Mid-Height Hiking Boots with Wide Toe Box?
Discussion in 'Outdoors' started by essjay, Dec 19, 2022.
  1. Dec 19, 2022 at 8:52 AM
    essjay
    essjay [OP] Part-Time Lurker
    Concord, CA
    2011 Tacoma SR5 (V6/AC/4WD)
    I have a boot reimbursement for work, and am looking for something with a wider toe box to replace my worn-out Danner Jags for when I don't need my taller, heavier boots (Danner Pronghorns). The job involves hiking (from flat pavement to loose 2:1 slopes) and rock scaling/rappelling (2:1 and steeper), although I'm generally wearing the Pronghorns for the latter two. I have a separate pair of alloy toe workboots that that I wear when that's required (basically never), so that's not a concern.
    I recently picked up a pair of Altra Lone Peak 6 shoes for general wear and light hiking, and was really impressed by the wide toe box and lightweight. Possibly the most comfortable shoes I've ever had, honestly. The Lone Peak Hikers and Lone Peak All-Weather Mids look to be very similar and are light, but I'm a bit concerned with durability due to how light they are. Since I only get reimbursed every 18 months, I'm looking for something that will last me close to that long.
    I also tried on a pair of Keen Targhee IIIs yesterday, and found them to be extremely comfortable. They're a little heavier than the Jags were, but they looked to be more durable than the Jags or either of the Altras.
    I'm 90% sure I'm going to go for the Keens, simply because I think they'll last longer, but figured I'd check here if anyone else had anything else that they'd recommend checking out.
  2. Dec 19, 2022 at 8:54 AM
    Evostaco
    Evostaco Jack of some of the trades, master of maybe 2
    Nebraska
    2021 tacoma offroad, mt, superwhite
    I like my keens
    50Buck and CTSpruceMica like this.
  3. Dec 19, 2022 at 8:57 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Might try on some merrell j06051w. I have clown feet and they’re very comfy.
  4. Dec 19, 2022 at 8:57 AM
    Knoxtaco20
    Knoxtaco20 Well-Known Member
    Knoxville
    2022 Tacoma DCSB 4x4
    I was going to suggest Altra based on looking for a wide toe box but it looks like you have some experience with them already. As far as durability, I have some Altra Lone Peaks that I use for trail running and used for close to 500 miles before they wore out. The soles look pretty good still but the cushioning lost it's cushion at the end. I have a weird shaped foot that is basically only wide in the forefoot and toes so I feel the pain of needing a wide toe box shoe. I have heard that Topo Athletic shoes / boots have a pretty wide toe box.
  5. Dec 19, 2022 at 9:11 AM
    essjay
    Concord, CA
    Yeah, I have the same problem, @Knoxtaco20. I wear thick socks with the Pronghorns because they're wide for me at the heel.
  6. Dec 19, 2022 at 9:17 AM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    I’m not sure on how wide they are but I have had great luck with Salomon Ultra GTX lineup. Lightweight, waterproof, comfortable and durable.
    b_r_o likes this.
  7. Dec 19, 2022 at 9:30 AM
    essjay
    Concord, CA
    I really wanted those Salomons, because they hit all the other boxes. The regular fit is too narrow at the toe, and REI unfortunately didn't have any wides in stock for me to try on.
  8. Dec 19, 2022 at 9:35 AM
    kraftorama
    kraftorama Well-Known Member
    Longmont, CO
    2015 Tacoma TRD OR DCSB
    GFC Camper Icon RXT leaf pack 3rd gen suspension 2022 Trail Edition wheels
    Oboz Sawtooth and Bridger are worth a look. Oboz toeboxes run a bit wider than most similar brands/models. Similar to the Keens mentioned but maybe a touch lighter.
    EdgemanVA likes this.
  9. Dec 19, 2022 at 9:37 AM
    CTSpruceMica
    CTSpruceMica Is a hotdog a sandwich?
    Dennis
    2014 Spruce Mica
    Having had both Keens and Salomons, I've found the Keens to have a wider toe box. All my Keens have held up extremely well. My favorite would be Vasque (and the best wet traction) but pricey
  10. Dec 19, 2022 at 9:48 AM
    VTi EG6
    VTi EG6 Well-Known Member
    TX
    2017 Taco TRD Sport
    Lone Peaks are good & Light, some have been said to wear down easy. I replaced my 4’s with Oboz. 2years strong w the oboz now.
    EdgemanVA and essjay[OP] like this.
  11. Dec 19, 2022 at 9:51 AM
    FlyingWolfe
    FlyingWolfe Wolfie
    Crystal
    Maine
    2018 Tundra TRD OR inferno
    Coworkers both have wide-assed dude feet and both wear Keens and love them. Pipeline field tech work, a lot of climbing/hiking/working and they do fine for em. I tried them myself but have tiny feet and they were too wide.
    Sig45 likes this.
  12. Dec 19, 2022 at 9:56 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    Super happy with Keen's for a wide toe box hiking & light hunting boot. Current pair are getting retired to garage duty after some pretty heavy hiking over the last 3 years. I'm not small and I'm always carrying 10-50ish lb worth of gear so they've done pretty well.
  13. Dec 19, 2022 at 11:29 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I have pretty wide feet and Asolo hiking boots fit me pretty well. They're expensive though
    Lighter weight stuff is always Salomon
  14. Dec 19, 2022 at 1:25 PM
    Tallgrass05
    Tallgrass05 Well-Known Member
    I've hiked in Danners, Vasque Breeze, Vasque St. Elias, Merrell Reflex, and Merrell Moab. The Moabs were hands down the most comfy right out of the box. Plenty of room for thick Smartwool socks.
  15. Dec 20, 2022 at 12:38 PM
    mhemberg
    mhemberg Well-Known Member
    2021 Tacoma TRD OR
  16. Dec 20, 2022 at 12:40 PM
    Braden801
    Braden801 Well-Known Member
    Utah
    2023 trd pro Tacoma
    TBD
    Look into a pair of Crispis.
    Best hiking boot I have come across so far.
  17. Dec 24, 2022 at 6:16 PM
    mic_sierra
    mic_sierra Toshiba HDDVD is the future
    Elsewhere
    '21 DCSB TRD Sport 4x4 Auto
  18. Dec 24, 2022 at 6:36 PM
    Forest Moon
    Forest Moon Well-Known Member
    Greater Lowell Area
    '24 OR 6mt Supersonic Red
    I'll second(or third) Merrell and Keen. Merrell Moab Ventilators were probably the most comfortable hikers I've had. But I wear Timberland White Ledges at work because they're comfortable hiking boots but have the "work boot" look. They don't last so long, less than a year, but I do a lot of walking on concrete and other hard surfaces. I'm on my feet 9 hours a day and in my experience, $300 boots don't seem to last any longer than $90 ones.
  19. Dec 24, 2022 at 7:52 PM
    essjay
    Concord, CA
    I think I'm going to end up with the Keen's, simply because I can try them on. Thanks for the help!
  20. Dec 30, 2022 at 11:25 AM
    EdgemanVA
    EdgemanVA Well-Known Member
    Virginia Beach
    2008 X-Runner
    Several
    I wear Oboz "low top" hiking shoes/boots. They felt more like hiking boots than either Keens or Merrells. In order to get the required "toe box" room for light backpacking, I went up a half size to 13s.
