Methanol 4.0
Discussion in 'Performance and Tuning' started by White lightning boosted, Jun 15, 2018.
  1. Dec 20, 2018 at 7:19 AM
    #481
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Did you end up buying the #5 or did it come with your kit too?
  2. Dec 20, 2018 at 7:20 AM
    #482
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    About 10 right now, AEM guage doesn't read below that but it looks like it's not dipping much below.
    BassAckwards likes this.
  3. Dec 20, 2018 at 7:22 AM
    #483
    BassAckwards
    Interesting... are you on OVTune v1 or v2 for the M/T?
  4. Dec 20, 2018 at 7:29 AM
    #484
    White lightning boosted [OP] Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    It came with it. Cant wait to see what it can really do.
    BassAckwards[QUOTED] likes this.
  5. Dec 20, 2018 at 7:36 AM
    #485
    TodayWasTHeDaY
    Russ
    Calgary
    V1 I believe. Just got it a week ago and the way he named his file there's no obvious way to tell what version it is.
    I doubt v2 will be radically different though, it's probably just fine tuned from v1
  6. Dec 20, 2018 at 7:36 AM
    #486
    BassAckwards
    Cool, interested to hear your thoughts on it. It will move some juice
  7. Dec 20, 2018 at 7:38 AM
    #487
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Yes! Now my low level indicator is if my windshield nozzles spray.:thumbsup:
  8. Dec 20, 2018 at 7:39 AM
    #488
    BassAckwards
    Have any pics of how you ran the fitting out of the washer tank?
  9. Dec 20, 2018 at 7:40 AM
    #489
    BassAckwards
    have you heard when the v2 is coming out? I pop in the OVtune thread every once in a while, and it seems like its delay after delay
  10. Dec 20, 2018 at 7:41 AM
    #490
    TodayWasTHeDaY
    Russ
    Calgary
    I think it might be out for auto trans already and supposed to drop anytime for stick.
    Athlaos and BassAckwards[QUOTED] like this.
  11. Dec 20, 2018 at 7:58 AM
    #491
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I dont. Can soon. Its left of the washer pump.
  12. Dec 20, 2018 at 1:48 PM
    #492
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    Where are you getting your 1.8" made? I contacted SmoothFlowPulleys (Nate) but he doesn't seem to like the idea of making them in my size.
  13. Dec 20, 2018 at 1:55 PM
    #493
    TodayWasTHeDaY
    Russ
    Calgary
    I'm guessing there isn't enough meat on a pulley in those sizes that could use the quick change hub.
  14. Dec 20, 2018 at 2:41 PM
    #494
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Just use the hub.
  15. Dec 20, 2018 at 2:50 PM
    #495
    1997tacomav6
    Denver
    I’m having thehighspeedlab make me one.
    Will be a first to see if it’s a go or if it slips.
    Got to try it, I’m running a 2” now.
    We will see
  16. Dec 20, 2018 at 3:06 PM
    #496
    Athlaos
    Leigh
    Edmonton
    Coincidentally Nate just got back to me. He said he’s got a design for one for me. So that’s good.
  17. Dec 20, 2018 at 3:17 PM
    #497
    Kelvin
    Kelvin Wheeeeee
    16’ GX460 with some junk bolted on
    I remember reading about some 4.7 guys with the TRD blower experimenting with smaller pulleys and they all just had major belt slip. Stock is 2.2 so the only other way around it is a overdrive crank pulley.
  18. Dec 20, 2018 at 3:18 PM
    #498
    1997tacomav6
    Denver
    Guess someone has to be the Guinea pig I guess it’s you and me ha ha Ha
  19. Dec 20, 2018 at 3:35 PM
    #499
    Jesse
    Poulsbo
    15' DCSB OR S/C
    If there was a way to have the rotors lightened that should help prevent slip. Less torque on the belt. Carbon fiber would be amazing. I'm sure the cost would be epic as well.
  20. Dec 20, 2018 at 4:04 PM
    #500
    Athlaos
    Leigh
    Edmonton
    2.0" pulley with the 4.0 blower (stock is 3.0") did take a bit of work to get the belt slip down. But if you're smart about it, it can be done.
