Metal rattling noise when accelerating
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fatmonk8, Dec 10, 2018.
  1. Dec 27, 2018 at 7:36 PM
    #81
    Smokehouse
    Smokehouse Procharged
    Zach
    Republic, Missouri
    2007 Super White Tacoma Sport
    Thanks man, also thanks for not attacking me for not knowing haha
    Druss2012 and Running Board Man like this.
  2. Dec 27, 2018 at 7:43 PM
    #82
    Freeheelbillie
    Freeheelbillie Well-Known Member
    Billie
    Saint Clair, MI
    2019 Tacoma SR, DCSB
    FRONT END King Stage 3 3” RR Coil Overs SPC UCA’s REAR END King Stage 3 BAMF Shock Relocation Rear AAL Heavy ARB Universal Diff Breather Kit TIRES & RIMS 16” Method Bronze BFG K02 (315/75/R16) ARMOR Demello Off Road Baja Hoop Front Bumper Main Line Overland Rock Sliders w/ Top Plate ¼” Aluminum RCI Fuel Tank Skid RCI Fuel Tank Straps RCI Rear Diff Skid RCI A-Arm Skids RCI – Front, Transmission, and rear Transfer Case Skid DRIVE LINE YotaWerx, BlackHawk Tune Re Geared w/ Nitro 4.56 Package Front ARB Air Locker Rear ARB Air Locker 8” Reverse Clamshell 3.73 & Down Carrier RECOVERY ComeUp Seal Gen2 9.5RS Winch, Synthetic Line ComeUp Seal Hawse Fairlead ARB On Board Twin Air Compressor LIGHTING Squadron-R Pro Amber Fogs (Wide Cornering) Baja Designs Rock Lights Squadron Sport Fogs (qty 4) Baja Designs Bed Light Kit SPODS, HD 8 Circuit Switch Panel
    No judgment here, happy to help.
    Here's a video on a nice trick for locating noises. The jug is a nice touch but not necessary, just hold the handle close to your ear.
    https://m.youtube.com/watch?v=fHtLH_m9gN4
  3. Dec 27, 2018 at 8:33 PM
    #83
    Smokehouse
    Zach
    Republic, Missouri
    It is sadly, people won't learn if you don't teach them
    Freeheelbillie likes this.
  4. Jan 4, 2019 at 2:23 PM
    #84
    sr52008tacoma
    sr52008tacoma Active Member
    check your heat shields theres a ton of them under there that like to rattle or fall off
  5. Jan 4, 2019 at 2:28 PM
    #85
    Fatmonk8
    Fatmonk8 [OP] Did anyone ever tell you you're my hero?
    Paul
    Delco, PA
    2019 SR5 Barcelona Red Taco 3.5 V6
    Yeah that has been mentioned already, they have been check all are fine.
  6. Jan 11, 2019 at 7:33 AM
    #86
    tbolish
    tbolish Member
    Any update on this? My 2.7 has the same issue, although completely at random it seems. Would love to know what it was.
    Thanks
  7. Jan 11, 2019 at 7:43 AM
    #87
    Fatmonk8
    Paul
    Delco, PA
    Honestly no, I have done everything to shaking almost all parts of my truck, to fixing any loose heat shield, to even taking valve covers off and replacing plugs and I have still found nothing. It is driving me mad.
  8. Jan 11, 2019 at 9:53 AM
    #88
    Freeheelbillie
    Billie
    Saint Clair, MI
    So you removed the serp. belt and checked the idler pulleys?
  9. Jan 11, 2019 at 10:00 AM
    #89
    Fatmonk8
    Paul
    Delco, PA
    yup, aside from rust they seemed tight.
  10. Jan 23, 2019 at 5:32 PM
    #90
    Fatmonk8
    Paul
    Delco, PA
    Sorry to bump an old thread again, but I feel like I have to come clean.
    So today I found out what the noise was...
    I figured I would wait to see if Toyota replacing my frame would fix the problem, maybe they would take apart or find what was loose and when they re-assembled my truck that somehow it would get fixed. It didn't. After I got my truck back the noise was worse.
    So after work today and hearing it the whole ride home Jersey to Pennsylvanian. I decided to take a look under the truck again. At that point I said fuck it, my other cat clam heat shield was already gone since I bought the truck so I figured id just pull the other one off. and what do I find....the damn metal strap was rusted thru and broken...I removed the clam and drove around and the noise is gone..
    to everyone that said it was my heat shield....you where right...I am a ashamed Tacoma owner tonight :(:rain:
    tsb, deanosaurus, 12TRDTacoma and 6 others like this.
  11. Oct 3, 2019 at 10:50 AM
    #91
    Levalexi
    Levalexi Well-Known Member
    Southern Maine
    07 Tacoma access cab 4x4 2.7l
    Did you have this noise all the time? I get a rattle, but it seems to only Happen when the trucks getting warmed up.
    wilcam47 and MarcomaN like this.
  12. Feb 16, 2020 at 8:48 PM
    #92
    taco541562
    taco541562 New Member
    99 tacoma trd
    sorry to bring up old thread but i believe i have this issue. i am supercharged with the 3.4 and getting a rattle at about 2200 rpm while under load/boost on the highway once i get into a lower gear/higher RPM it goes away
    rharris5551 and wilcam47 like this.
  13. Feb 16, 2020 at 8:59 PM
    #93
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Im getting this on my f150... random rattle goes away at 60+
  14. Feb 17, 2020 at 6:21 AM
    #94
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    Might be dumb but I had a similar rattle that ended up being rocks in the cats heat shield...
  15. Feb 17, 2020 at 6:26 AM
    #95
    EdgemanVA
    EdgemanVA Well-Known Member
    Virginia Beach
    2008 X-Runner
    Several
    Speaking of the cat heat shield, I drove over a plastic grocery bag, and it got stuck to my cat. I smelled burning plastic for at least 3 months.
    Alexely999[QUOTED] likes this.
  16. Feb 17, 2020 at 6:26 AM
    #96
    Alexely999
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    :eek:
  17. Sep 6, 2020 at 8:26 PM
    #97
    tacoooking
    tacoooking Well-Known Member
    Dana Point, CA
    2016 TRD Off-Road
    why would that only happen when accelerating though?
    wilcam47 likes this.
  18. Sep 6, 2020 at 8:51 PM
    #98
    tacoooking
    Dana Point, CA
    2016 TRD Off-Road
    having same issue
  19. Sep 6, 2020 at 9:42 PM
    #99
    Running Board Man
    Running Board Man Well-Known Member
    Dirty injectors, not running smooth under acceleration
  20. Sep 6, 2020 at 9:51 PM
    #100
    tacoooking
    Dana Point, CA
    2016 TRD Off-Road
    dirty injectors = heat shield? lol
