Mid Travel BS 2.0
Discussion in 'Suspension' started by 2ndGenJonny, Jan 12, 2016.
  1. Jun 22, 2016 at 3:14 PM
    #2781
    Forcedtravel
    Forcedtravel Well-Known Member
    Gharrity
    Agoura hills
    09 sr5 4x4 6spd
    Bunch of shit
    I noticed in your title you work on radars ?
  2. Jun 22, 2016 at 3:21 PM
    #2782
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
  3. Jun 22, 2016 at 3:21 PM
    #2783
    VolcomTacoma
    Jeff
    NorCal
    Please google my quote
  4. Jun 22, 2016 at 3:22 PM
    #2784
    Forcedtravel
    Gharrity
    Agoura hills
    09 sr5 4x4 6spd
    Bunch of shit
    hahah i take that as a no. i work on microwave radio systems and cell sites thats why i ask
    Arcticelf likes this.
  5. Jun 22, 2016 at 3:23 PM
    #2785
    Forcedtravel
    Gharrity
    Agoura hills
    09 sr5 4x4 6spd
    Bunch of shit
    Touche
  6. Jun 22, 2016 at 3:25 PM
    #2786
    VolcomTacoma
    Jeff
    NorCal
  7. Jun 22, 2016 at 3:26 PM
    #2787
    Forcedtravel
    Gharrity
    Agoura hills
    09 sr5 4x4 6spd
    Bunch of shit
    I was about to have a Nerd moment with you so thanks for bursting that bubble
  8. Jun 22, 2016 at 3:29 PM
    #2788
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Will be curiously watching what you come up with. Wish I could go outside the frame like the 2nd gen guys.
  9. Jun 22, 2016 at 3:36 PM
    #2789
    2ndGenJonny
    2ndGenJonny [OP] Well-Known Member Vendor
    Jon
    Gilbert, AZ
    Makes squeezing shocks without spacers more complicated though. The BAMF inboard 1st gen setup seems like the way to go if you are 1st gen and SOA. You 1st gen guys also have proper shackles. I had to do a lot of work to get mine there.
  10. Jun 22, 2016 at 3:40 PM
    #2790
    VolcomTacoma
    Jeff
    NorCal
    Agreed. I ended up buying a Ford 9" on a whim, but now I'm second guessing that and thinking on just trussing the stock axle a bit and waiting until I can afford a full currie set up linking this bitch. Gonna run me another probably 3-4k just to get the Third member and get the axle all setup, in addition to what I paid for it...Thinking it's not work it
  11. Jun 22, 2016 at 3:49 PM
    #2791
    2ndGenJonny
    Jon
    Gilbert, AZ
    MT went LT again. I thought t100 axles were the ones to truss and use for links?
    Or is that for 1st gens?
  12. Jun 22, 2016 at 3:50 PM
    #2792
    VolcomTacoma
    Jeff
    NorCal
    1st gens can use the Toyota stuff because it's all a couple inches wider than 1st gen axles. 2nd gens would only benefit like 1" wider. The junkyard Ford 9" I got is like 69" WMS, vs the 65" WMS for stock rear axles...so it'll match the front end a bit more and keep my tires off the shocks...but I'm gonna have to put in some work to get it set up...
  13. Jun 22, 2016 at 3:51 PM
    #2793
    VolcomTacoma
    Jeff
    NorCal
    And actually...did we ever establish if 5100s are considered MT? Otherwise...stock went LT again :D
  14. Jun 22, 2016 at 4:08 PM
    #2794
    2ndGenJonny
    Jon
    Gilbert, AZ
    You mean 5100s went MT again?
    I dont set the rules, i just help people where I can. Isnt there a Billie that is long enough to take advantage of a UB upper?
    I dont even know cause Ive never looked at Billies or OME. I just know some locals that run pretty hard with those setups. Anyone who uses their truck gets my :thumbsup:
    MT or whatever thread this is.... I dont care what we call it.
    Maybe I should change the name to Drawn over Mandrel Wars version 2.
  15. Jun 22, 2016 at 4:10 PM
    #2795
    VolcomTacoma
    Jeff
    NorCal
    :notsure:
    I don't know things anymore. I just know I got 5100s for free (+labor) and then went LT lol
  16. Jun 22, 2016 at 4:27 PM
    #2796
    2ndGenJonny
    Jon
    Gilbert, AZ
    I assume that you've tried different valving to compensate?
    I ask cause I do not know. When I was looking at inboard setups I read that valving is a big part of it.
  17. Jun 22, 2016 at 4:36 PM
    #2797
    2ndGenJonny
    Jon
    Gilbert, AZ
    Please allow me to be the devil's advocate here but before you go and rip it all apart why not revalve and see what happens?
    2.0 shim stacks arent expensive at all and as JD showed me, its not that hard to do.
    Silver02Taco likes this.
  18. Jun 22, 2016 at 4:49 PM
    #2798
    2ndGenJonny
    Jon
    Gilbert, AZ
    I see what you are saying now. I went through a similar operation with mine. We cut out the crossmember, plated in the frame and pulled the bed to get the relocation brackets as far fwd as a DCSB would allow. That combined with valving that King suggested, the shackle flip and 5" shackles, it worked out perfect. Fucking setup is using every bit of my Deavers and the shocks are not limiting anything like before.
    I say go for it man and get at it! Only you know your build and it sounds like youve got some great ideas.
    Edit: love me some 1st gens. My 1st Tacoma was an 02 silver AC prerunner with a locker.
  19. Jun 22, 2016 at 5:03 PM
    #2799
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    Use gold bond blue. It's like having angry gnomes hammering refreshing cool into your balls with frozen sledgehammers.
    Mr.PowerTrays likes this.
  20. Jun 22, 2016 at 5:06 PM
    #2800
    Arcticelf
    Gladiator
    I used to work for the outfit that built all the Fox and CBS electronic news gathering radios.
    Forcedtravel[QUOTED] likes this.
