Metra Dask Kit....Junk
Discussion in 'Audio & Video' started by myke, Dec 27, 2011.
  1. Dec 27, 2011 at 2:26 PM
    myke
    myke [OP] Member
    Alberta, Canada
    08 Tacoma TRD
    So far only a canopy and weathertech floor mats in the mail.
    So i just installed the Alpine INA-W900BT....love the deck!! Everything works beautifully but the dash kit install. I used the factory steel brackets to attach to the dash kit and it seems as though it's about 1/4 to 1/2 inch too far into the cab direction. I was not able to use the Alpine trim ring (which would have made a cleaner look), and the kit just doesn't have a very nice fit/finish. Also the hole for the hazard light is not quite big enough and so when the button is pushed in then pushed back out, it sticks quite bad. The last concern was that with using the factory brackets and the face plate of the Metra kit it was too tight on the bottom of the Alpine unit and it restricted the opening of the DVD player in insert a disc. I had to put some shims between the HU and the brackets so the player would open and close properly.
    So in closing i think maybe i'll order a Schoshe Kit online and see how it works. I was in a rush to get the kit and put it in and i should have ordered online instead of buying it from the electronics store.
    That's just my rant!
  2. Dec 27, 2011 at 2:36 PM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    My Metra works just fine, albeit I'm not using with a double DIN unit. I did have an issue with the first one Crutchfield sent with it not fitting which was due to a defect with it from the factory with the tabs that stick out and snap into the dash. New piece fits great.
  3. Dec 27, 2011 at 2:41 PM
    bridgcat
    bridgcat Well-Known Member
    Alabama
    Mag Grey 4x4 SR5 TRD Offroad
    Avid Off-road Light bar w/ Line-X, American Aluminum Black LP Toolbox, N Fab black step bars,In-Channel Vent Visors, two 10" Rockford subs, Pioneer Double Din DVD player w/ Metra dash kit, 285/65R18 Nitto Trail Grappler MT/s. 18x9" Black XD Monsters. Weathertech digital fit floor mats. Color matched grille with FJ Tacoma badge. De-badged with black, "4x4" badge on tail gate. Mud flap delete mod. Custon TRD decal, color matched rear bumper, Icon extended travel reservoir coilovers, Icon rear reservoir shocks, Dakar rear leaf pack, extended stainless steel brake lines, Camburg uniball upper control arms, timeren bump stops,Beefed Taco carrier bearing drop, Rockford Fosgate Door speakers, Dynomat doors and rear panel, All pro front bumper.
    I hate mine. Damn thing rattles insanely...bugs the hell outta me!
  4. Dec 27, 2011 at 2:41 PM
    TacomaBuzz
    TacomaBuzz Well-Known Member
    CT
    2014 RegCab 4x4 TX Special Edition
    Sirius, Bugflector,back-rack, stepsides.
    Sorry to hear this, I had the opposite experience with metra. I tried scosche and it was very poor quality with cheap,flimsy plastic brackets. Absolute junk.
  5. Dec 27, 2011 at 2:42 PM
    jpneely
    jpneely Well-Known Member
    Charleston, SC
    2011 PreRunner SR5
    very, very stock.
    i think both the metra and the schosche are shoddy at best. but again they are the only option we have sooo you chose the lesser of the two evils IMO. ive tried both and its a tiny bit better than the other so i stuck with it. but they do their job just in a less than perfect way!
    in any other dash kit ive used theyve let me reuse the metal brackets holing up the head unit buuuuuuut i guess that would just make the new dash kits jealous... so yea they wont let you anymore.. (duetche bags)
  6. Dec 27, 2011 at 5:37 PM
    Rellik01
    Rellik01 Well-Known Member
    Craig
    Windermere, Florida
    2012 TRD Sport 4x4 White
    Bull Guard powder coated white, chrome aftermarket tail lights,Led interior lights, Factory roof rack, Bug deflector, Factory tow package, Garmin GPS, Viper 5901 alarm with auto start, Weather tech window wind deflectors, , 3" Tube steps powder coated white, CB Radio, Radio Scanner.
    I have the same head unit and tried both trim kits. Unfortunetly I think it is the HU that is just an off size by the slightest amount. I tried everything and just had to be satisfied that it was straight and level. You can try some window screen spline, comes in black or grey and many sizes, you can then make a "custom trim ring". Sorry I don't have pics but it actually works pretty good. BTW great HU.
  7. Jan 1, 2012 at 5:28 PM
    magnetic10
    magnetic10 Well-Known Member
    Don
    Raleigh, NC
    10' SR5 Double Cab 4x4
    Grillcraft black mesh.
    I cant tell the difference in my metra kit vs stock on mine. Fit is perfect as far as im concerned sorry about your results. :(
  8. Jan 1, 2012 at 5:41 PM
    rexel
    rexel Well-Known Member
    I drilled new holes in the factory brackets to move the deck 1/4" deeper into the dash....looks much better.
