Method Wheels | Ready to order, double check me
Discussion in 'Wheels & Tires' started by Poe, Mar 15, 2014.
  1. Mar 15, 2014 at 12:46 PM
    Poe
    Poe [OP] GOON.
    Michael
    Kentucky
    Ok so i have my tires in 265/75/16 and want some rims to go with.. i found these 2, the size i need to order is 16x8 | 6x5.5 | 0/4.5"
    Is this correct? Which do you guys like best
    NVs
    OR
    Standard
  2. Mar 15, 2014 at 1:00 PM
    Yotski
    Yotski Well-Known Member
    Alex
    Hilo, Hawaii
    13 SSM Access Cab V6 6 Speed 4x4 TRD Off-Road
    Wet Okoles, Toytec BOSS 3in Kit, Allpro Standard Leaf pack, Ext Bilstein 5100, OEM Skid Plate(destroyed), Thule Racks, Method NV, KM2s, Rigid Grille & Light Bar
    Yea thats what I have. Same size rim and tires. I went with the machined NV though. I like the NV easy to clean and different from most other rims.
  3. Mar 15, 2014 at 1:02 PM
    StuckinOhio
    StuckinOhio Well-Known Member
    Mark
    Ohio
    12' v6 AC 4x4 SR5
    Not to scare you but my double standard rim bolts oxidized in a short 2+ months of NE ohio winter / salt exposure. Just giving you a heads up if you drive through salt.
    I am emailing customer service now to see if there is a solution.
  4. Mar 15, 2014 at 1:09 PM
    Yotski
    Alex
    Hilo, Hawaii
    My NV bolts are fine and I live on an island lol. Maybe theyre different.
  5. Mar 15, 2014 at 1:45 PM
    StuckinOhio
    Mark
    Ohio
    12' v6 AC 4x4 SR5
    sea water only contains 3.5% salt.
    Road salt starts out 100% salt. Then get diluted as snow melts
    Road salt formulation includes:
    Sodium cloride
    magnesium
    calcium
    potassium chloride
    Sodium acetate
    calcium
    magnesium acetate
    calcium hydroxide
    I washed my truck weekly to prevent oxidation, didn't help.
  6. Mar 15, 2014 at 2:05 PM
    StuckinOhio
    Mark
    Ohio
    12' v6 AC 4x4 SR5
    OP that is the right size. IMO they both look good! [​IMG]
  7. Mar 15, 2014 at 6:33 PM
    Poe
    Poe [OP] GOON.
    Michael
    Kentucky
    Thanks guys. I am pretty hype about getting some.. i hope mine dont rust but ive narrowed it down to these or xd hoss
  8. Mar 16, 2014 at 10:10 PM
    Agro
    Agro Well-Known Member
    San Diego
    2015 Ford F-150 XLT 3.5L Ecoboost!
    I was looking at getting a set of NVs as well. I am not sure though of size.
    I have 265/70/17 Goodyear Duratracs. I dont know much about wheels and tires, but I believe this is the largest I can go on stock suspension/wheels. I do have 1.5" lift, and wouldnt be opposed to 3" later, but likely not going to go 3".
    not sure what size wheel I need? can I get one that could accommodate a larger tire and not need UCA's and all that?
    This is what I found online:
    TRD Sport Alloy Wheels: 17x7.5, +30 mm offset, 5.5" backspacing, 6x5.5" bolt pattern, 108 mm hub bore
    I dont want to run spacers just to run new wheels.
  9. Jul 6, 2014 at 10:42 AM
    mxchic621
    mxchic621 Well-Known Member
    Yukon Oklahoma
    14 TX BAJA Double Cab 4X4
    Method Double standards 285/75/16 Falken Rocky Mt tires. Toytec front spacer for Baja Suspension. Flush mounts on rear bumper. Past: 2007 TRD_Offroad Ext cab Tacoma 2wd.
    any issues with 16's? did you use spacers? and do you still have plenty or room for the calipers?
