Methanol 4.0
Discussion in 'Performance and Tuning' started by White lightning boosted, Jun 15, 2018.
  1. Dec 20, 2018 at 4:38 PM
    #501
    Kelvin
    Kelvin Wheeeeee
    16’ GX460 with some junk bolted on
    Well I’m also less inclined to mess with what’s tried and proven. I’m sure you’re familiar with the weak UZ rods. There is a better belt selection nowadays compared to when that topic was discussed. Also there was a GS430 guy that slapped a m112 onto his car. Went from 6, 8, 10, and then 12 psi is when it let go. He did a 2JZ swap after that.
    Athlaos[QUOTED] and Roostfactor like this.
  2. Dec 20, 2018 at 5:05 PM
    #502
    1997tacomav6
    Denver
    I’m at 6000 feet and run up to 10,000 feet so the air is super thin, if I was at sea level NO WAY would I go that small
    Athlaos and Roostfactor like this.
  3. Dec 21, 2018 at 12:29 PM
    #503
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    Apparently, I'm inclined to mess with it. I get 14psi on warm days and 16psi on cold days.
  4. Dec 27, 2018 at 7:33 AM
    #504
    White lightning boosted [OP] Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    After speaking with the tech at snow&n/x I'm under the impression their nozzle suggestions are rather conservative. Butt dyno tells me a #5 nozzle is a great match with a 2.5 pulley.
  5. Dec 27, 2018 at 7:40 AM
    #505
    1997tacomav6
    Denver
    Your best to get a dyno and then you will know exactly what your numbers are.
    Dyno will tell you the EXACT hp, boost,AFR, numbers.
    Gauges don’t always tell you the whole truth and you can see how accurate the gauges
    are to the DYNO run.
    If your running a little lean or to rich because of the nozzle size you will burn your cats up.
    Roostfactor and BassAckwards like this.
  6. Dec 27, 2018 at 7:41 AM
    #506
    Jesse
    Poulsbo
    15' DCSB OR S/C
    True. IF I had cats:)
  7. Dec 28, 2018 at 7:34 AM
    #507
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Welll.. I blew a 7.5amp fuse on my way to work this morning. Threw a 10amp in there that I had. I will update if it blows that one as well. Seems like it popped during a WOT run this morning when it was cold out..
  8. Dec 28, 2018 at 7:35 AM
    #508
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Good to know. I've never tripped one.
    BassAckwards[QUOTED] likes this.
  9. Dec 28, 2018 at 7:37 AM
    #509
    BassAckwards
    Any idea what size fuse you have in yours?
  10. Dec 28, 2018 at 7:39 AM
    #510
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Probably a 7.5 I've always wondered how such a heavy duty pump ran on such small wires. The instructions never specified anything like a dedicated circuit.
  11. Dec 28, 2018 at 7:41 AM
    #511
    BassAckwards
    I was also wondering why they used such small wires on the pump. That was my logic for using a fuse tap to install mine. It had the same gauge wiring as the pump, so it should be solid(as long as it's fused properly). Im guessing it is just because the pump doesn't run constantly (except for maybe in @Athlaos case because he runs a truck load of meth). I think it's 16 gauge wiring they used iirc
  12. Dec 28, 2018 at 7:55 AM
    #512
    Athlaos
    Leigh
    Edmonton
    I thought it said 20A somewhere in the instruction manual. That's what I have in mine.
  13. Dec 28, 2018 at 7:57 AM
    #513
    BassAckwards
    Interesting... I didn't see anything in the instructions about that. I fused mine based on what the max amperage the wire is able to carry safely. I think 16AWG wire is rated for 10 amps
  14. Dec 28, 2018 at 7:59 AM
    #514
    BassAckwards
    Just read through the stage 2 boost cooler instructions, it does say a 20amp fuse.. seems like the wiring would melt down before it'd ever trip the fuse though.
  15. Dec 28, 2018 at 8:10 AM
    #515
    Athlaos
    Leigh
    Edmonton
    I did some reading on this a while back when I was trying to figure out how much current wires can actually hold... meaning how much safety of factor did engineers put into the "ratings" of various wires. 16ga CAN hold 20A without melting. Temperature of the wire would increase about 30 degrees.
  16. Dec 28, 2018 at 8:11 AM
    #516
    BassAckwards
    Very good to know, makes me feel much better about my wiring..
    Athlaos[QUOTED] likes this.
  17. Dec 28, 2018 at 8:13 AM
    #517
    Athlaos
    Leigh
    Edmonton
    Also the wire itself doesn't melt until like 1200 degrees... so you could theoretically put LOADS more current through the wire. But, the polymer insulation on the wire would melt or burn long before that. So you'd end up with a short circuit, or a fire, at some point before the metal melts. Lol
  18. Dec 28, 2018 at 8:43 AM
    #518
    Athlaos
    Leigh
    Edmonton
    When I was at the dyno hack-tuning the water/methanol, my constant-spray #4 and progressive spray #3 and #5 (simultaneous) seemed hit a sweet spot of power when I adjusted the progressive system to be 2/3 on. That's a weird formula for you to work out there, but I think you get the idea anyway.
    BassAckwards likes this.
  19. Dec 28, 2018 at 8:46 AM
    #519
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Thanks. I'll tinker with it.
  20. Jan 3, 2019 at 9:39 PM
    #520
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Think I'm going to relocate my nozzle to the 76mm adapter plate this weekend. Hesitant about tapping my new afe intake pipe. Thoughts guys?
