Metallic Noise in Drive and Reverse at idle coming from front end
Discussion in '1st Gen. Tacomas (1995-2004)' started by Steelhead Huntah, Feb 5, 2017.
  1. Feb 5, 2017 at 1:01 PM
    Steelhead Huntah
    Steelhead Huntah [OP] Active Member
    1996 Toyota Tacoma 3.4l
    Sounds like front differential but not sure?? Any advice 1996 3.4l 285k
  2. Feb 5, 2017 at 1:12 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Drain diff fluid and look for chunks?
  3. Feb 5, 2017 at 1:14 PM
    cruiserguy
    Elijah
    SEKS
    I'd look at cv joints and make sure they're not blown. Then the driveline and then drain diff.
  4. Feb 5, 2017 at 1:14 PM
    CD20H
    CD20H Well-Known Member
    Ben
    North Texas
    2004 Double Cab TRD 4x4 Limited
    Magnuson Kompressor, OME lift kit, JBA Headers, junky Sony radio.
    You going to have to dig a little deeper into the situation. When in doubt lift the front end and start moving things until you can replicate the grinding sound.
  5. Feb 5, 2017 at 1:25 PM
    Steelhead Huntah
    I've drained the diff fluid a month ago, found some metallic on plug and some chunks but not a lot. Thought it could be u joints but not if it is occurring during idle. I have replaced one cv axle on passenger side but drivers side seems fine. I put camera under truck. sound is made when at idle, so cv axles aren't moving and u joints aren't either??
  6. Feb 5, 2017 at 1:31 PM
    cruiserguy
    Elijah
    SEKS
    Noise only occurs at idle? Maybe a motor mount or tranny mount?
    Tacofart likes this.
  7. Feb 5, 2017 at 1:37 PM
    Steelhead Huntah
    Yes, but only in Reverse, Drive, 1,2 but not in Neutral. I made a video of the noise but noticed the file is too big to upload. I'll try linking to youtube soon. I'm wondering if it's the spider gears in the differential because noise sounds metallic and like its going to lock up.
  8. Feb 5, 2017 at 8:46 PM
    wamego
    wamego Well-Known Member
    2020 Tacoma Limited 4x4 V6
    Something on the exhaust, lose or cracked??
  9. Feb 5, 2017 at 9:27 PM
    Steelhead Huntah
    I don't think so, but i'll check it out in the morning. I'll let you know how it goes.
  10. Feb 5, 2017 at 9:46 PM
    FirstTimeFirstGen
    FirstTimeFirstGen Less active than most
    David
    Pacifica
    2004 4WD 3.4L Tacoma (Manual)
    Not enough to have a build thread.
    Sounds like a engine related noise under light load. Check all your heat shields and everything driven by the belts. I know 3.4s are supposed to be amazing but check your oil and drain plug for metal if you determine it's inside the engine. Could also be cat rattle. And like @cruiserguy said, check your mounts. Idk how the crank pulley is built, but if it's a 2 piece dampener, maybe the rubbers worn out? Go to harbor freight or a parts store and pick up a mechanics stethoscope. Be careful, they can hurt your ears but use it to find the noise. Or if you have a long screwdriver or pry bar, put it up against whatever you think the noise is coming from and put your ear on the other end. The sound will resonate. It's a poor man stethoscope.
  11. Feb 5, 2017 at 9:58 PM
    Steelhead Huntah
    Definitely could be an engine problem, I've been seeing oil on the bottom end all over. Sometimes splattered on around areas by the starter, oil pan etc. Thanks for the advice!! I let you know how it goes.
  12. Aug 18, 2022 at 7:33 AM
    Dev1nStevens
    Dev1nStevens New Member
    Devin
    1999 Toyota Tacoma SR5 Prerunner 3.4L V6 Extended Cab
    What was the result? I am having same noise while only at idle in drive and slightly worse sounding in reverse.
    No noise in park or neutral. Doesn't happen at cold start but only after hot and driven for a few miles.
  13. Aug 18, 2022 at 9:07 PM
    MadNachos
    MadNachos Well-Known Member
    2000 Tacoma 4WD Base - no low gas warning light but it has AC!
    Broken catalyst rattling around in one of the cats? That can make a racket at certain RPM and it can be temperature dependent.
  14. Aug 19, 2022 at 6:49 AM
    Dev1nStevens
    Devin
    Makes sense, I’m not passing smog (high NOX @ 15mph, yay California) and am being told to replace the cat. Going by my exhaust guy today and will update with solution.
