Metallic grinding noise when stopped
Discussion in '1st Gen. Tacomas (1995-2004)' started by PsiBlast, Dec 29, 2015.
  1. Dec 29, 2015 at 8:40 AM
    PsiBlast
    PsiBlast [OP] Well-Known Member
    Connecticut
    A low-pitched metallic grinding noise can be heard from the car (not sure exactly from where) when I am stopped and in gear (with the brakes on). As soon as I let off the brakes, the noise stops.
    The noise is gone when I put it in Park or Neutral.
    It's a steady constant noise, not rhythmic at all, and happens when the car comes to a stop. If I'm crawling and hit the brakes, the noise isn't there. Again, only when the car is at a complete stop. Then when I let off the brake, the noise goes away.
    Any ideas?
  2. Dec 29, 2015 at 8:54 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    You need to attempt to determine where the noise is coming from. While its in your driveway, with you holding down the brakes, have someone try to figure out where its coming from (preferably, someone who knows more about cars ).
    My 2 wild-ass-guesses would be a bad motor mount (there are 3), or the fan is hitting the shroud.
  3. Dec 29, 2015 at 10:10 AM
    PsiBlast
    Connecticut
    Ok. The sound is definitely coming from the front passenger side. I also noticed that the sound there when slowly backing into a parking space and turning the wheel. The sound seemed to "travel" with the motion of the steering wheel.
