Mid Travel BS 2.0
Discussion in 'Suspension' started by 2ndGenJonny, Jan 12, 2016.
  1. Jun 22, 2016 at 5:07 PM
    #2801
    2ndGenJonny
    2ndGenJonny [OP] Well-Known Member Vendor
    Jon
    Gilbert, AZ
    Nooooo thats what i used! It was like firenuts!
  2. Jun 22, 2016 at 5:10 PM
    #2802
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    You really should build up to it. :)
  3. Jun 22, 2016 at 5:11 PM
    #2803
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
  4. Jun 22, 2016 at 5:16 PM
    #2804
    2ndGenJonny
    Jon
    Gilbert, AZ
    Seriously... its been brutal these last 2 weeks. There is a street sign on my block that is burned black on the side that gets sun all day
  5. Jun 22, 2016 at 5:21 PM
    #2805
    TYetti
    TYetti 4cylinders of awesomeness
    Mat
    Abbotsford, BC, Canada
    09 Tacoma AC 2.7L 5spd 4x4
    No thanks I'll take the pacific rain forests over mind melting heat
    Arcticelf likes this.
  6. Jun 22, 2016 at 6:27 PM
    #2806
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Way simpler, cheaper, and just as effective to add your own crossmember. I boxed just a bit of the frame and then added a piece of 1.75" tubing and some ruff stuff tabs.
    Just wish there was a good way to run 12" shocks without going through the bed or having the hangers way down low.
    As far as shackles are concerned, I've learned my lesson messing around with them. Don't know that I would call one over the other 'proper'. Inverted or regular, if they pivot enough to accommodate the length of spring, they're doing their job. Changing the mounting point in relation to the frame doesn't change your springs.
    Silver02Taco likes this.
  7. Jun 22, 2016 at 7:52 PM
    #2807
    2ndGenJonny
    Jon
    Gilbert, AZ
    Im not saying go out and spend extra money on something when you have the ability to make it.
    As for shackles. OEM on the 2nd gens dont move freely without loosening the bolt and standing on a tire. One of if not the most functional mods ive done is the shackle flip on my rig.
  8. Jun 27, 2016 at 12:09 PM
    #2808
    sasquatch95
    sasquatch95 Well-Known Member
    Hunter
    nanaimo BC
    07 DCLB sport
    Getting my BAMF shock tower put on July 11 with 2.5 kings and was wondering if someone knew how big of wheel spacer I'll end to clear the shocks. Got 17x8 fn fx pro rims with 4.5 bs and 285/75 toyo's. Planning on putting arp wheel studs on at the same time and don't want to cut them and have them still to long for the spacers.
  9. Jun 27, 2016 at 12:14 PM
    #2809
    2ndGenJonny
    Jon
    Gilbert, AZ
    16 or 17? MTs? RTs? ATII?
  10. Jun 27, 2016 at 12:20 PM
    #2810
    sasquatch95
    Hunter
    nanaimo BC
    07 DCLB sport
    17's with ATII extreme
  11. Jun 27, 2016 at 12:28 PM
    #2811
    Bsheriff11
    Bsheriff11 Remember Your ABC's. Always. Be. Casual.
    Brandon
    Virginia livin', South Carolina raised
    2000 Limited T4R
    Click My Sig Homie
    You're gonna rub the shock body when you flex it
  12. Jun 27, 2016 at 12:31 PM
    #2812
    sasquatch95
    Hunter
    nanaimo BC
    07 DCLB sport
    Will be close to rubbing non flexed to I'd think. Just was wondering if someone ran close to this setup and what size spacer they used so I can get it before hand. I know it would be better to wait and see though
  13. Jun 27, 2016 at 12:31 PM
    #2813
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    Did you even read his question, he knows it is going to rub...he is asking what size spacer he needs
    sasquatch95 likes this.
  14. Jun 27, 2016 at 12:34 PM
    #2814
    Bsheriff11
    Brandon
    2000 Limited T4R
    Click My Sig Homie
    haha not fully apparently,I was getting asked a question at work while I was reading it. Sorry! I rub with 4.3 BS, I would need Just over a 1/4"" to fully clear, so I would get 3/4" spacers with that tire size and BS
    Mr.PowerTrays likes this.
  15. Jun 27, 2016 at 12:50 PM
    #2815
    sasquatch95
    Hunter
    nanaimo BC
    07 DCLB sport
    And you have 2.5" kings or 2.0??
  16. Jun 27, 2016 at 1:02 PM
    #2816
    Bsheriff11
    Brandon
    2000 Limited T4R
    Click My Sig Homie
    Well shit misread that too, think I'll get back on here after work! I have 2.0, the 3/4" spacer would be cutting it too close for you to fully clear, you'd be better off trying to get to 3.5" BS. Sorry for being confusing.
  17. Jun 27, 2016 at 1:17 PM
    #2817
    sasquatch95
    Hunter
    nanaimo BC
    07 DCLB sport
    It's all good!! I'm thinking atleast an 1-1/14 spacer.
    Bsheriff11[QUOTED] likes this.
  18. Jun 27, 2016 at 1:50 PM
    #2818
    2ndGenJonny
    Jon
    Gilbert, AZ
    Well I run the same tire and BS wheel and scrub a little bit with 2.0s. Id say the Synergy 1.5" spacers should be more than enough.
  19. Jun 27, 2016 at 2:36 PM
    #2819
    sasquatch95
    Hunter
    nanaimo BC
    07 DCLB sport
    Who'll hopefully I can run the smallest one possible like a 3/4 but I highly doubt it and your guess of 1.5 is probably going to be. Thanks guys for the answers! :)
  20. Jun 27, 2016 at 2:50 PM
    #2820
    2ndGenJonny
    Jon
    Gilbert, AZ
    :thumbsup:
    Good luck dude.
    Whos installing?
