Method nv rims on a 2012 tacoma trd sport
Discussion in 'Wheels & Tires' started by Ktm112racer, Aug 17, 2017.
  1. Aug 17, 2017 at 12:17 PM
    Ktm112racer
    Ktm112racer [OP] Well-Known Member
    Can I fit a 275/70/17 tire on my truck with no lift with method nv rims. They are 17 by 8.5 wide rims and 4.75 back spacing.
  2. Aug 17, 2017 at 12:20 PM
    PapaBear
    PapaBear Never test how deep the water is with both feet.
    Austin
    SIN CITY
    07 DCSB PR 4.0... Aaaand she’s GONE
    Soft Suspension Hard Rubber ®
    Before I did a spacer lift (don't judge, I know the consequences) I was stock. I had the same sized wheels, 17's x 8.5 with the same backspacing. Biggest tire you can fit with minimal rubbing was 265/70/17. YOU WILL RUB ALL THE TIME WITH 275's. Do not get them unless you lift the truck.
  3. Aug 17, 2017 at 12:24 PM
    Ktm112racer
    Where did the 265/70/17 tires rub papabear?
    PapaBear likes this.
  4. Aug 17, 2017 at 1:39 PM
    PapaBear
    Austin
    SIN CITY
    Inner fender closest to the door, rubbed through my mud flaps so I took them off as well. When turning and sometimes switching from an incline to flat surface quickly, they would rub on the front of the fender well while turning the wheel.
