Mid Travel BS 2.0
Discussion in 'Suspension' started by 2ndGenJonny, Jan 12, 2016.
  1. Jan 13, 2016 at 3:46 PM
    #221
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    Meh...honestly when it comes to something as simple as an UCA, cromo is cromo and a unibal is a uniball so I wouldn't hate on it at all...
    jberry813 likes this.
  2. Jan 13, 2016 at 3:47 PM
    #222
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    I've got no qualms with TC, and in fact, I'll most likely be purchasing a set of their arms in the near future. My post in no way was meant to put down TC, and I can very much appreciate a company that takes pride in their craftsmanship and customer service. At the same time I was also in no way supporting Pro Comp. Besides a $30 set of spindle gussets, I've had no dealings with either.
    I think my main point was somewhat misconstrued in that all I was hoping for was an honest comparison of the products, and not for my own sake so much as to point out how some products are defended, recommended, or condemned. Stating how they run their company and past product history also in no way effects the quality of the arms. Yes their lifts have historically been for looks and not performance, but that does not effect this specific product. Also, some people might put up with poor customer service for a cheaper price.
    Does that make more sense?
    In regards to the copy of arms arguments, I have to ask how many ways can one possibly make a uniball arm? To simply make them work they all will look nearly identical, no? How much castor is effected is another point entirely, and yes, ProComp should advert those figures.
    Anyways, I digress. I was merely pushing for fair consideration, or reviews, of products on their own merits or lack thereof.
    Mr Salty and BenTheMan like this.
  3. Jan 13, 2016 at 3:47 PM
    #223
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    yessir! went from PC.. to OME.. to Kings.
  4. Jan 13, 2016 at 3:52 PM
    #224
    BohlaaH
    BohlaaH Loading...
    ALEX
    Thunder Bay, Ontario
    2015 TRD Sport DCLB
    Rigid Industries Grille and 20' fitted LED bar 6" BDS Lift w/ FOX 2.5 (front) FOX 2.0 (rear) 35x12.5 TOYO M/T Open Country Tires Fuel Assault 18" Wheels OPT 7 LED 9003 Headlight Cut Cab Mount & Pinch Weld Trimmed Fender Flares 4.88 Yukon Gears ARB air locker Front & Rear Dent in Driver door... Relentless Fab CB antenna hood mounts Rigid Industries Dually "Amber" spot lights Adventure Offroad Fabrication Overhead Console OTTRAW Switch Mod
    I am looking into the total chaos upper and lower control arms. Will these give me better ground clearance? More "droop"? I'm running a drop bracket and wanna get that bastard of a diff plate up higher. Will control arms do this? Should I get stock length if so?
  5. Jan 13, 2016 at 3:54 PM
    #225
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    @iJonny :laughing:
    jberry813 and 2ndGenJonny[OP] like this.
  6. Jan 13, 2016 at 3:55 PM
    #226
    BohlaaH
    BohlaaH Loading...
    ALEX
    2015 TRD Sport DCLB
    I came here because most of you guys are running aftermarket control arms.
  7. Jan 13, 2016 at 3:55 PM
    #227
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    control arms will not do anything to get your front diff up any higher. with uniball uppers and lowers and the correct shocks you can gain a inch - ish of travel
  8. Jan 13, 2016 at 4:08 PM
    #228
    2ndGenJonny
    2ndGenJonny [OP] Well-Known Member Vendor
    Jon
    Gilbert, AZ
    Understood and I appreciate the well thought out response. I'm not going to push the topic any more.
    Like I stated in my post above I'm VERY well versed in ProComp lifts. I have some links for you and I'll PM you later with them. I hope it will help you out.
    Another man that is very knowledgeable with DB lifts right here. Definitely no stranger to dumping a shit ton of money either.
    BohlaaH[QUOTED] likes this.
  9. Jan 13, 2016 at 4:13 PM
    #229
    1337Taco
    1337Taco Well-Known Member
    Kevin
    NorCal
    2015 4X4 Manual
  10. Jan 13, 2016 at 4:22 PM
    #230
    BohlaaH
    BohlaaH Loading...
    ALEX
    2015 TRD Sport DCLB
    I have a bds lift... Dunno if that makes a difference, please pm me. I would like to ask a few questions!
  11. Jan 13, 2016 at 4:27 PM
    #231
    Acerwin
    Acerwin The unNORM NORM
    Andrew
    South Carolina
    Toyota Tundra
    This
  12. Jan 13, 2016 at 4:29 PM
    #232
    2ndGenJonny
    Jon
    Gilbert, AZ
    Pm sent sir.
  13. Jan 13, 2016 at 4:36 PM
    #233
    336
    336 Well-Known Member
    Kendrick
    Ashe/Boone
    4x4 6 Speed
    I need to be added to the basic bitch MT list.. nothing fancy my way, just a clean ass ride.
    lol edit: #idontvalve
    Josh828, 2ndGenJonny[OP] and Acerwin like this.
  14. Jan 13, 2016 at 4:45 PM
    #234
    2ndGenJonny
    Jon
    Gilbert, AZ
    Added mang
  15. Jan 13, 2016 at 4:46 PM
    #235
    336
    Kendrick
    Ashe/Boone
    4x4 6 Speed
    thanks bruh. more mods to come.. i've just been enjoying my shit, it's a dependable set up and several others can second that
    2ndGenJonny[OP] likes this.
  16. Jan 13, 2016 at 5:42 PM
    #236
    Rattletrap66
    Rattletrap66 (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
    am I half Mid travel? Add me if I can make it lol just the rear I guess would be
    Acerwin likes this.
  17. Jan 13, 2016 at 5:43 PM
    #237
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    When you going to get that front done?
    Rattletrap66[QUOTED] likes this.
  18. Jan 13, 2016 at 5:44 PM
    #238
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
  19. Jan 13, 2016 at 5:44 PM
    #239
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    Great idea for a new thread, and thank you.
    In other news, its time for limit straps, at least it's fucking cold out now for laying under the truck welding...
  20. Jan 13, 2016 at 5:46 PM
    #240
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    after 35's, regear and locker
    Acerwin[QUOTED] likes this.
