Metallic clunk going over bumps
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jesusjones142, Feb 11, 2020.
  1. Feb 11, 2020 at 3:12 PM
    jesusjones142
    jesusjones142 [OP] Well-Known Member
    none
    I’ve been getting this metallic clunk that’s progressively gotten worse over the last year or so. It started in the front right, now I hear it on the left as well, sometimes one side or the other rather than both at the same time. I don’t hear it over small bumps like you’d find on a dirt road but rather speed bumps or large dips in the highway that case a significant compression in the front suspension. I can kind of feel the clunk through the floor too.
    I don’t visually see anything loose or any signs of anything hitting anything else. The truck is a 2015 trd sport DCSB 2wd with 58k. Where should I begin looking and what am I looking for exactly.
  2. Feb 11, 2020 at 3:15 PM
    TacoTuesday94
    TacoTuesday94 Well-Known Member
    Ry
    Huntington Beach CA
    Supercharged 4.0 2010
    Is it stock or have you made modifications? Have you wheeled it hard or stayed mostly on the road? Do you have any excess weight up front like a winch or steel bumper? Do you have a stock wheel size? What type of climate do you live in?
    edit: Also, if possible, can you tell if the clunk is happening on compression or release?
    12TRDTacoma likes this.
  3. Feb 11, 2020 at 3:18 PM
    jesusjones142
    none
    Bone stock. Bought it used with 32k from the dealer. Original tires even. Never been off toad, strictly road driving, no mods, in Nor Cal
  4. Feb 11, 2020 at 3:32 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    radiator support bushings.
  5. Feb 11, 2020 at 3:46 PM
    jesusjones142
    none
    How do I check to see if they’re bad
  6. Feb 11, 2020 at 3:50 PM
    Musubi3
    Musubi3 Well-Known Member
    Big Island
    2014 Tacoma DC 4x4 TRD Off Road, Supercharged
    If you can replicate it at slow speeds with someone outside watching and listening, that may help you hone in on where and what. That's how I've diagnosed most of my random noise issues.
  7. Feb 11, 2020 at 3:59 PM
    TacoTuesday94
    Ry
    Huntington Beach CA
    Hmmm. Without hearing it I’m not quite sure. However a good place to start is:
    1) check that none of the control arms are contacting the spring, you would most likely be able to see a cleaner part of the spring of your truck is a bit dirty.
    2) probably doesn’t apply to you, but check around the wheel well to see if your tire is making any contact with any part of the fender.
    3)check and see if your lower ball joint is leaking grease, but usually this wouldn’t happen at 60k miles.
    4)check for signs of excessive wear on your shocks, seepage, etc.
    5)check your brakes and rotors and make sure they aren’t loose or misaligned.
    That’s a fairly standard place to start.
    Best of Luck! I’m rooting for your truck!
  8. Feb 11, 2020 at 6:48 PM
    Muldoon
    Muldoon Well-Known Member
    Robert
    Northeast Ohio
    2009 4x4 ACLB TRD-OR 4.0, Green
    5100s, Wheelers AAL, Leer 100R
    You’d have probably noticed upon looking around, but double check your CV axle boots. See if there’s evidence of tearing or leaking. A cv axle that’s worn can clunk when hitting bumps like that
  9. Feb 11, 2020 at 6:56 PM
    maxtherat
    maxtherat Well-Known Member
    Inland Northwest
    2001 Dodge Ram 2500, 1993 Jeep Wrangler
    All the usual diesel truck mods- fuel system upgrade, programmer, CAI, intake manifold, 60MM stealth turbo
    These kinds of clunking noises can come from the rear as well and they just sound like it’s from the front. Two things I’d check, just off the top of my head, are the lower control arm cam bolts or the rear suspension for a broken leaf spring(s).
  10. Feb 11, 2020 at 11:47 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Check that your spare tire is tightly cranked up and not slightly loose or it moves.
    Also as inflation decreases as most never check it so does the size so gets loose.
  11. Feb 12, 2020 at 12:07 AM
    Fluffymonkey
    Fluffymonkey Token
    College Station, TX
    2013 Trd Sport DC, 07 DC sr5, 03 Prerunner
    2003: Stock 2007: Avid Offroad sliders, 30% front tint, bed mat, Truxedo low-pro qt tonneu cover, aero turbine 2525 muffler w/ 8'' tip, AR25 Resonator, 16x8 Dick Cepek DC-1 w/ 265/75 Goodyear Wrangler Duratracs, 2010 headlights, ome 884 coils with .5'' top plate spacer, OME sport front shocks, bilsten 5100s rear, 2'' aal, locking gas cap, LR ucas, Viper 2-way remote start, afe drop in filter, Rocky locking bike mounts, gear chest, scangauge, pop n lock tailgate lock 2013: most things transferred over from my 07, 5100s @ .85 + eibachs and Toytec tps for 3'' front lift, wheelers progressive aal w/ overload; compustar 2-way remote start; Antennex shorty antenna, pop n lock tailgate lock with programmable key, seat covers, Toyota's crappy all-weather floor mats (should have got Husky's or Weathertechs), TRD skid plate, led light pods mounted in front bumper valence w/ Eyourlife wireless harness and remote, led bed lights, light pods mounted in bed, Devil Horns emblem from Diaz Fabrications, rear facing pod lights in bed, under seat lights,
    Something is loose it seems, but probably not enough to notice it at low speeds, only when you hit big bumps. Crawl underneath and start double checking to make sure everything is torqued to spec. I've had a few incompetent lift shops install parts and days later i've noticed clunking. Crawled underneath and noticed I could unscrew some bolts with my fingers. I know you're stock, but that's not to say something might not be torqued properly.
  12. Feb 12, 2020 at 12:17 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    My vote is on radiator support bushings as well.
