Mid Travel BS 2.0
Discussion in 'Suspension' started by 2ndGenJonny, Jan 12, 2016.
  1. May 11, 2016 at 5:59 PM
    #2321
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    Probably better to weld on the LCA skids and weld a tab to that.
    Probably no material difference to weld on a backer plate and the tab to that though.
    Some people also have good luck attaching the bottom of the strap to the bolt for the coil over.
    I have DK LCAs waiting to be installed with my limit straps...
    AE
  2. May 11, 2016 at 7:28 PM
    #2322
    Mr.PowerTrays
    Mr.PowerTrays Well-Known Member Vendor
    Maverick
    Colorado
    2011 dcsb trd or
  3. May 11, 2016 at 7:31 PM
    #2323
    Mr.PowerTrays
    Maverick
    Colorado
    2011 dcsb trd or
    actually 4.5'' is wayyy to far out, ill just build my own i guess. but is that the right size shackle hanger for the dakars?
  4. May 11, 2016 at 7:33 PM
    #2324
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    ndcmack likes this.
  5. May 11, 2016 at 9:54 PM
    #2325
    a.smo
    a.smo Well-Known Member
    Aaron
    PHX, Az
    '99 Trd Xtra Cab 4x4 5sp
    Curious as to why? I figured you'd be fully boxed and plated.
  6. May 11, 2016 at 9:59 PM
    #2326
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Idk lol. Frames stronger since whole truck is caged
  7. May 11, 2016 at 10:03 PM
    #2327
    a.smo
    Aaron
    PHX, Az
    Forgot your truck was caged. Haha.
  8. May 11, 2016 at 10:05 PM
    #2328
    doreydeluxe
    doreydeluxe Well-Known Member
    Scott
    Colorado
    2007 AC Off Road
    Stuff
  9. May 12, 2016 at 11:36 AM
    #2329
    TACOconvert2012
    TACOconvert2012 My truck hates you. My wallet hates you.
    Socal
    SC'd 2012 MGM TX/Pro 4x4
    never ending..
    ok guys... I am about to pull my hair out searching for this clunking noise...
    I know my ICONs need a rebuild but I don't "think" that's where the noise is coming from. I have replaced my UCA, LCA, hubs, inner and outer tie rods and now I have a weird clunking when I stop or pull into my driveway. I noticed yesterday for the first time that if I take a corner under speed there seems to be a weird feeling of something sliding or adjusting causing a clunk. just got an alignment and tires.. guys seemed to not have any problems. about ready to tear the whole front end off and start over..
  10. May 12, 2016 at 11:42 AM
    #2330
    TACOconvert2012
    Socal
    never ending..
    if there isn't a member available hit up socal supertrucks they do them.. I think like 150$
    Rakso[QUOTED] likes this.
  11. May 12, 2016 at 11:43 AM
    #2331
    2ndGenJonny
    2ndGenJonny [OP] Well-Known Member Vendor
    Jon
    Gilbert, AZ
    Does it feel like its under your feet? If so, tighten the 4 body mounts and check the bed mounts also. Mine used to back off on my 08 and would make a clunk. Use a breaker bar and a deep well socket.
  12. May 12, 2016 at 12:50 PM
    #2332
    TACOconvert2012
    Socal
    never ending..
    I will try this today.. I kind of looked at the body mounts and wondered but didn't feel like touching them so I guess in order to check them off my list of possible causes its time. oh and yes it does feel "under my feet" cross my fingers...
  13. May 12, 2016 at 1:02 PM
    #2333
    2ndGenJonny
    Jon
    Gilbert, AZ
    The symptoms sound the same, they back of a few threads and they clunk.
    Like I said, use a breaker bar and a deep well. The bed bolts are a t55 or 56 star.
  14. May 12, 2016 at 1:07 PM
    #2334
    TACOconvert2012
    Socal
    never ending..
    Thanks for the info, I have the star for the bed bolts lying around somewhere because one of them backed out on me in the past.
  15. May 12, 2016 at 1:11 PM
    #2335
    2ndGenJonny
    Jon
    Gilbert, AZ
    I hope thats the issue. Hunting down noises sucks ass!
  16. May 12, 2016 at 1:13 PM
    #2336
    TACOconvert2012
    Socal
    never ending..
    yup, makes me miss the days the truck didn't make a sound. But you play hard sometimes you pay hard... think that's how it goes lol
  17. May 12, 2016 at 1:20 PM
    #2337
    2ndGenJonny
    Jon
    Gilbert, AZ
    Its mostly my heimed uppers and uniballs that make noise. I finally found a good lube for the az heat as well. I think ill be getting ready to order some new uniballs since mine are nearing 60k
  18. May 12, 2016 at 1:24 PM
    #2338
    Arcticelf
    Gladiator
    What do you use for the heimes? Dry lube like a uni-ball?
  19. May 12, 2016 at 1:33 PM
    #2339
    TACOconvert2012
    Socal
    never ending..
    that's how mine was for a long time, left all uniballs and heim joints except the small spherical bearings on the top and bottom of my ICONs..
  20. May 12, 2016 at 1:36 PM
    #2340
    2ndGenJonny
    Jon
    Gilbert, AZ
    I have used the triflow in the past but now im using Bel Ray Moly lube on the UBs now. I haven't coated the heims cause the can doesnt have one of those straw tips and the spray isn't that tight to get in without coating everything. Im ok with the heims making noise, its no where as loud as the UBs.
    Arcticelf[QUOTED] likes this.
