Metallic rubbing sound at low speed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by greyeyezz, Mar 8, 2014.
  1. Mar 8, 2014 at 11:06 AM
    greyeyezz
    greyeyezz [OP] Well-Known Member
    This just started yesterday. Sounds like the fan hitting a thin piece of metal briefly from 0 to 5mph then disappears. Won't do it once up to speed or accelerating.
    Then I started it this morning, put in reverse and it was quite loud backing up. Almost like a shroud vibrating type sound. I'm stumped.
    07 Tacoma 4x4 Doublecab 4.0
    49,200
    Thanks
    edit:
    I did notice the shroud above the exhaust pipe was a little loose but can't possible see how that could be it.
  2. Mar 8, 2014 at 11:13 AM
    transplant
    transplant resident know-nothing
    theo
    Crestline, Ca
    89 sr5, 99 OR, 11sport, 14 offroad
    i had an acura a long time ago that the heat shield above the cat got loose and would make a sound like youre describing... it was rpm dependent because of the vibration and harmonics. if that thing is loose, tear it off or tighten it up!
  3. Mar 9, 2014 at 1:22 PM
    greyeyezz
    Its the baffle in the Cat converter. This sucks.
  4. Mar 9, 2014 at 1:27 PM
    transplant
    theo
    Crestline, Ca
  5. Mar 10, 2014 at 11:16 AM
    greyeyezz
    Good news its covered under EPA warranty 8 years 80K miles. Dealer has to fix it on their dime.
  6. Mar 10, 2014 at 12:06 PM
    TacoTuesdaze
    TacoTuesdaze Member
    NY
    3" Toytech Lift Steel Front Bumper
    Its the Air Filter housing that is rattling. Had the taco inspected and thats what my mechanic told me. Have a K N air intake system on the way so I haven't tried to dampen it.
  7. Mar 10, 2014 at 9:44 PM
    ssanders2211
    ssanders2211 Well-Known Member
    Midwest
    '14 DCLB 4x4
    behind the rear seat hi-lift mount bracket, easy-out crossbed toolbox brackets, sliders, ATO plate rear bumper, hood/bed lighting, always-on 12v outlets, dashcam, Viper 5806V w/ GPS
    Looks like you found it, but just to add to the list of possible metallic rattling sounds, here's mine: 1999 Tacoma, 240k miles, upstream 02 sensor was loose and rattled because the nuts rusted off. That took forever to find because it only did it under very specific circumstances at first.
