Method wheels
Discussion in 'Wheels & Tires' started by AKTacoParty, Jul 19, 2013.
  1. Jul 19, 2013 at 5:57 PM
    AKTacoParty
    AKTacoParty [OP] Well-Known Member
    Jake
    Seattle
    2013 Limited 4x4 285/70/17's, stock for now
    Okay Im looking at some method racing wheels. This one
    http://www.tirerack.com/wheels/Whee...lse&filterNew=All&filterWeight=All&sort=Brand
    It says a back spacing of 4.72" and 0 offset. Will this fit? Just so I understand it better this will stick out further than say a 5" backspacing? I will be running 265/70's but I want to upgrade later to 285/75's will it work for both tires or am I going to rub? Also anyone with these rims know how big the wholes are for the lug nuts? Will the standard acorn style work or do I need the thinner splined ones? Thanks
  2. Jul 20, 2013 at 12:35 AM
    AKTacoParty
    Jake
    Seattle
  3. Jul 20, 2013 at 9:07 AM
    TacoDeLaPlaya
    TacoDeLaPlaya Total Automotive Performance Sleeper Cell
    Bobby
    Del Mar, CA
    06 Silver Access cab
    Custom sotoshi deep dish grill 6112 front 5100 rear Leer 100xl
    I have stock wheels.
    However i have been researching a lot and anything 5.5 bs or less should work. The zero offset/4.72 bs would be fine and sick out an inch and a half or so farther than stock. I am interested in these wheels in a 16.
  4. Jul 20, 2013 at 9:12 AM
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    I had 4.75" BS 0 OS KMCs and they did not clear the calipers.
  5. Jul 20, 2013 at 9:14 AM
    tostidos
    Apple Valley, CA
    07 LT 6spd
    I also have methods, the standard acorn style works.
    but if you run this wheel with a spacer you will more than likely have to trim.
  6. Jul 20, 2013 at 9:20 AM
    TacoDeLaPlaya
    Bobby
    Del Mar, CA
    16s or 17s?
    What part of the caliper was to close? The spokes of the wheel rubbed or the inside of the wheel rubbed?
  7. Jul 20, 2013 at 9:22 AM
    tostidos
    Apple Valley, CA
    07 LT 6spd
    17's and the spokes rubbed. on the outside of the caliper. Would not mount flush.
  8. Jul 20, 2013 at 11:53 AM
    AKTacoParty
    Jake
    Seattle
    Well I guess its back to the drawing board. Any idea how much it might cost to have rim made to my spec?
  9. Jul 20, 2013 at 12:00 PM
    tostidos
    Apple Valley, CA
    07 LT 6spd
    Shouldn't cost any extra. I got my methods made to spec. Just call a method dealer and they will contact method and have them cut to spec for you. I have 4.5BS -12 OS 6 on 5.5 that I had cut direct from method.
Products Discussed in this Thread
