Michelin LTX A/T2 or LTX M/S2
Discussion in 'Wheels & Tires' started by MJonesTrumpet, Aug 3, 2010.
  1. Jan 8, 2016 at 2:51 AM
    #441
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    I am running P265/75-16 at 36 psi with good success, but only have put 5k or so miles on the tires...I am also running P265/70-17 as WINTER tires using a set prerunner SPORT alloy rims I got cheap.
    NMTrailRider[QUOTED] likes this.
  2. Jan 17, 2016 at 6:27 PM
    #442
    JohnNP
    JohnNP ForeRunners Future Wife :)~
    Hobe Sound, FL
    2014 DCSB 4x4 TRD Sport JBL
    As of 11/4/15 1) Tailgate Anti-Theft Mod 2) ND4SPDBP's Fog Light Mod 3) Devil Horn Emblem 4) Weathertech Digital Floor Liners 5) ADD W-1 Vers 2 Baffled Oil Catch Can- constantly surprised at how much oil this thing captures 6) Weatherproof Under the rail LED bedlights Warm White (by Mattgecko) with hidden small cubby switch 7) Sliding Window Security Bar 8) Hood Lighting Kit Warm White /Pro Kit (by BeeRad) 9) Morimoto mini D2S retrofit HID lights w/ 55W ballasts and XB 5000k bulbs from TRS- one of the best modifications I have ever made, blows the stock lights out of the water 10) ImMrYo bracket 11) Scangauge II 12) Autodimming mirror w/ Compass/Temperature/Homelink 13) Bedrug Mat and Tailgate rug. 14) Pop n Lock Power tailgate lock w/ bolt coded to factory key. 15) Map Light w/ Door Mod 16) BakFlip HD Tonneau Cover 17) 35% Front windows ceramic tint - a very good match to factory 19) Gerber machete, because every truck needs a machete 20) Various flashlights, really love my Black Diamond Miner Mole Headlamp 21) AFE Pro Dry drop in filter 22) removed secondary charcoal air filter 23) Back up light Mod- I used the light bulb as found on page 14, 35W from Lowes. https://www.tacomaworld.com/threads/886-backup-light-mod.209578/page-14 24) Hi-Lift Off Road Recovery Kit- thank you TW Secret Santa 25) Tailgate Seal 26 interior footwell/rear seat dome light controlled LEDS https://www.tacomaworld.com/threads/footwell-and-rear-seat-led-light-dome-switched-mod-lots-of-pics.409428/#post-11529460 27) pelfrybilt aluminum front skid 28) morimoto XB fog lights 29) mob town front recovery bar with 2 Smitty bilt D-Rings 30) 48" Extreme Hi-Lift Jacks w/ ATO rail mounts 31) Prinsu rack 32) Rigid D2 Ditch lights 33) 40" Heretic LED bar on Prinsu Rack 34) Kawell x 6 side lights 2 spot and 1 wide per side 35) Rigid SRQ2 x 2 rear facing asshole/backup lights 36) NSA switch panel to 150amp bussman fuse on custom made mount 37) 267/70/17 BFG KO2's in C rating Pending installation 1) Rock Lights Upcoming/Possible Mods 1) Katzkin Leather Seats in black/ice grey (supposedly better factory match for the 2014) w/ Degreeze heater/cooling and TRD stitched into the seat faces thru jhuey - once I get to Arizona will buy them and have him install them 3) Total chaos UCA's 4) Kinda want to get some of the 2016 TRD Sport Rims or the grey TRD wheels the FJ cruiser/4Runners have. 5) BAMF LCA Skids 6) ICON or KING coilover 8) BAMF hidden grill light mounts 9) 20" or 30" LED light by Rigid Industries for behind the Grill. . 10) full leave pack maybe the Deaver 10 leaf set 11) ? Warn m8000 winch- really depends on if I end up doing more off roading 12) Possibly a console vault, not entirely convinced those are as secure as they would have you believe.
    I'm assuming those are the LTX rated Defenders?? How are they so far? Very curious about these tires.
  3. Jan 17, 2016 at 11:11 PM
    #443
    NMTrailRider
    NMTrailRider Well-Known Member
    New Mexico
    Yup. I got the P-rated version (38lbs/each). I think they're called "Defender LTX M/S". They're great. I can tell that the size is different while driving. But other than that, they feel/ride/sound just like my MS2's. Tread is nearly, if not, identical to the MS2. They're supposed to be everything that the MS2 is. But with slightly better wet/snow traction.
  4. Jan 17, 2016 at 11:22 PM
    #444
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    Don't get 70 - get 75's.
    here are a few pics with 32" MS2's from my stock suspension days:
    And after my lift:
    JohnNP likes this.
  5. Jan 17, 2016 at 11:34 PM
    #445
    NMTrailRider
    New Mexico
    Already got the 70's. But thanks for the pics! I actually sit higher with the 265-70s than I did on the 245-75. Obviously not much higher, but noticeable.
  6. Jan 18, 2016 at 8:49 AM
    #446
    JohnNP
    Hobe Sound, FL
    I'm still struggling with the whole P vs E debate. Grrrrrrrrrrrrr
  7. Jan 18, 2016 at 9:05 AM
    #447
    neverstuck
    Guido
    Lebanon
    13 DCLB sport
    If you tow or haul heavy loads and want more stability (less sidewall flex), if you do much off-roading or travel on crushed/broken rock secondary roads, or if you just really want excellent flat tire protection get the LT. You won't notice much difference in MPG's. The only significant benefit to P rated tires is you can run them with less air and they offer a much softer ride. It's worth also mentioning that the LT tire usually comes with significantly deeper tread to start which means they will last longer.
    NMTrailRider and JohnNP[QUOTED] like this.
  8. Jan 18, 2016 at 11:28 AM
    #448
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
    The P rated tires ride very, very nice and I towed my loaded snowmobile trailer 500 miles the other day with no problem.
  9. Jan 18, 2016 at 12:08 PM
    #449
    NMTrailRider
    New Mexico
    Agreed. I really like my P's. Super smooth and quiet. Rides like a car for the most part. When I air up to 36+ it stiffens up considerably. Too stiff for my likes on such a little truck. So, I can imagine how stiff the LT's must be. I also tow a small fishing boat and frequently carry several hundred pound loads in the bed (dirt, wood, etc). No problems at all.
    Highplainsdriftr likes this.
  10. Jan 20, 2016 at 1:19 PM
    #450
    MCObray
    MCObray Well-Known Member
    Oregon
    2002 Toyota Tacoma DC TRD
    Well this thread solidified my tire decision... especially since I just put a set of 265/70/16 Michelin LTX A/T 2s on order... if whatever reason I do not like them in the coming weeks, I will in all likely swap to the M/S 2s. Will an alignment be necessary after installing new tires...? I've never done one after added new tires to my previous 3rd Gen 4Runners.
    My newly acquired Tacoma DC is my primary daily driver, but have plans to do a little off road exploration here in Oregon. I was contemplating going all in with 2" OME lift, ARB Bull Bar, etc. but have decided to postpone those modifications for the coming year or so at least... which in all likely I would've gone with a 265/75/16 in the load range C - E flavor to accommodate the added weight
    I am stoked to get these tires on and put 'em through there paces. I'll post up pics when I get them installed at my local Discount Tire.
    JohnNP likes this.
  11. Jan 20, 2016 at 4:51 PM
    #451
    NMTrailRider
    New Mexico
    These are my new Defender LTX MS in a 265-70-16. Stock suspension.
    2015WhiteOR, karmatp and JohnNP like this.
  12. Jan 20, 2016 at 5:05 PM
    #452
    JohnNP
    Hobe Sound, FL
    No alignment required. ;).
  13. Jan 20, 2016 at 5:06 PM
    #453
    JohnNP
    Hobe Sound, FL
    You loving them still
  14. Jan 20, 2016 at 5:12 PM
    #454
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    Getting new tires won't cause you to need an alignment but it's good to know your alignment is correct before ruining new tires.
    If your old tires are wearing perfectly symmetrically, I might not worry about it but if they're wearing funny at all I'd have it aligned AFTER the new tires are installed.
    MQQSE and JohnNP like this.
  15. Jan 20, 2016 at 7:18 PM
    #455
    MCObray
    Oregon
    Right on, thanks for the response. This is a new-to-me truck, so I may have alignment performed just to baseline the vehicle further...
  16. Jan 20, 2016 at 9:01 PM
    #456
    NMTrailRider
    New Mexico
    Yep. They're great. But honestly, if it weren't for the slight size increase, I wouldn't know they're any different than the MS2's.
    I would have just got MS2's again, but figured what the hell. MS2's are going away anyway, and the defender is supposed to have slightly better wet/snow. I really can't imagine Mich woulda messed too much with something that's had as good of a response as the Ms2 has had over the years. Unless they were pretty confident it would hold up similarly.
    No complaints here and I really don't expect there to be any. But I understand the apprehension when the MS2's were/are as good as the are! If I do have any complaints, I'll come back and update.
    JohnNP[QUOTED] likes this.
  17. Jan 21, 2016 at 4:29 AM
    #457
    hetkind
    Howard
    Johnson City
    Tell you what, at the 265 width, I am never going to overload the P LTX tires, and they perform VERY well. And track far better than my P rated studded snows. Of course with the cap on, no more hauling sand and gravel!
    Howard
    JohnNP likes this.
  18. Jan 21, 2016 at 7:40 AM
    #458
    NMTrailRider
    New Mexico
    Agreed
  19. Jan 22, 2016 at 9:37 AM
    #459
    MCObray
    Oregon
    MQQSE, JohnNP and NMTrailRider like this.
  20. Jan 22, 2016 at 10:10 AM
    #460
    NMTrailRider
    New Mexico
