Michelin LTX A/T2 or LTX M/S2
Discussion in 'Wheels & Tires' started by MJonesTrumpet, Aug 3, 2010.
  1. Nov 22, 2015 at 12:13 PM
    #361
    JohnNP
    JohnNP ForeRunners Future Wife :)~
    Hobe Sound, FL
    2014 DCSB 4x4 TRD Sport JBL
    As of 11/4/15 1) Tailgate Anti-Theft Mod 2) ND4SPDBP's Fog Light Mod 3) Devil Horn Emblem 4) Weathertech Digital Floor Liners 5) ADD W-1 Vers 2 Baffled Oil Catch Can- constantly surprised at how much oil this thing captures 6) Weatherproof Under the rail LED bedlights Warm White (by Mattgecko) with hidden small cubby switch 7) Sliding Window Security Bar 8) Hood Lighting Kit Warm White /Pro Kit (by BeeRad) 9) Morimoto mini D2S retrofit HID lights w/ 55W ballasts and XB 5000k bulbs from TRS- one of the best modifications I have ever made, blows the stock lights out of the water 10) ImMrYo bracket 11) Scangauge II 12) Autodimming mirror w/ Compass/Temperature/Homelink 13) Bedrug Mat and Tailgate rug. 14) Pop n Lock Power tailgate lock w/ bolt coded to factory key. 15) Map Light w/ Door Mod 16) BakFlip HD Tonneau Cover 17) 35% Front windows ceramic tint - a very good match to factory 19) Gerber machete, because every truck needs a machete 20) Various flashlights, really love my Black Diamond Miner Mole Headlamp 21) AFE Pro Dry drop in filter 22) removed secondary charcoal air filter 23) Back up light Mod- I used the light bulb as found on page 14, 35W from Lowes. https://www.tacomaworld.com/threads/886-backup-light-mod.209578/page-14 24) Hi-Lift Off Road Recovery Kit- thank you TW Secret Santa 25) Tailgate Seal 26 interior footwell/rear seat dome light controlled LEDS https://www.tacomaworld.com/threads/footwell-and-rear-seat-led-light-dome-switched-mod-lots-of-pics.409428/#post-11529460 27) pelfrybilt aluminum front skid 28) morimoto XB fog lights 29) mob town front recovery bar with 2 Smitty bilt D-Rings 30) 48" Extreme Hi-Lift Jacks w/ ATO rail mounts 31) Prinsu rack 32) Rigid D2 Ditch lights 33) 40" Heretic LED bar on Prinsu Rack 34) Kawell x 6 side lights 2 spot and 1 wide per side 35) Rigid SRQ2 x 2 rear facing asshole/backup lights 36) NSA switch panel to 150amp bussman fuse on custom made mount 37) 267/70/17 BFG KO2's in C rating Pending installation 1) Rock Lights Upcoming/Possible Mods 1) Katzkin Leather Seats in black/ice grey (supposedly better factory match for the 2014) w/ Degreeze heater/cooling and TRD stitched into the seat faces thru jhuey - once I get to Arizona will buy them and have him install them 3) Total chaos UCA's 4) Kinda want to get some of the 2016 TRD Sport Rims or the grey TRD wheels the FJ cruiser/4Runners have. 5) BAMF LCA Skids 6) ICON or KING coilover 8) BAMF hidden grill light mounts 9) 20" or 30" LED light by Rigid Industries for behind the Grill. . 10) full leave pack maybe the Deaver 10 leaf set 11) ? Warn m8000 winch- really depends on if I end up doing more off roading 12) Possibly a console vault, not entirely convinced those are as secure as they would have you believe.
    I wanted to be able to go off road and not worry about sidewall damage as much. Have you gone on the trails like Socar has pictures of in your P rated tires as well? Have you been in a truck with the E's by chance?
  2. Nov 22, 2015 at 12:15 PM
    #362
    Mush Mouse
    Mush Mouse Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
    no I live on East coast but have been on trails much like Socar pictures minus the Cactus, definetly get the P Rated you will not like the E rated tire it would be like driving on cinder blocks
    Cmurder likes this.
  3. Nov 22, 2015 at 12:26 PM
    #363
    JohnNP
    Hobe Sound, FL
    Hrmmm.....ha yeah not so worried about cactus (western dudes....should I be?). It was more about the sidewalk. I really don't want to have a sidewalk blow out. I know hypoxic has E's and has mentioned they don't ride harsh like the other E's he's been in before. It's funny people's experiences with these things. I do appreciate your input though. I will certainly give the P's adequate consideration given your warning.
    Mush Mouse[QUOTED] likes this.
  4. Nov 22, 2015 at 12:40 PM
    #364
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    In 40k miles they should be about 1/3 worn and perform exactly as they do now :thumbsup:
    JohnNP and hetkind[QUOTED] like this.
  5. Nov 22, 2015 at 12:43 PM
    #365
    Mush Mouse
    mush
    2013 SR5
    I would not get E rated tires they are way overkill for a light duty 1/2ton truck and a DD
  6. Nov 22, 2015 at 5:01 PM
    #366
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    I live off gravel road, off a gravel road in the Cherokee national forest...these tend to pack the gravel instead of spinning gravel. I don't need to look for poor quality roads, I drive them daily.
    Howard
    JohnNP[QUOTED] likes this.
  7. Nov 22, 2015 at 5:03 PM
    #367
    teamhypoxia
    Colorado
    '12 DCSB TRD OR
    Have you had a set of E rated LTX?
  8. Nov 22, 2015 at 6:17 PM
    #368
    Mush Mouse
    mush
    2013 SR5
    no I never had a need for E rated tires since I don't carry heavy loads that would require a 10 ply tire
  9. Nov 22, 2015 at 6:22 PM
    #369
    Mush Mouse
    mush
    2013 SR5
    never had E rated tires,they are used primarily for carrying very heavy loads and are 10 ply as opposed to a 2 ply P metric which are used as an all around tire. I know this if you buy a 10 ply tire the ride and comfort will be sacrificed by the stiffer tire not ideal situation if the truck is a daily driver,if its a workhorse hauler than I guess it would be good.
  10. Nov 22, 2015 at 6:29 PM
    #370
    Mush Mouse
    mush
    2013 SR5
  11. Nov 22, 2015 at 6:46 PM
    #371
    JohnNP
    Hobe Sound, FL
    Thank you Mush, I read the pages. There were some rather good points on both sides for the E vs P argument. :) I noticed one of the guys mentioned putting ICON coilovers on at the same time as an E rated tire and really liking the ride. I was myself planning on doing an ICON coilover setup :)
    I appreciate yours and everyone else's help with my decision. About the only thing for sure is I'm getting michelins lol :)
  12. Nov 22, 2015 at 7:56 PM
    #372
    teamhypoxia
    Colorado
    '12 DCSB TRD OR
    I can tell you from personal experience that an E rated LTX rides much better (empty truck) than the Rugged Trails that came on the truck. I could be wrong, but I'm guessing those were P rated?
  13. Nov 23, 2015 at 6:50 AM
    #373
    Mush Mouse
    mush
    2013 SR5
    anything rides better than Rugged Fails, if you match a P rated LTX versus a E Rated LTX of basically the same size the P rated gives better all around comfort and performance while the E Rated wins with carrying very heavy loads and has thicker skin 10 ply and wont ride or have the handling characteristics of a P rated.
  14. Nov 23, 2015 at 6:53 AM
    #374
    Mush Mouse
    mush
    2013 SR5
    Good luck cant go wrong with Michelins
  15. Nov 23, 2015 at 12:34 PM
    #375
    teamhypoxia
    Colorado
    '12 DCSB TRD OR
    I guess this quote is why I asked if you'd ever actually had any E rated michelins....
    I will admit that I've never driven on cinder blocks, but I have to imagine that it's quite unlike the ride I get from my michelins :D
    I know you read a bunch of stuff about tire ratings but I can tell you that whatever michelin does in the manufacturing of these ltx tires results in an incredibly plush ride. even with E rated tires.
  16. Nov 23, 2015 at 12:53 PM
    #376
    NMTrailRider
    NMTrailRider Well-Known Member
    New Mexico
    I'm about to go in for my 2nd set of MS2's. Still debating 245/75 vs 265/75... Currently on the 245's.
  17. Nov 23, 2015 at 1:17 PM
    #377
    Mush Mouse
    mush
    2013 SR5
  18. Nov 23, 2015 at 1:20 PM
    #378
    Mush Mouse
    mush
    2013 SR5
  19. Nov 23, 2015 at 6:16 PM
    #379
    rcsb jon
    rcsb jon Well-Known Member
    Pittsburgh
    '17 Ridgeline RTL-T | AWD | White | Ebony
    -WeatherTech liners
    Narrower is always best for snow/ice. Narrower tire provides more pressure on the contact patch. A wider tire provides less pressure on the contact path, thus reducing traction on snow/ice. You want to penetrate the snow/ice/slush/muck, not float on it.
    NMTrailRider[QUOTED] likes this.
  20. Nov 25, 2015 at 12:04 AM
    #380
    NMTrailRider
    New Mexico
