Metal rattling noise when accelerating
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fatmonk8, Dec 10, 2018.
  1. Sep 6, 2020 at 11:00 PM
    #101
    Running Board Man
    Running Board Man Well-Known Member
    No you dingus, dirty injectors = rough running = vibration = rocks rattling in heat shield
    You wanna see what I mean go unplug a coil or injector and drive around you'll find it doesn't feel bad when off the throttle but on the gas it feels like you're re entering the atmosphere
    wilcam47 likes this.
  2. Sep 7, 2020 at 7:33 AM
    #102
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    Idk maybe just the vibrations from acceleration, but when I finally found and removed them it solved the problem :thumbsup:
  3. Sep 7, 2020 at 7:50 AM
    #103
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I am glad to hear you found your rattle. I removed my Y pipe recently and found that cat clam shield to be totally unserviceable. The strap and the bolts were rusted beyond any sort of repair and would not budge no matter what. I said to hell with it all and just cut it off and run without that shield now. Considering it's function, the hardware and the straps which hold that shield in place are made of cheap garbage.
  4. Sep 7, 2020 at 10:11 AM
    #104
    boredazhell
    boredazhell Well-Known Member
    It takes a good man to give updates. Usually threads like this when the guy found the problem, 1. He doesnt give an update which causes other people looking for answers to find a dead end. 2. The issue was something suggested by someone else in the thread which was put off. Which makes op not come clean and leaving the thread dead.
    Now i have to look at my clam shell. Thx for the update.
  5. Nov 13, 2020 at 9:27 PM
    #105
    Sergei K
    Sergei K Member
    Sergei
    2019 Toyota Tacoma
    I have been experiencing the same thing for months now. (Rattling noise like gravel/nails in a tin can) It’s extremely irritating, good news is that it was an easy fix! Keep an eye out for the bolts by the heat guard by the exhaust. I found two bolts that were so lose I could tighten it with my fingers. THE WASHERS were actually the cause of the rattling. Once located and tightened, the noise stopped. Hope this helps!
  6. Nov 19, 2020 at 5:35 AM
    #106
    rharris5551
    rharris5551 Well-Known Member
    Jasper, TN
    08 xrunner & 10 T4R limited
    I’m having the same exact problem. Ever find out what was the cause ? I’m also supercharged, 7th injector, and get the sound when I gouge on it in a higher gear at lower rpm soon as it gets to a higher rpms the sound goes away.
  7. Jan 2, 2022 at 2:06 PM
    #107
    santan
    santan New Member
    2012 Tacoma TRD
    Been battling this for 6+ months on my 2012 and had the same issue on my 2005 Taco before I sold it.
    After so many engine-related efforts chasing it, I finally pulled the cat heat shield off and found it to be the cause of my “rattle” as well.
  8. Feb 16, 2022 at 7:45 AM
    #108
    Thefinalfight
    Thefinalfight Born for the road
    Calvin
    Pittsburgh pa
    2013 Tacoma trd 4x4 v6 4.0
    Brake controller (aftermarket) Receiver hitch
    Hey OP @Fatmonk8 did you ever solve this? Sorry to post on an old thread but I have the exact same issue on my 2013 prerunner (v6 automatic) and wanna try to figure it out myself before taking it for service. It’s around 15-20 rpm’s and sounds like hardware rattling in a can or something. Basically you’re exact description. Thanks in advance
  9. Feb 16, 2022 at 8:26 AM
    #109
    EdgemanVA
    EdgemanVA Well-Known Member
    Virginia Beach
    2008 X-Runner
    Several
    Just beware it may be something more expensive. I have a car that I would hear rattling, especially when I revved it up and let off. It turned out to be the components in the catalytic converter had started to crumble. The back section was still in tack, holding the loose pieces inside. Guess I can be thankful they didn't migrate down into my muffler.
    One expensive catalytic converter later, the problem was fixed.
    Thefinalfight likes this.
  10. Feb 20, 2022 at 12:20 PM
    #110
    Thefinalfight
    Calvin
    Pittsburgh pa
    Did you ever figure this out? I have the exact issue on my 13 prerunner v6
  11. Feb 20, 2022 at 12:44 PM
    #111
    Thefinalfight
    Calvin
    Pittsburgh pa
    Hey you ever figure this out? I’m having the same problem with my 13 prerunner 4.0
  12. Mar 1, 2022 at 10:38 AM
    #112
    Fatmonk8
    Fatmonk8 [OP] Did anyone ever tell you you're my hero?
    Paul
    Delco, PA
    2019 SR5 Barcelona Red Taco 3.5 V6
    it was the heat shield, I just took it off.
    gsubioguy likes this.
  13. Jun 10, 2022 at 2:14 AM
    #113
    BigOleWallace
    BigOleWallace Active Member
    Preston
    East NC
    2021 Army Green Tacoma TRD Off-Road 4X4
    Etsy
    jyamauchi likes this.
  14. Oct 5, 2022 at 5:20 PM
    #114
    4xThad
    4xThad Thad
    Thad
    Bend, OR
    2021 Cement Tacoma TRD OR DCLB; 2021 Blizzard Pearl 4Runner Limited; 2006 Tundra-SOLD
    Tint, DK ucas, Big Billies with Icon springs, SCS S6 wheels wrapped in Duratracs, a GFC, a Smartcap, martin OR RR, roam boxes sometimes, maxtrax and rotopax sometimes, and a ski rack other times
    pastrami199 likes this.
  15. May 23, 2023 at 1:28 PM
    #115
    gulfcoasttroll
    gulfcoasttroll Well-Known Member
    Jacob
    Pensacola
    '15 DCLB 4WD MGM. RIP '08 DCSB 4WD SW
    Fresh start - no mods
    Old thread but my truck (2015 taco w/ 80K miles) has been making a funny sound only when accelerating and under 40mph. Been going on for about 2 months. I wouldn't say mine sounds like a rattle or metallic like people describe with the loose heat shields. Mine sounds garbled, almost like a boat engine under water sound if that makes sense at all? As I accelerate its like I can hear the normal engine sound but it's got like a repetitive bubbly waaahhhh tune to it. As soon as I let off the gas it stops. Over 40mph it goes away completely and sounds normal. Cold or hot it will do it on command as soon as I press the gas, and stop as soon as I left off. Any thoughts? My wife and I have been having to switch cars frequently transporting kids and what not so I forget to check it out while I'm driving hers, until I get back in the truck and notice it again.
    Doesn't make the sound in neutral sitting in the driveway pressing on the gas. When it happens it feels like I hear it towards the engine bay a little to the right as I'm sitting in the drivers side.
  16. Sep 30, 2023 at 5:36 PM
    #116
    Dady83
    Dady83 Well-Known Member
    2020 Tacoma SR5
    I'm having the same exact noise, u described it well, 2020 tacoma, 17k miles first owner, oil change on times. What that can be? Everyone including dealers can't give me an answer, some people say that engine due high pressure in summer requires 93 gas. Any new ideas are welcome
  17. Oct 18, 2023 at 6:12 AM
    #117
    Ken99287
    Ken99287 New Member
    2013 v6 double cab, long bed
    Mine is doing this! Started a few months ago and was barely noticeable. Happened mostly when starting from a stop. I thought one of the kids put rocks or nuts in a cup holder, but the nose was coming from the front drivers side, maybe just inside the engine bay.
    It's been getting worse - lost and starting to make the noise whenever I accelerate.
    I'll have to try the high test and spark plugs.
    Oh I also have a pedal commander, maybe I'll try turning it off or removing it as well.
  18. Jun 22, 2024 at 10:51 AM
    #118
    Tylerkxj
    Tylerkxj Member
    Orlando, FL
    2021 TRD Pro
  19. Jun 22, 2024 at 1:39 PM
    #119
    Plasmech
    Plasmech Well-Known Member
    2009 SR5 V6 Access Cab TRD Off-Road
    Mine does the same thing. When I hit exactly 1850 RPM under load I get a metallic rattlecan sound. It's not a knock or a ping. it drives me nuts.
  20. Jun 24, 2024 at 4:56 AM
    #120
    Plasmech
    Fixed mine this weekend. It was the driver's side heat shield.
