Michelin LTX A/T 2 E
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gsxr1959, Dec 6, 2011.
  1. Dec 6, 2011 at 10:57 AM
    gsxr1959
    gsxr1959 [OP] New Member
    08 4X4 TRD OR
    K&N 63, Magnaflow, Weathertech, Red Line Hood Struts, 5100 front 1.75 and rear TSB
    Anyone running the "E" load range? Any issues with ride performance or handling with 80 psi? I'm interested in upgrading to 265/75/16, tire rack only has the E.
  2. Dec 6, 2011 at 11:01 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Unless you off road or haul excessively, load range E is overkill. Even if you do get the E's, you will not need 80 PSI in them, it will ride like a hay wagon. For every day driving, you'll probably only need about 1/2 that. If it were me, I would not run load range E on a Tacoma unless the extra plys were needed for off roading. They are also very heavy and will sap your gas mileage. That being said, lots of people here are running that load range and mechanically there's nothing preventing you from doing so.
