Method 703 questions
Discussion in 'Wheels & Tires' started by UpAndOut, Dec 14, 2024.
  1. Dec 14, 2024 at 1:57 PM
    UpAndOut
    UpAndOut [OP] Member
    NY
    2023 TRD Pro White, 2020 SR5 DCSB White
    Hello all-
    Looking to buy my son a gift, set of new wheel/tires for his 2020 SR5, stock suspension, no lift, and has factory mud flaps on.
    He has seen many with the Method 703 on here so likely go with those, 16 inch and I see they are 0 offset. Considering Falken Wildpeak size 265/70/16.
    From what I can tell from searching here should not be any issue with any rubbing, however on TireRack site if I put together package, it gives an alert for "Aggressive Fit, may need lift".
    Can anyone confirm if this set up (Method 0 offset)/size would work/no rubbing on his '20 SR5 stock suspension and with mud flaps?
    And, if anyone with wheels has any photos head on/or from rear to see poke, posting would be appreciated.
    Greatly appreciated-
    Happy Holidays
  2. Dec 15, 2024 at 6:23 PM
    Skim Taco
    Skim Taco Member
    Brett
    Exit Zero NJ
    2019 Tacoma TRD Sport
    I'm looking at the same setup for my truck (2019, stock suspension) and from what I've seen, mudflips will most likely need to be removed. Other than that it clears it fine apparently.
    here is a thread with a picture of stock suspension on 265/70/17 with Method 701 (same offset).
    https://www.tacomaworld.com/threads/method-701s-with-k02s.750702/
  3. Dec 16, 2024 at 3:34 AM
    UpAndOut
    NY
    Thank you, appreciate the info and link
  4. Dec 17, 2024 at 12:49 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    I’d look at 17s. There are more wheel and tire choices .
    BabyBilly likes this.
  5. Dec 17, 2024 at 3:50 PM
    UpAndOut
    NY
    Thank you. Saw that was a popular option. Was a bit worried for same reason as 0 offset with 16s, that maybe stock SR5 with mud flaps may have rub. Not in the market to do a lift on his truck.
