Metal Sounding Rattle From Rear End (maybe)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by C_Rob18, Jul 15, 2025.
  1. Jul 15, 2025 at 6:56 PM
    C_Rob18
    C_Rob18 [OP] New Member
    Caleb
    North GA
    2017 Silver Tacoma DCLB TRD Sport 4x4
    Unknown Lift & Bumpers 33’s Prinsu Front Rack Paintmatched Leer Camper top
    Hey guys!
    long time lurker, brand new account.
    I recently (Jan ‘25) purchased a DCLB TRD Sport with 88k and have since put 11k on her. Got some off brand/unknown bumpers, maybe a lift, racks, camper top, all the goodies to start off with but that’s besides the point. I shamefully admit that I just now rotated the tires last week and ever since it being on the lift, it has had this rattle and it’s killing me. Only from 10-20mph, any direction in any gear. HELP PLEASE IM LOSING MY MIND
    https://imgur.com/a/OfVN2SD
    EDIT: SOLVED.
    Cam/mount for the spare tire chain was rattling at low speeds. Rendered it immovable and the sound is gone. Thank you all for your help and welcoming me into the community!
  2. Jul 15, 2025 at 7:00 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    Make sure the spare tire chain below the bed is secured and not rattling. Welcome to TW.
    wilcam47 likes this.
  3. Jul 15, 2025 at 7:03 PM
    C_Rob18
    Caleb
    North GA
    Much thanks!
    as far as I can tell, it has been removed by the previous owner (before trade in)
  4. Jul 15, 2025 at 7:05 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Sounds like it’s tied to rotations, so I’d look at driveshaft and wheels.
    Maybe drums aren’t seated right and are scraping on the backing plate.
  5. Jul 15, 2025 at 7:06 PM
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    A@!#$@$%#$%
    The wild west
    2016 SR5 DCSB
    heat shield come loose?
  6. Jul 15, 2025 at 7:31 PM
    sleestak
    sleestak Active Member
    Are the covers that snap over the wheel nuts loose and moving around? It's pretty common on the TRD Sport wheels where the spring wire doesn't provide enough tension and they rattle on the wheel over every little bump. Just a thought since you said it only happened after the tire rotation and it's a quick check.
  7. Jul 16, 2025 at 7:06 AM
    TA2016
    Oregon
    Do you not have a spare tire below your bed? If you do have a spare tire and don’t see the lowering chain dangling, someone may have tucked the chain against the spare wheel causing it to rattle.
  8. Jul 16, 2025 at 10:08 AM
    C_Rob18
    Caleb
    North GA
    I do not have a spare underneath, thanks for the idea though!
    TA2016 likes this.
