Sport and after looking at pretty much all of the stuff you've looked at, it turned out to be a loose bed side support rod in front of the rear wheel well on the driver's side. Might be worth a try.
  4. Sep 19, 2024 at 2:13 PM
    MountainMan227
    okay that is super helpful. I have never heard of that part and cant seem to find pics. Can you give a little more detail on where to find it?
  5. Sep 19, 2024 at 2:19 PM
    Too Stroked
    Tom
    I no longer have a Tacoma (in a 4Runner right now), but the part in question is a quarter inch diameter round rod that goes diagonally upward / inward from the lower front corner of the rear wheel well opening on the bed side to the frame if I recall correctly.
  6. Sep 19, 2024 at 3:07 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Does it happen on compression or droop?
    If you're running any kind of lift in the front, your upper control arm may be hitting a coil at full droop.
    You can jack up the front of the truck, get the tires off the ground, take off your wheels and check the clearance between the UCA and coil on both sides.
  7. Sep 20, 2024 at 2:07 PM
    MountainMan227
    No lift, but that is almost exclusively when I hear the noise. I'll look for signs of impact on UCA and coil. Thanks man
  8. Sep 20, 2024 at 6:01 PM
    Fenwick1993
    Fenwick1993 Hillbilly
    Not Fenwick
    Chesapeake, VA
    96 Tacoma 5Lug, 2015 PreRunner
    Stonewall is the fattest 5 lug slug ever
    Subbed, cos mine makes the exact same sound under the exact same conditions, and nothing appears to be the obvious culprit.
  9. Sep 21, 2024 at 7:22 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Make sure the spare tire is winched up tight. They can get loose and move around.
    CrazyCrewChief and wilcam47 like this.
  10. Sep 21, 2024 at 8:24 PM
    CrazyCrewChief
    CrazyCrewChief Unknown Member
    Gordon
    NorCal
    2015 Tacoma AC TRD Sport MGM
    ^^^This! My truck does this and it is the spare tire. Since I know what it is, I'm not that concerned about it.
