Metallic Rattle at 50mph
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jimmy44512, Nov 17, 2022.
  1. Nov 17, 2022 at 7:19 PM
    Jimmy44512
    Jimmy44512 [OP] New Member
    Hey there!
    Looking for some diagnostic help with a new metallic sounding rattle. Driving a 2013 Doublecab OR AT with about 105k miles. No lifts or anything. Stock suspension/wheels/etc.
    I'm getting a rattle/tinging sound at 49-50mph. Haven't been able to reproduce the sound at any other speed. It happens at that certain point whether accelerating or off the gas. Seems like it's center of the dash below the floor. It doesn't happen every time I hit 50mph, but most times. Roads are flat where I am as well.
    Have already checked all the heat shields. Drove with the skid plates off and it still rattles. Have tried it in 4wd and gotten the same outcome at the same speed, so that hopefully eliminates it being the needle bearing issue. Wasn't able to find any posts or videos that matched my issue.
    Anyone else out there with this occurance? YouTube video here of the sound
    https://youtube.com/shorts/lDS-cjE5SwA?feature=share
    Thanks!
  2. Nov 20, 2022 at 12:10 PM
    esotaco
    esotaco Well-Known Member
    Ed
    Fairfax, VA
    '13 Silver 4.0L AT SR5 4X4
    I could not tell from the video what I was hearing. However, any idea if your truck has gone through the TSB 44-14 procedure to correct spark knock? It was/is a problem with the 2012-2014 V6 engines. Spark knock will sound like keys rattling. It is unlikely based on your description on the circumstances under which you are hearing the noise in your truck but you can at least eliminate spark knock as a source of the noise. I had the procedure done in 2015. It is a dealer issue that they took care of at no cost. Otherwise, there are far more knowledgeable members on this forum that can guide you as to other things to check.
    Jimmy44512[OP] likes this.
  3. Nov 21, 2022 at 11:55 AM
    Jimmy44512
    That's a good thought - I actually did have that TSB completed a while back as well. It is a bit different noise/circumstance it seems like. Thanks for the reply!
  4. Nov 21, 2022 at 12:47 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Drive 51?:notsure::notsure::notsure:
  5. Nov 21, 2022 at 1:08 PM
    Jimmy44512
    I'll give that one a shot! :thumbsup:
