Mickey Thompson Classic II and lug nut question
Discussion in 'Wheels & Tires' started by 6spdtaco, Mar 3, 2012.
  1. Mar 3, 2012 at 5:18 PM
    6spdtaco
    6spdtaco [OP] Well-Known Member
    VT
    Taco
    Will the stock lug nuts that came with my TRD alloy wheels work with the Mickey Thompson Classic II wheels? If not, what nuts should be used?
  2. Mar 4, 2012 at 5:38 AM
    6spdtaco
    VT
    Taco
    Thanks. here I go!
  3. Mar 4, 2012 at 11:36 AM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    most aftermarket wheels use 60* cone/tapered lugs. my recommendation is to buy a set of spline lug nuts. they provide the most clearance around the lug area.
  4. Mar 4, 2012 at 2:08 PM
    SCSPerformance
    Vin
    Bay Area, CA
    2005 Tacoma
    i personally use spline lugs and i've had no issues whatsoever with them. within the last 6 months i've taken my wheels on and off about 10 times. there's no signs of wear or cracking. they're hand torqued every time.
    if you trust gorilla acorn lugs, i see no reason why you wouldn't gorilla spline lugs. they produce quality products. stay away from the cheap crap and there shouldn't be any issue.
  5. Mar 5, 2012 at 6:58 PM
    DFB
    DFB Active Member
    Southaven, MS
    2012 Doublecab 4wd
    Does anyone know of another source for the gorilla lug nuts besides wheelers? I placed an order with them today and they are backordered for the next 1-2 weeks.
