Michigan Tacomas
Discussion in 'Mid West' started by harshest, Feb 8, 2009.
  1. Feb 22, 2022 at 11:35 AM
    #3801
    Scotfree
    Scotfree I drive slow
    2021 sr 4x4 2.7
    Do you guys think a few coats of a rust inhibitor wax on a stainless steel exhaust will keep it from rusting? Or should I prime it and paint it with high temp paint? I literally would put a coat on every wash, At least once a month but probably twice a month.
  2. Feb 22, 2022 at 12:50 PM
    #3802
    MSgt O
    MSgt O Well-Known Member
    2013 Tacoma
    if you have a true stainless exhaust like 304/316 stainless, fluid film or woolwax is the best thing to keep it from rusting. Painting it will not. More often than not, stainless exhaust cracks before it rusts. If you have 409 stainless, it will rust much less than the others. So, it depends on what your exhaust was built with. That all being said, fluid film and woolwax will help greatly at stopping rust from starting.
    CygnusX191 likes this.
  3. Feb 22, 2022 at 2:21 PM
    #3803
    Scotfree
    2021 sr 4x4 2.7
    Thank you, I’m soaking up all of the Michigan knowledge I can get and I appreciate it! I painted the welds that aren’t near any polished pieces just as an added layer of protection, but won’t bother with the rest until I can’t stand it.
  4. Feb 22, 2022 at 3:17 PM
    #3804
    Scotfree
    2021 sr 4x4 2.7
    Primed and painted the hangers actually and the tip weld.
    CygnusX191 and koditten like this.
  5. Feb 22, 2022 at 4:52 PM
    #3805
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Keep in mind fluid film and woolwax smell funky when they get heated up on your exhaust. Nothing to worry about but you will wonder wtf the first time you smell it
    Scotfree and Shellshock like this.
  6. Feb 22, 2022 at 5:04 PM
    #3806
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Lol.
    You got that right!
    FF smells like a cat litter box 3 days past being scooped out!
    I use Fluid Film pretty regular.
    I go out of my way to avoid spraying the exhaust system.
    I think the Fluid Film stuff works great, but I can't say I'd be in love with a "hot cat shit" aroma.
    Find out if your exhaust is truly stainless by trying to attach a magnet to it. Stainless will have small amount of attraction to the magnet. I'm betting the exhaust is "aluminized" steel. Just a fancy name for a coating that reduces corrosion. I bet a magnet sticks pretty good.
    With that said, I can't see Fluid Film sticking very long to the exhaust. The system just gets too hot.
    The best recipe for a long exhaust system life is longer trips.
    I'm talking 50 miles or more to completely dry out the exhaust system between shut downs.
    Remember your high school chemistry.
    The main byproduct of any combustion process is water.
    Heat things up completely and the moisture will cook off.
    Good conversation.
  7. Feb 22, 2022 at 5:38 PM
    #3807
    Scotfree
    2021 sr 4x4 2.7
    The magnet sticks to the pipes but not the resonator, tip or the muffler. It’s getting nice and shiny… Hopefully the Rejex helps. I still have some woolwax left, but I think I’ll hold off until it starts to look bad. I know I don’t need this exhaust system but I feel like the price was too good to pass up in the twilight zone we currently live in.$500 for a Magnaflow cat back. As somebody else on TW said, “it’s about smiles per gallon.”
  8. Feb 22, 2022 at 6:35 PM
    #3808
    33yrsoftoys
    33yrsoftoys Over 40yrs now
    joel
    mid Michigan
    2021 dcsb off road 6 speed manual
    Bilstein 6112's 5th clip 1/4" spacer driver's side. Icon tubular UCA's with Delta joint, wheelers superbumps, ECGS bushing. Allpro standard leaf packs, 5160's, U bolt flip kit with wheelers super bump's, extended stainless steel brake lines, carrier bearing drop. Icon rebounds 17" with Nitto terra grappler G2's 285/70/17's.
    Looks really good. Well done.
    CygnusX191 and Scotfree[QUOTED] like this.
  9. Feb 22, 2022 at 8:33 PM
    #3809
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    Rejex is good stuff and I think it was developed to protect paint and polished aluminum surfaces aft of aircraft engine exhaust stacks from exhaust soot sticking and staining the surfaces. You should let it cure for 8-12 hrs before raising the temp over 85°, though. It won't bond to the surface well or at all if it's applied to a hot surface or heated shortly after application.
  10. Feb 23, 2022 at 9:47 AM
    #3810
    Roof Walker
    Roof Walker Well-Known Member
    SE Michigan
    2021 Tacoma TRD Pro MT
    Maxxis Militia
    Ive noticed a lot of your posts in all sorts of threads… and you always seem to be very well informed on metallurgy and chemistry. I’m curious if you were a machinist or something along those lines in the past? I believe you told me when I met you that you were retired now but I could have that wrong too.
  11. Feb 23, 2022 at 9:58 AM
    #3811
    koditten
    Kirk
    Central Michigan
    Close.
    Retired water tech. Dealt a lot with boiler waters and cooling tower water.
    No real certifications, just 25 years dealing with basic water treatment chemistry.
    jwctaco and CygnusX191 like this.
  12. Feb 23, 2022 at 10:04 AM
    #3812
    koditten
    Kirk
    Central Michigan
  13. Feb 23, 2022 at 2:07 PM
    #3813
    jwctaco
    jwctaco Retired, going slow in the fast lane
    Jim
    SW Michigan
    23’ T4R
    koditten[QUOTED] and CygnusX191 like this.
  14. Feb 24, 2022 at 3:18 PM
    #3814
    Mateo74
    Mateo74 Well-Known Member
    Matthew
    NWI
    16' Tacoma Sr5 Blazing blue pearl
  15. Feb 24, 2022 at 3:50 PM
    #3815
    koditten
    Kirk
    Central Michigan
    Yes. Been planning to.
    Gonna build a couple in the near future.
  16. Feb 25, 2022 at 9:21 AM
    #3816
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Woolwax has much less of an odor (from what I'm told). I use it every year and haven't noticed any smell from the exhaust. Although I do try to avoid spraying it since it's just going to burn off anyway.
  17. Feb 25, 2022 at 10:56 AM
    #3817
    Scotfree
    2021 sr 4x4 2.7
    I did the same. 3 coats of Rejex on the aftermarket exhaust and 2 coats kbs high temp primer, 2 coats paint and heat cured the hanger welds hangers + tip weld, and where it mounts to the cat. Tried to leave wax residue on the welds intentionally. Anti-seize on the bolts. After time tells, I might take a rag and “clear” woolwax a thin layer wipe down. Noticed it does saturate the high temp paint on the cat. No funny smells though… yet.
    JustJon and CygnusX191 like this.
  18. Feb 25, 2022 at 11:45 AM
    #3818
    koditten
    Kirk
    Central Michigan
  19. Feb 25, 2022 at 11:52 AM
    #3819
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    This truck is too clean underneath
    :mudding:
    Scotfree[QUOTED] likes this.
  20. Feb 25, 2022 at 3:22 PM
    #3820
    Scotfree
    2021 sr 4x4 2.7
    Can’t find the graphic for elbow grease.
