Metalmiller Recovery Shackles. Limited qty
Discussion in 'Buy / Sell / Trade' started by MetalMiller, Dec 10, 2010.
  1. Jan 3, 2011 at 4:52 PM
    MetalMiller
    MetalMiller [OP] Well-Known Member
    Shreveport, La
    Thanks!
    And yessir, I have about 20 powdercoated ones ready to ship.
  2. Jan 4, 2011 at 12:16 AM
    lookylookitzadam
    lookylookitzadam Retrofit Club!
    Adam
    San Diego
    07 DC OffRoad
    that would be an E70xx electrode. OP, I am a structural engineer and deal with steel properties/welding/fabrication all day long. Let me know what materials you are using and i can give you strengths and factors of safety if you need.
  3. Jan 4, 2011 at 7:09 AM
    MetalMiller
    Shreveport, La
    I put in and email to my welder, I'll let you guys know the materials and would definately appreciate you working up a number for me!
  4. Jan 4, 2011 at 1:10 PM
    lookylookitzadam
    Adam
    San Diego
    07 DC OffRoad
    OP, i pm'd you back regarding the information you sent me. If you want me to post it here let me know.
  5. Jan 4, 2011 at 3:00 PM
    MetalMiller
    Shreveport, La
    Please do, I'm sure people would like to see the math on this! Thanks a bunch!
  6. Jan 4, 2011 at 6:22 PM
    lookylookitzadam
    Adam
    San Diego
    07 DC OffRoad
    I am almost sure the welder is going to be using an e70 electrode which is 70ksi minimum rating so it makes sense that it can be a little higher.
    Weld strength is based on size of the weld and length of the weld. I am not sure what weld size you are using, but my guess from the pictures is conservatively 3/8" thick. This provides 5.57 kips/in of weld. (kips = 1000lbs). It seems that total weld length would be 1”+1”+2”+2” since its welded all around the 1” stock. This would give about 33,000lbs of tensile strength. In the weld. Some practices allow for this capacity to be multiplied by 1.5 due to the direction of load being applied perpendicular to the weld direction, however since recovery is seldom accomplished by pulling straight back, I think the 33,000lbs (33kips) would be a good number in terms of weld strength (assuming 3/8” thick weld throat.) If the thickness was 7/16” the capacity would be in the neighborhood of 39kips.
    The 2” stock rated at 70ksi will have a tensile strength of 280kips so that will never rupture in tension. The 1” A36 is a little harder due to the hole, however, assuming that you have a 1” bolt hole, with a 1” bolt bearing on the a36 piece, you would have approximately 36kips of strength out of that piece.
    So in general, you product should work around 30kips assuming the welds are up to par. The limiting piece would be the shackle bolt. My assumption is that the bolt is probably type A325 and 1” in diameter, giving it a shear strength (since it is loaded perpendicular to its direction) of about 30kips.
    Hopefully this gives you some idea into the strengths of the materials. In other words, the welder saying that the truck will break before the shackle is correct. Also note, that these numbers are estimates and are for information purposes only, so don’t hold me to any of these values. LOL. Also let me know if any of my assumed materials are incorrect (shackle bolt in particular).
    -Adam
  7. Jan 10, 2011 at 6:22 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Mine just came today! Looks pretty well built and I already told my old man I can give him a tow when his truck gets bogged down :D
  8. Jan 12, 2011 at 7:37 PM
    MetalMiller
    Shreveport, La
    Great!
    I have plenty more ready to ship out for anyone interested
  9. Jan 13, 2011 at 6:40 AM
    TacoDaTugBoat
    TacoDaTugBoat Well-Known Member
    Goshen, Ct
    13 DCLB TRD Sport
    I am a civil engineer that deals mostly with structures, and wanted to comment that these values are accurate. I have not bothered to do out the calcs to back these up, but all the assumptions are valid. This item is definatly overdesigned. The only way I could see this failing is through a heavy impact load perpendicular to the truck breaking on side of the weld. But you would have to hit it hard and would likely damage the truck also.
  10. Jan 13, 2011 at 7:39 AM
    Pugga
    Massachusetts
    Engineering aside, I dragged out a Dodge Dakota yesterday and a Ford F150 this mornig with this thing so throw away the calcs, I've got 'real world data'. BTW, I'm an civil engineer also, good to see another on this site :cheers:
  11. Jan 13, 2011 at 10:01 AM
    MetalMiller
    Shreveport, La
    Thanks for the positive feedback. I knew these things would hold up, it's still nice to hear it from others!
  12. Jan 15, 2011 at 6:57 PM
    olgzr
    olgzr Well-Known Member
    Denton, Tx
    What is the procedure for ordering one of these? Thanks.
  13. Jan 15, 2011 at 7:36 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Pm Metalmiller
  14. Jan 15, 2011 at 8:00 PM
    olgzr
    Denton, Tx
    Thanks, PM sent.
  15. Jan 15, 2011 at 8:06 PM
    #35
    Drunknsloth
    Drunknsloth Indffrnce will be the fall of manknd but who cares
    Retribution
    South West
    08 SR5 Access V6 6-Speed
    Blacked-Out Badges; Retribution Decals (Sockmonkey); Tailgate Mod; Red LED Rear Blinkers; Yellow Foglights; Yellow Front Blinkers; Superwhite Xenon Corner Bulb; Leer Bedcap; Bedrug Bedmat; Black Cupholders; Black Plastic Piece Around Window Controls; Plasti-Dip Front Bumper Valence; Plasti-Dip Grill Surround; Blackout Chrome Back Bumper; Metal Miller Skid-Plate; Aero Turbine 2525 Muffler; TSB Rear Leaf Springs and Shocks; Satoshi Grill Pending; Off-Roading Torn off Mirror (Replaced); Blue-Sea Fuse Box; Tinted Tail Lights; URD Short Shifter; Interior Mood Lighting; Hood Lights; BedLights Pending
    How many more do you have?
  16. Jan 16, 2011 at 11:20 AM
    #36
    MetalMiller
    Shreveport, La
    I have about 15 left. Just shoot me a pm and ill send one your way. I'm on the road today but will be responding to all pms tonight
  17. Feb 27, 2011 at 12:08 AM
    #37
    TacoMal
    TacoMal Well-Known Member
    California
    09 TRD Off Road Dbl cab
    Wet Okole's, Relentless Sliders, Plasti Dipped badges and wheels
    Any left??
  18. Feb 27, 2011 at 2:44 AM
    #38
    Tepidy
    Tepidy Well-Known Member
    Ted
    upstate NY
    11 tacoma 4x4
    Toytec Coil Overs 3.00" DSM UCA's (Desert Products) TSB 4 Leaf w/AAL by Pro Comp Bilstein 5100 rear 1"ToyTec SwayBar Drops 1" diff drop Detroit Trutrac Rear Diff Nitro 4.56 Gears Doug Thornley Header MagnaFlow Cat Back Exhaust Custom Built Rear Plate Bumper Custom Built Front Plate Bumper 4X Innovations Rock Sliders ATO Front Skid BAMF Rear Diff Skid Uniden 510XL Pro CB Raceline Renegades BF Goodrich Mud Terrains KM2's 265x75x16 WeatherTechs Rear Diff breather Relocate Intake Resonator Removed Yellow Wire Mod
    Hi nice recovery shackle. How about answering my PM concerning the batman emblem I paid for three weeks ago. Is it made if not whats the deal. Thanks-Teddy
  19. Feb 27, 2011 at 11:23 AM
    #39
    JoeTacoma02
    JoeTacoma02 Well-Known Member
    Subbed for future purchase :)
  20. Apr 26, 2011 at 2:22 PM
    #40
    MetalMiller
    Shreveport, La
    I have 10 powdercoated and ready to ship. PM me if interested! I'll sell em on a first come first serve basis.
