Michael's NorCal Tacoma on 35s Build
Discussion in '1st Gen. Builds (1995-2004)' started by MichaelsTacoma, Jun 14, 2017.
  1. Apr 3, 2022 at 8:54 PM
    #221
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    Rad! Must be an older camburg kit. +2.5?
    Looks like it could use some skids too
    Dalandser likes this.
  2. Apr 3, 2022 at 9:02 PM
    #222
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Would be a 3.5" over
  3. Apr 3, 2022 at 9:06 PM
    #223
    MichaelsTacoma
    MichaelsTacoma [OP] Well-Known Member
    Michael
    Sacramento
    00 TRD 4wd e-locker
    donahoe racing coilovers, Camburg upper control arms, rear bilstein 5100, wheelers leaf pack, wheelers super bumps, 33 inch Cooper discovere stt pros
    3.5 camburg kit. Could definitely use some skid plates.
  4. Apr 3, 2022 at 9:50 PM
    #224
    betterbuckleup
    Ian
    Concord, CA
    Nice. Doesn't look that wide which is nice
  5. Apr 3, 2022 at 11:12 PM
    #225
    MichaelsTacoma
    Michael
    Sacramento
    00 TRD 4wd e-locker
    I agree doesn’t look wide. It has pretty big fender flares on it. The stock rims also don’t poke out much. If the flares were off it has about half a tire outside the fender. The rear has 1.5” wheel spacers as well. Once I change rims hopefully it’ll look a bit wider.
  6. Apr 3, 2022 at 11:56 PM
    #226
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Is it a cruising rig or are you building it to do the same kind of stuff as your 1st gen?
  7. Apr 4, 2022 at 9:51 AM
    #227
    MichaelsTacoma
    Michael
    Sacramento
    00 TRD 4wd e-locker
    Similar stuff to the 1st gen. But this one can take my family out. Cruising, trail riding, some rock crawling.
    jubei likes this.
  8. Apr 4, 2022 at 9:58 AM
    #228
    DoubleC
    DoubleC Well-Known Member
    Christian
    Oxford, MS
    1999 Tacoma 3.4 TRD (Natural White - the best white)
    What tire size (metric) were you at in this picture and how did you fit them (i.e. had you tubbed the firewall yet?) Also nice build!!
  9. Apr 4, 2022 at 11:23 AM
    #229
    MichaelsTacoma
    Michael
    Sacramento
    00 TRD 4wd e-locker
    Thanks man. I believe I was on 33s in those photos. They fit with just my lift and and some hammering on the pinch weld.
  10. Apr 4, 2022 at 2:18 PM
    #230
    DoubleC
    Christian
    Oxford, MS
    I gotcha man. One more question. I'm gonna move up from 32s to 33 skinnies soon, how much hammering did you need on the pinch weld? And how far up the pinch weld did you go from the bottom?
  11. Apr 4, 2022 at 2:37 PM
    #231
    MichaelsTacoma
    Michael
    Sacramento
    00 TRD 4wd e-locker
    It’s been a while but it’ll depend on your wheel offset. I had to hammer and trim some with a grinder but not to much.
  12. Apr 4, 2022 at 8:31 PM
    #232
    DoubleC
    Christian
    Oxford, MS
    I’m gonna be running skinnies on 00 offset so probably not too much. Thanks man nice build!!
