Metal rattling noise when accelerating
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fatmonk8, Dec 10, 2018.
  1. Dec 10, 2018 at 10:16 AM
    Fatmonk8
    Fatmonk8 [OP] Did anyone ever tell you you're my hero?
    Paul
    Delco, PA
    2019 SR5 Barcelona Red Taco 3.5 V6
    Honestly I am hoping it is just something simple like this.
    El Duderino likes this.
  2. Dec 10, 2018 at 10:16 AM
    Fatmonk8
    Paul
    Delco, PA
    Probably going to try this before I full plugs
    eon_blue[QUOTED] likes this.
  3. Dec 10, 2018 at 10:17 AM
    eon_blue
    Azusa, CA
    I would run 91 or 93 (whatever premium is in your area) since mid-grade might not be enough to diagnose.
  4. Dec 10, 2018 at 10:20 AM
    Tectonic
    Tectonic Well-Known Member
    James
    Tucson, AZ
    12 TRD Sport DCSB 4wd
    Bilstein 5100 all around OME 884 Wheelers 1.5" 3 leaf progressive aal 255/75r17 Hankook Dynapro ATM ARE camper shell Hella Sharptones (4)
    If it is ping, it's probably not that bad. There's a ton of threads on ping, and it's *probably* not going to hurt your engine. Mine has pinged for years, though it's a little better after the ECU flash... But, obviously we all hope it's just a loose heat shield...
  5. Dec 10, 2018 at 10:21 AM
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    Gravel/rocks in the heat shield.
  6. Dec 10, 2018 at 10:23 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    I bet your missing some screws on the skid pan/plate
  7. Dec 10, 2018 at 10:24 AM
    Fatmonk8
    Paul
    Delco, PA
    Na, checked all my heat shields
    Alexely999[QUOTED] likes this.
  8. Dec 10, 2018 at 10:24 AM
    Fatmonk8
    Paul
    Delco, PA
    Don't have one
  9. Dec 10, 2018 at 10:24 AM
    eon_blue
    Azusa, CA
    I don't know what the 2nd gen N/A ping sounds like, but man...you should hear a supercharged 3.4l ping when it's running lean...it sounds awful. To the point where I have to immediately let off the throttle for fear of engine failure. It even burned out my catalytic converters before I upgraded the fuel system and got rid of 75% of the issue.
  10. Dec 10, 2018 at 10:25 AM
    Fatmonk8
    Paul
    Delco, PA
    It's more of a metal rattle then a ping.
  11. Dec 10, 2018 at 10:29 AM
    BillsSR5
    bill
    2014 SR5
  12. Dec 10, 2018 at 10:30 AM
    Tectonic
    James
    Tucson, AZ
    When mine pings it sounds like a metal rattle. I think it sounds a lot different than the 3.4L. I thought it was a heat shield for a while. Think about when it happens. If it's only under load, that suggests it's more likely coming from the engine. If not then it's any number of other things. Again, high octane gas is the best test
  13. Dec 10, 2018 at 10:43 AM
    Fatmonk8
    Paul
    Delco, PA
    Alexely999 likes this.
  14. Dec 10, 2018 at 10:44 AM
    Fatmonk8
    Paul
    Delco, PA
    Yea it is definitely under load, I will try a higher octane when I have to fuel up next.
    Tectonic[QUOTED] likes this.
  15. Dec 10, 2018 at 11:01 AM
    #35
    BillsSR5
    bill
    2014 SR5
  16. Dec 10, 2018 at 11:02 AM
    #36
    Fatmonk8
    Paul
    Delco, PA
    devkurf likes this.
  17. Dec 10, 2018 at 11:04 AM
    #37
    BillsSR5
    bill
    2014 SR5
  18. Dec 10, 2018 at 11:05 AM
    #38
    Fatmonk8
    Paul
    Delco, PA
  19. Dec 10, 2018 at 2:39 PM
    #39
    obscurotron
    obscurotron Well-Known Member
    N. Nevada
    '14 DCSB 4x4
    Too many to list, and I've probably forgotten a bunch.
    Said you checked heat shields, did you check the clamshell heat shield around the catalytic converter right under the driver's footwell?
    I had exactly the same sound, at the same RPM's, in my '14 this summer. Was bad when cold, sometimes it went away when warmed up. Checked the usual suspects, then I tapped on the cat shield with a rubber mallet. Got some noise, so I took the clamshell off (after destroying the rusted nuts/bolts holding it on.) Sure as shit, had some rocks in there. Cleaned it all out, got some stainless hardware from OSH (before they went Tango Uniform), put it back together, and noise gone.
    In fact, that might be the only unwanted noise I've ever isolated and corrected on this truck!
  20. Dec 10, 2018 at 4:22 PM
    #40
    eon_blue
    Azusa, CA
    I don't know about 2nd gens, but on 1st gens the oil pan is dangerously vulnerable without the skid plate on, even the stock tin can skid plate is better than nothing. I hope you don't go offroad without one....one good hit to the oil pan and you're in big time trouble. Even on the street if you run over something big at driving speeds it can puncture the pan and you're gonna have a bad time
