Mevotech LCA, beware..
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hilux30, Mar 15, 2014.
  1. Mar 15, 2014 at 6:06 AM
    hilux30
    hilux30 [OP] Well-Known Member
    PEI
    '15 4Dr SB 6MT
    OTT tune 3 degree cam gear OME/Dobinson
    Bought these just this past summer, had a shop install them along with the weld-in cam-bolt guides that we all love so much. The original arms were fine except for seized cam bolts... that's normal here.
    Passenger side all of a sudden would not retain proper caster at 0 degrees camber to match driver's... weird.
    I drove like this (job allowed no time to fix issue) until just today I installed actual Toyota LC arms at double the price, set the cams back to what I had, amazingly I'm so negative cambered that I have plenty of adjustment room now (with OME 885s, 2.5" lift, Camburg uppers).
    Placing the arms on top of each other, seams something is off but this too crude of a comparison... one bushing was separated, spinning inside the arm, ball joint boots totally torn, and the actual rearward bushings lengths on the Mevotechs were 4-5mm shorter than Toyota's, which caused the ears to bend a little too much, I knew it didn't look right.
    All this time, bolts were torqued to 103ft lbs, this time lubed everything with anti-seize...
    VENTING: This is wHy I have to do my own work: I didn't notice that my so called great mechanic put a tap weld on the Ball joint castle nuts instead of giving me a 0.50 cent pin! Cutting the welds no problem but it will strip the threads... so had to wait for new nutzz
    I know that the lift would stretch the rubber on the ball joints, but the 130K originals were just fine, trust me it's crap rubber. Alignment is eye-balled (not too bad), proper one coming Monday... .
    Crom likes this.
  2. Mar 15, 2014 at 6:12 AM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    That right there would have me bullshit with the mechanic.:mad:
  3. Jan 31, 2017 at 3:55 PM
    Firebird
    Firebird Notorious Member
    Phoenix
    Lewisberry, PA
    1993 FZJ80
    We gave you 1053 days...
  4. Jan 31, 2017 at 5:01 PM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    man you just saved me I almost bought those on Saturday. :thumbsup:
  5. Feb 1, 2017 at 6:36 AM
    hilux30
    PEI
    '15 4Dr SB 6MT
    yeah I never did manage to take them pictures.. Few years and 100K miles later, still on the factory Toyota arms with perfect alignment.... Now in defense of Mevo' I'm still using them once in a while for arms/joints on older simpler cars for customers that understandably refuse factory stuff and/or availability issues. So far so good but 95% we use Moog...
    Firebird[QUOTED] likes this.
  6. Feb 1, 2017 at 7:32 AM
    Firebird
    Phoenix
    Lewisberry, PA
    1993 FZJ80
    I'm using moog lowers. I think I just blew up one of the bushings last night. Less than 5k miles on them...
  7. Feb 1, 2017 at 7:35 AM
    Pigpen
    Dan
    Northwest Montana
    From what I've read the cams break loose from the bolt on the MOOG hardware.
  8. Feb 1, 2017 at 7:42 AM
    DaVikes
    DaVikes Well-Known Member
    Ross
    Denver
    Colorado Sports Car
    Arb front bumper, warn winch, All Pro rear bumper, OME up front, OME and All Pro Standard in Back, ARB locker, 34 x 10.5 KO2's, 17" Level 8 Trackers, and fancy single piece driveshaft.
    Are there any good aftermarket lca's? Getting new lca's w new bushings and ball joints seems like a good idea unless they fall apart.
  9. Feb 1, 2017 at 8:22 AM
    hilux30
    PEI
    '15 4Dr SB 6MT
    I would stick with Toyota arms, online direct suppliers even dealers would have them around $200-$250/ arm.. Remember that final torquing of LCA cam-bolts (100 ft lbs) must be done at normal ride height, not on the hoist/jacks. That way the bushings would twist up and down equally.. If torqued on the hoist, it would sit up a bit higher and bushings rip prematurely rip on the up-swing...
    reallifedog, Stryker420 and DaVikes like this.
  10. Feb 1, 2017 at 12:46 PM
    DaVikes
    Ross
    Denver
    Colorado Sports Car
    Do you know if the Toyota LCA's come with the bushings and ball joint? Thanks
  11. Feb 6, 2017 at 8:01 AM
    hilux30
    PEI
    '15 4Dr SB 6MT
    yes they come with ball joint and bushings installed, I don't think you can buy LCAs for the Tacoma without anything as I have tried... You can buy the bushings and ball joint alone but then you'll need a shop willing to press in/out, not worth it...
  12. Feb 6, 2017 at 9:20 AM
    SethB
    SethB Well-Known Member
    TDY
    **SOLD** 2009 DCLB 4X4 Auto
    OME Suspension, SPC UCAs, ARB Bumper, Smittybilt Winch, Ext Brakelines, SOS Sliders, 4x Innovation Rear bumper
    Completely opposite here. I installed the complete Mevotech supreme LCA's from Rock Auto over 10K miles ago to quickly solve my knocking stock bushings. Absolutely no problems aligning and holding alignment. The difference may be that I do all of my own work, except for alignments, which a trusted shop does for me. With SPC UCA's, no problem getting 3+ caster and 0 camber and toe.
    Stryker420 likes this.
  13. Feb 19, 2017 at 5:45 PM
    Hojae84
    Hojae84 Well-Known Member
    Bedford NY
    2008 dcsb 4x4 sr5
    Curtis home pro, front rear cameras, side blind spot cameras and more
    I installed mevotech lcas 8 months ago and no issues. Alignment is fine, installed myself and torqued bolts at ride height. I did use moog cam bolts which I regret since they failed for many people - they are holding up ok tho.
  14. Jan 17, 2019 at 8:05 AM
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    Do either of you have these Mevotech arms still on your truck? How are they holding up? Also which PN's did you use? I am finding the MEVOTECH CMS861038/9 and the MEVOTECH CMS861042/3 with different prices.
    Looking for some decent aftermarket LCA's. I was looking at Moog but it seems like more people have had issues with them recently. Any input is helpful. Thanks
    Edit: Looks like one uses blue boots on the LBJ's and the other uses black boots.
  15. Jan 17, 2019 at 9:35 AM
    boostedka
    James
    NM
    After doing more research it looks like it's the Mevotech MS861038 and MS861039. The other ones look different in every picture I can find. I'l trying to figure out if these or Moogs are better than each other. They look exactly the same in online pics :notsure:
  16. Jan 17, 2019 at 9:59 AM
    abqnurse80
    abqnurse80 Well-Known Member
    Nic
    ABQ, NM
    2012 FJ Cruiser
    Bilstein 5100 all around, first clip front. AVS window visors, BFG AT KO2s. JBL.
    Just ordered
    MEVOTECH CMS861038
    MEVOTECH CMS861039
    To install while I poly my stock ones and redo ball joint.. have heard good things, and will post when I get them installed, hopefully within a week!!!
    boostedka likes this.
  17. Jan 17, 2019 at 10:18 AM
    boostedka
    James
    NM
    Where'd you end up ordering them from? I keep looking at those, Moog's and Dorman's. They all look the same. :annoyed: I can't decide
  18. Jan 17, 2019 at 10:22 AM
    abqnurse80
    Nic
    ABQ, NM
    2012 FJ Cruiser
    Got mine from Rock Auto, cheap!! I know they all start looking the same... Again, I'm not sure about the quality, but for $200, can at least be up and driving, my lca bushings are toast, and I'm not sure about the energy poly upgrade, but that'll be another time. Moogs seem ok I suppose, you see a lot of opinions on here. Figured time to try the mevos!!!
  19. Jan 17, 2019 at 4:04 PM
    boostedka
    James
    NM
    I ended up going with Dorman LCAs. They seemed to be the one arm I couldn’t really find any real negative comments about.
    I got them through JCWhitney. They are $101 each and they have a 15% off coupon if you sign up for text message alerts.
    waterlogged77 likes this.
  20. Jan 18, 2019 at 5:46 AM
    SethB
    TDY
    Still have Mevotech Supremes, over 35K on them and they are GTG. Get them from Rock Auto, like $185 for the pair. They are pre-loaded with poly bushings so they will outperform the other aftermarket LCA's.
