metal sound
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ProRacerNorm, Jun 29, 2010.
  1. Jun 29, 2010 at 9:11 PM
    ProRacerNorm
    ProRacerNorm [OP] Member
    Norm
    Salem County NJ
    07 TRD Off-Road Lifted
    URD MKII Stage 3, Borla Cat-back, Doug Thorley Headers, ICPW Tail and Third Brake Lights, ToyTec Ultimate Lift Kit 3", GrillCraft MX Series Upper and Lower, Kenwood Double-Din, 18" RBP 94R with 285/65/18 tires.
    I have been getting a metal sound like its hitting something when i brake heavy. anybody have an idea what it could be
  2. Jun 29, 2010 at 9:13 PM
    S.B.
    S.B. Well-Known Member
    Sean
    Colorado Springs, CO
    08 Taco 4x4 TRD OffRoad Rugged Trail
    Fox 2.5, Built right UCAs, CBI Front bumper, NWTI Rear bumper, 35s
    If you feel it the pedal (pualsating) then it called anti-lock brakes. They are just noisy in tacomas.
  3. Jun 29, 2010 at 9:19 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    it could also be the floating brake pads design
  4. Jun 29, 2010 at 9:19 PM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    When was the last time you had a brake job?
  5. Jun 29, 2010 at 9:19 PM
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    mines so annoying i hate it
  6. Jun 29, 2010 at 9:23 PM
    ProRacerNorm
    Norm
    Salem County NJ
    brakes were done not too long ago...its too late now but im gonna look at the wheel tomorrow
  7. Jun 29, 2010 at 9:31 PM
    S.B.
    Sean
    Can you feel it in the pedal.
  8. Jun 29, 2010 at 9:34 PM
    Timicha
    Timicha Timicha
    TIM
    Tillamook / Portland , Oregon
    04 White Tacoma
    Fabtech 4 inch lift, tinted windows, diff drop, 33 inch MTZ tires on Raceline Raptor wheels, ELITE OFF-ROAD bumpers and sliders
    most brake pads have little metal pieces that will screach when you hit the breaks so that you know when its time to change your pads. check to see if your pads are getting worn down and if the little metal prongs are the screaching metal noise. be my best guess
  9. Jun 29, 2010 at 9:38 PM
    ProRacerNorm
    Norm
    Salem County NJ
    no its no feeling or anything just a sound like scraping metal
  10. Jun 29, 2010 at 9:39 PM
    Timicha
    Timicha Timicha
    TIM
    04 White Tacoma
    i'd defenetly check your pads then cause you wont feel anything they just make a sound to warn you they are getting low and need replacing soon. and you would only hear it when you press on the brakes
  11. Jun 29, 2010 at 9:39 PM
    kinkrider101
    santa barbara
    wheels and tires
    does it sound like something is being thrown against mateal..like A popping noise.thats what mine sounds like
  12. Jun 29, 2010 at 9:41 PM
    S.B.
    Sean
    Also known as the squealers.
  13. Jun 29, 2010 at 9:42 PM
    ProRacerNorm
    Norm
    Salem County NJ
    thanks guys ill check it out in the am
  14. Jun 29, 2010 at 11:50 PM
    Timicha
    Timicha Timicha
    TIM
    04 White Tacoma
    haha ya i dunno any official name i just know they are there :D
  15. Jun 30, 2010 at 8:31 AM
    hans2
    hans2 Member
    +1, same sound. Not the ABS. Seems to be coming from the pedal assembly under the dash. First heard at ~ 14K miles. 2.7 L.
  16. Jun 30, 2010 at 8:49 AM
    AeroCooper
    AeroCooper Half the strength of ten (microscopic men)
    NH
    2018 Barcelona Access Cab Off Road
    Pro grille, remote start, tailgate inserts, nifty key fob
  17. Jun 30, 2010 at 1:28 PM
    ProRacerNorm
    Norm
    Salem County NJ
    Found out what it was...It was the metal shroud around the back side of the brakes. It was bent in a little bit
  18. Jun 30, 2010 at 2:11 PM
    Timicha
    Timicha Timicha
    TIM
    04 White Tacoma
    sweet glad you found what it was
  19. Jun 30, 2010 at 11:56 PM
    YeahYeah
    YeahYeah Well-Known Member
    Thomas
    (My Home - Murrieta, CA) Now, Alexandria, VA
    07 Tacoma Pre-Runner
    mud flaps gone, second air-filter gone, DTRL, fog light whenever and work with hi-beams, cut exhaust (was wicked flow), flat black stock rims, ABS switch, cup holder led's (with switch), turning signal mod #45, Bilstien 5100's, grill mesh
    you do that abs mod? i did and it happens when I turn mine off.
