Mid Travel BS 2.0
Discussion in 'Suspension' started by 2ndGenJonny, Jan 12, 2016.
  1. Apr 29, 2016 at 6:29 PM
    #2181
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    No, mine came loose after the initial install.
  2. Apr 29, 2016 at 6:51 PM
    #2182
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
    Don't forget loctite on the spindle to adapter bolts too. Seen a couple of those come loose.
  3. Apr 29, 2016 at 7:06 PM
    #2183
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    when uniballs are brand new they can be so fkn tight that when you turn the steering wheel and the ball joint adapter on the bottom of the spindle turns the bolt/nut and uniball doesn't turn with it. The bottom of the BJ adapt turns against the bottom of the nut and when that happens it loosens the bolt when you turn the wheel...and re loosens it until your uniball is broken in a bit. Mine did it too on two separate kits and always worse on the drivers side for some reason ?
    So, it didn't stop coming loose because you put loctite on it - it stopped coming lose because the thing that was causing it stopped causing it - mic drop :rimshot:
    Airdog likes this.
  4. Apr 29, 2016 at 7:07 PM
    #2184
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    This...and the torque spec is ATAYCFGIWTBWYH
  5. Apr 29, 2016 at 8:29 PM
    #2185
    sasquatch95
    sasquatch95 Well-Known Member
    Hunter
    nanaimo BC
    07 DCLB sport
    I'm pretty sure I put lock tight on 2 bolts either side not the one that goes through the uniball but the other 2... Also how do my cv angles look? I'm thinking I'm going to lower it down to 23 or should I wait a bit till the coils settle as they are brand new?
  6. Apr 29, 2016 at 9:22 PM
    #2186
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    Your cv's don't look bad at all and if your coils are brand new they will settle a lot...but that also means you will have to realign it after they settle. You should have let them settle and finished adjusting them before you got an alignment amigo.
    12TRDTacoma likes this.
  7. Apr 29, 2016 at 9:25 PM
    #2187
    12TRDTacoma
    Rob
    Concordia
    Boosted
    He's right you know ^^^
  8. Apr 29, 2016 at 9:26 PM
    #2188
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Speaking about loose bolts and tight uniballs, I never experienced the issue you guys are describing with mine. It may have to do with the fact that I had to remove the bolts and spindle assembly a few times afterwards to keep trying to fix my tearing, or sliding off the rotating cup assembly axle boots, however.
  9. Apr 29, 2016 at 9:29 PM
    #2189
    sasquatch95
    Hunter
    nanaimo BC
    07 DCLB sport
    I really wish I could have and that was the plan but I had to get all new alignment tabs from toyota so I losted where I marked them and I tried to take a best guess to get it close to where I had it before but I was way off and it was trying to pull me in every direction so I had to get an alignment ASAP as it's my DD I don't might going again but it it's another 120$ but oh well I guess
  10. Apr 29, 2016 at 9:37 PM
    #2190
    Glueman
    Glueman Yersinia pestis
    Utah
    The Plague....
    6 inch Douche Bag lift...what else do I need?
    Do you ever expect any play/movement in a uniball? Wondering if the teflon liner can wear out or come out and allow the uniball to develop any movement....
  11. Apr 29, 2016 at 9:43 PM
    #2191
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    Yup...uniballs do not last forever and any play is no good
    ckeene9 likes this.
  12. Apr 30, 2016 at 1:59 AM
    #2192
    ckeene9
    Chesterfield, VA
    See Build Thread
    You mean I have to replace consumables?
  13. Apr 30, 2016 at 5:52 AM
    #2193
    2ndGenJonny
    2ndGenJonny [OP] Well-Known Member Vendor
    Jon
    Gilbert, AZ
    What about ass play? Or playing with yourself?
    Silver02Taco likes this.
  14. Apr 30, 2016 at 8:13 AM
    #2194
    Glueman
    Utah
    The Plague....
    Guess I was kind of wondering about the limit. How much play is too much? Guess thats subjective ... "I know it when I see it"
  15. Apr 30, 2016 at 9:13 AM
    #2195
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    Well your on the east coast ...so you probably need to replace yours 10x a year...maybe 20 because of your tight trails and salty roads
    ckeene9[QUOTED] likes this.
  16. Apr 30, 2016 at 9:14 AM
    #2196
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
  17. Apr 30, 2016 at 9:20 AM
    #2197
    BigRedToy
    BigRedToy ¯\_(ツ)_/¯
    Colorado
    07 Regular Cab SR5 4x4
    Greasable shackles, any recommendations?
    Mr.PowerTrays likes this.
  18. Apr 30, 2016 at 9:32 AM
    #2198
    2ndGenJonny
    Jon
    Gilbert, AZ
    If you are going to 5", Rubicon Express makes them. You can get them from 4wp for around 80$ i think. Unless you know someone with a Transamerican account. Then they will be a bit cheaper.
  19. Apr 30, 2016 at 9:34 AM
    #2199
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    So here's an easy way to tell, grab your UCA and try to move it as much as you can, if you can feel ANY movement in the UCA, your UCA is gonna need replacing, the more play, the sooner the replacement. That bitch should be completely solid. Basically every part on your truck should be the same, if you can grab it and wiggle it, something aint right. Grab a wrench.
    LTDSC and Glueman like this.
  20. Apr 30, 2016 at 9:40 AM
    #2200
    BigRedToy
    BigRedToy ¯\_(ツ)_/¯
    Colorado
    I'm looking for a stock replacement.
