Method lug nuts
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mnewman03, May 27, 2016.
  1. May 27, 2016 at 2:30 PM
    Mnewman03
    Mnewman03 [OP] Well-Known Member
    2016 MGM DCSB TRD OR
    Getting ready to purchase some methods, and I'm now reading that they aren't hub-centric. What lugs do I need to prevent wobbling?
  2. May 31, 2016 at 9:53 AM
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
    You need hubcentric rings if you are concerned with wobble. Very low chance to get a noticeable wobble since truck tires are so large. Just buy matching lug nuts from Method and you should be fine.
    Storman likes this.
  3. May 31, 2016 at 9:55 AM
    nv529
    nv529 Well-Known Member
    Nick
    Metro Detroit, Michigan
    2006 Long Travel Taco, 2010 FJC, 2018 F250 Alumiduty
    I believe you can buy hub-centric rings from method.
  4. May 31, 2016 at 9:57 AM
    Clearwater Bill
    Billy
    Largo Florida
    Are the lugs/lug seats tapered or flat?
    If flat, you need the rings.
    If tapered, you can install the wheels properly and they will behave as lug-centric, no ring needed.
  5. May 31, 2016 at 10:21 AM
    Mnewman03
    I've found a couple other threads of people using ET conical to solve the problem. Thanks for the replies
  6. Mar 26, 2017 at 12:19 AM
    80sforlife
    80sforlife Well-Known Member
    2017 Toyota Tacoma DC TRDOR 4x4
    Would stock lugs work for the Method Double Standard wheels?
  7. Mar 26, 2017 at 12:55 AM
    0210 Well-Known Member
    Vancouver, BC
    2016 TRD Sport Upgrade DCLB
    No, they'll fucking explode and take out a dozen nuns & puppies.
    Did you really need to bump three threads with an identical reply in each?!?
    Ch78 likes this.
