Metra Dash Kit
Discussion in 'Audio & Video' started by ToyComa92, Mar 18, 2012.
  1. Mar 18, 2012 at 1:06 PM
    ToyComa92
    ToyComa92 [OP] Write your love, Then your anger.
    Jon
    Conifer, Colorado
    2006 Tacoma TRD sport Debadged
    Heated katzskin leather, Black TRD sport wheels, Bilstein 5100s, Toytec 2" Springs, Deaver 2" AAL, Pioneer AVH4400BH, Ultragauge, Weathertechs front/rear,
    For some reason my metra dash kit doesn't want to fit right into my dash, I tried using the four white tabs that came with it and those didn't work, So i took off the four tabs on my factory HU and those worked better but the top still doesn't fit right, Im pretty sure i assembled it correctly? I dont know whats going on with it.
    Also the smaller 20 pin connection from the factory wiring harness, i have nothing to plug into that? Its three wires into a 20 pin, Im assuming i have to splice into it for Mute, Reverse and wired remote input? Or is that where the steering wheel interface adapter would come in? I left that out because im pretty sure i cant do it myself.
  2. Mar 19, 2012 at 12:08 PM
    Ronn
    Ronn Well-Known Member
    Ron
    Northern Ontario
    2007 DCLB 4x4 SR5
    Westin bullbar, KC slimlites, Mini D2S headlight retrofit, 5100 front @ 1.75 and 5100 rear, Wheelers HD leaf pack
    I had to take a utility knife and shave the inside of the tabs down a little so the clips would go onto tabs a little more. IIRC they should click into place. That was my problem, hope this helps you.
  3. Mar 19, 2012 at 3:37 PM
    Sprink669
    Sprink669 Well-Known Member
    I am going to have to try this. My dash kit has never fit correctly.
  4. Mar 20, 2012 at 7:36 AM
    Ronn
    Ron
    Northern Ontario
    2007 DCLB 4x4 SR5
    Just remember to do it a little at a time, if you take too much material off the tab on the dash kit, it will be loose and rattle.
