Methanol 4.0
Discussion in 'Performance and Tuning' started by White lightning boosted, Jun 15, 2018.
  1. Dec 13, 2018 at 7:38 AM
    #341
    White lightning boosted [OP] Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    Me too. It's rare 3 days go by that I'm not enjoying my hood struts.
    Athlaos and BassAckwards[QUOTED] like this.
  2. Dec 13, 2018 at 7:38 AM
    #342
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Athlaos likes this.
  3. Dec 13, 2018 at 7:39 AM
    #343
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Athlaos and BassAckwards like this.
  4. Dec 13, 2018 at 7:40 AM
    #344
    BassAckwards
    Yeah im in there what seems like everyday. Even if its just to check the oil.. Need to get some of those hood struts. I still have the prop rod
  5. Dec 13, 2018 at 7:42 AM
    #345
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    Would be a sweet way to hide it up out of the view of people who don’t need to see it.
    BassAckwards[QUOTED] likes this.
  6. Dec 13, 2018 at 7:47 AM
    #346
    Jesse
    Poulsbo
    15' DCSB OR S/C
    That's why I like where mine is at. Cant see it until you're in the truck. No sun hitting it either.
    BassAckwards likes this.
  7. Dec 13, 2018 at 7:52 AM
    #347
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    I have this problem sometimes too, although I figure it's more when the tank is 1/3 full.
  8. Dec 13, 2018 at 7:53 AM
    #348
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Bobber needs to have a little more retard in its movement.
    BassAckwards and Athlaos[QUOTED] like this.
  9. Dec 13, 2018 at 7:54 AM
    #349
    Athlaos
    Leigh
    Edmonton
    Keep in mind, if it goes below your fitting level you're kind of screwed. More important for peoples like me who run 12psi and up, but still. Even though the little light can get annoying, I'd rather have that over a bent rod.
  10. Dec 13, 2018 at 7:54 AM
    #350
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    I noticed while researching that aem has a two prong capacitance level switch. Don't know if it's any good but it shouldn't be as erratic as a bobbing float sloshing around in the high seas of your boost juice tanks.
  11. Dec 13, 2018 at 7:56 AM
    #351
    BassAckwards
    Well then.. when you put it that way.. may try and do that this weekend. Did yall have any issues with the rubber gasket sealing things up?
  12. Dec 13, 2018 at 7:56 AM
    #352
    Athlaos
    Leigh
    Edmonton
    I did not have issues with that grommet, no.
  13. Dec 13, 2018 at 7:58 AM
    #353
    Jesse
    Poulsbo
    15' DCSB OR S/C
    No.
  14. Dec 13, 2018 at 8:50 AM
    #354
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    You have the UCON dialed in to account for meth injection, correct? So your open loop is anticipating more octane and would be lean if your meth ran out? For those of us on a fixed TRD/OVtune, would it really be an issue if you accidentally ran out of boost juice while boosting or at WOT....we'd likely still be running rich as the tune is not anticipating any octane increase in open loop. Just thinking out loud here.
  15. Dec 13, 2018 at 9:07 AM
    #355
    Athlaos
    Leigh
    Edmonton
    The UCon corrects for the additional methanol automatically, it runs in closed loop all the time. When I got the UCon, I didn't tell them I was going to run water/methanol injection in the future, then added it later, and the unit compensated immediately to keep AFR on target. So to answer that question, it would automatically adjust the injectors to re-richen so that it will be on-target, should the water/methanol run out. So that is sort of a factor of safety.
    If you were running TRD/OVtune where open loop is still in effect, if you ran out of water/meth it wouldn't be a huge issue if your water/meth injection isn't there for safety. If your boost levels are under about 12psi you'd most likely be safe, especially for street driving. Your knock sensor would help you out and keep you safe too. But since I'm making up to 16psi, there I would not want to run out of water/methanol. Which is also why I'm running two pumps and two controllers, as redundant systems for extra safety.
  16. Dec 13, 2018 at 9:10 AM
    #356
    BassAckwards
    Which two controllers are you using? im guessing the MAF one, but which other one?
  17. Dec 13, 2018 at 9:11 AM
    #357
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Nothing is redundant about preventing rods front being garage wall art.
  18. Dec 13, 2018 at 9:37 AM
    #358
    Athlaos
    Leigh
    Edmonton
    The one that just has a relay activated by boost.
  19. Dec 13, 2018 at 9:40 AM
    #359
    JacksonTacoma
    James
    Jackson, MI
    2015 S/C TRD Pro
    Yeah I guess the only real danger for mild boost setups would be getting a full custom tune with AFRs dialed in and reliant on meth injection to be on target. Boost juice becomes Boom Juice if you run out. It seems there's a bit of a safety net with an overly rich TRD tune, even though there would be some power left on the table.
    Athlaos[QUOTED] likes this.
  20. Dec 13, 2018 at 9:49 AM
    #360
    Jesse
    Poulsbo
    15' DCSB OR S/C
    As I've specifically requested when talking with mat. Not meth mandatory.
    JacksonTacoma[QUOTED] likes this.
