Michelin Defender LTX MS replaced BFG KO2's
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ChrisK7UND, Jun 4, 2017.
  1. Jun 7, 2017 at 9:22 AM
    #61
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    Right. It's not a tire model in the current line up.
  2. Jun 7, 2017 at 11:23 AM
    #62
    tguil
    tguil Well-Known Member
    Nebraska
    2018 Double Cab TRD Sport 4X4 AT
    For a more aggressive tire and a more aggressive look, get the LTX A/T 2s. Almost the same tire wear. Actually better wear on gravel. Still good on highway. I have had both on my Rams and my wife's Tacomas and prefer the AT 2.
  3. Jun 7, 2017 at 11:25 AM
    #63
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    I use LTX M/S on my 4runner exclusively (and offroad that thing a f*kton)
    and AT/2 on Trucky.
    When my AT/2 wear out, I am going for M/S on it, too.
    all I can figure out from the two tires is....I cannot figure out a difference!!!
    except maybe the AT/2 pulls me through frozen corn snow better ??
    TejasTaco likes this.
  4. Jun 7, 2017 at 4:08 PM
    #64
    bowtechjoe
    bowtechjoe Active Member
    North Carolina
    2015 Pyrite Mica trd off road DC
    weather tech mats, SCS SR8 wheels, 5100's w/885 coils, aal in rear
    Question for you guys running the Defenders. I currently run the BFG KO2 and was thinking of switching to these tires, but my concern is the off road ability. not like rock crawling but I farm part time with my dad and do a lot of hunting. How do these tires do on muddy farm paths, fields things like that? one spot I contend with is a pretty good slant that gets like greasy/slick mud around a field even with the KO2 I slide down towards the drainage ditch unless in 4wd and moving pretty decent seed. Thanks in advance
  5. Jun 7, 2017 at 5:23 PM
    #65
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    you'll need to keep some speed.
    you are maybe better off with something knobbier on the sidewalls
    if you do muddy fields a lot. if you stop you may sit there trying to get out
    or need to air way down
    then again, the BFG blocks are so big they float you up...
    the deep grooves in the M/S help dig in and can pull you through
    more than you think...
    bowtechjoe[QUOTED] likes this.
  6. Jun 7, 2017 at 5:43 PM
    #66
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Check out the tread on the LTX AT (Google). It's a little more aggressive than the LTX MS, but likely possesses some of the same benefits.
  7. Jun 7, 2017 at 5:50 PM
    #67
    TheCookieMonster
    TheCookieMonster cookies!!!!!!!!!!!
    North East
    1995 Hi Lux 22re 4x4 5speed
    Michelin MS2 K&N drop in filter
    big box stores,Costco, BJs wholesale,if you want to save a few more dollars get the Michelin X Radial LT2 its the same tire made for BJs wholesale stores.
  8. Jun 7, 2017 at 6:01 PM
    #68
    TejasTaco
    TejasTaco Grab a taco
    Ditto. Had them on my prior Tacoma. Seemed like the proper balance between pavement and dirt. Definitely going to Costco for some Michelins when I wear the OEM Goodyears down.
  9. Jun 7, 2017 at 7:06 PM
    #69
    Guerrilla
    Guerrilla L(.)(.)K@G(.)(.)Dz
    D. Cooley
    Coast to Coast
    El' Black 13 DCSB 4x4
    Stuff
    With all of that siping, they oughta be a great wet/winter tire.
  10. Jun 8, 2017 at 11:57 AM
    #70
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    These are the LTX M/S2's that came on the truck from Toyota.
    SilverII and DesertTaco4x4 like this.
  11. Jun 8, 2017 at 4:14 PM
    #71
    Steve Urquell
    Steve Urquell No Pants
    2017 2.7L/5MT AC Utility 4X4
    I've lived down 1.5 miles of Arkansas flint road for 17 years. It cuts the hell out of cheap tires at about 1/2 tread life. Defenders are the only tire that will run all the way down to the wear bars so they last ~3X longer than any other tire for me as they wear longer too.
    They also made my last truck (a 94 Ranger) much safer to drive as it was terrible in the rain. It was stuck well after putting defenders on. I've had a couple of instances in my new truck with sliding on wet roads with the factory Hankooks. I figure they'll get cut up at 1/2 tread and I'll replace with defenders. They are the best tires I've run.
  12. Jun 14, 2017 at 7:37 AM
    #72
    Doc Hallows
    Doc Hallows Member
    2016 Toyota Tacoma TRD Off Road
    Anyone have a set with the FX Pro wheels?
  13. Jun 14, 2017 at 8:00 AM
    #73
    6172crew
    6172crew Well-Known Member
    New Mexico
    4X4 TRD sport
    My Truck has both, pic is up in the for sale section. White MT TRD sport.
  14. Jun 14, 2017 at 8:02 AM
    #74
    TejasTaco
    A direct link would be beneficial.
  15. Jun 14, 2017 at 8:03 AM
    #75
    6172crew
    New Mexico
    4X4 TRD sport
    I am not selling the truck in this thread, go look at it if you want to see it.
  16. Jun 14, 2017 at 8:04 AM
    #76
    BallsDeep09
    BallsDeep09 Well-Known Member
    '16 DCSB TRDOR 6 spd.
    Excellent tires, I have em on my rig as well!
  17. Jun 17, 2017 at 9:50 AM
    #77
    ChrisK7UND
    ChrisK7UND [OP] Well-Known Member
    Colorado
    2017 Tacoma TRD Sport Double-Cab
    LED Interior Bulbs, Hondo Garage Phone Mount, Tacoma Bed Mat
    I am still impressed with the mileage gains since going back to stock size NON-KO2's. This was a 20 minute trip mixed driving yesterday. With my KO2's I was lucky to get 17.
  18. Jun 17, 2017 at 11:20 AM
    #78
    AGLAT
    AGLAT Active Member
    Treasure Island, FL
    2017 MGM TRD Sport DCSB 2WD
    OME w/ 887 coils + LR UCAs, rear OME w/ 2" blocks Fuel Maverick 20x9 +1mm, Michelin LTX 305/50R20, RBP RX-3 steps
    I'm running the 305/50R20 Michelin Defender LTX M/S tires and I am very happy with them. They are lighter weight than other tires this size, and they are extremely quiet and awesome in the rain.
    They are sized more like a 285/55R20 tire if you compare the dimensions, and they tuck in perfectly on a set of 20x9 wheels with 0 offset..
    --AGLAT
  19. Dec 30, 2018 at 12:35 PM
    #79
    Brad88
    Brad88 Member
    2015 Tacoma Sport TRD Double Cab
    Hello I came across this post and wonder if you can please help clarify whether my tires will fit on my rim as it appears to be the same set up that some of you have? Although I cannot see the size clear enough in the photos.
    I recently bought a 2015 Tacoma TRD sport Double Cab with stock 17 inch rims that are 17 x 7.5 wide. It has Cooper tires on it now they are the Stock size P265/65R17 but I want to change them as I find them noisy and also not the best for fuel mileage. I drive 99 percent on paved roads and rarely ever venture elsewhere. I bought a set of TRD Sema pro wheels in Graphite and they are 17 x 7". Picture Attached, I want to buy a set of Michelin Defender LTX M+S and use the TRD Pro Rims. Are you using the stock size Michelin P265/65 R17 Tires on this same size and width rim? My concern is Michelin's website says rim width range for that size tire is:
    7.5-9.5".
    Will I have issues with the 7" wide TRD Pro Sema Rims PTR20-35110-GR with the stock sized Michelin Tires listed above? Is that what size some of you are running on same 17 x 7" wide rims?
    I do not want to go to a larger size or different tire, I had Michelins on my last truck and liked them more than any other tire I have purchased.
    uwhusky12 likes this.
  20. Dec 30, 2018 at 12:47 PM
    #80
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Perfect tire for a Sport. But, I'll stick with my Duratrac's for the Off-Road. The Kevlar's that came with it should have probably gone on a Sport.
    Flash1034 likes this.
