Mid Travel BS 2.0
Discussion in 'Suspension' started by 2ndGenJonny, Jan 12, 2016.
  1. Jul 28, 2016 at 6:15 AM
    #3301
    glorifiedwelder
    glorifiedwelder IG= @Liquid_Torch
    jason
    Santa Clarita, ca
    double cab trd sport
    I understand where you're coming from, before going LT I swapped to aftermarket control arms because I do a lot of wheeling during hunting season and pretty much all my buddies can't get the kind of time off work that I can, so I spend almost every night 15-20 miles into the mountains with zero phone reception, so loosing a ball joint if I hit a rock at a funny angle or clip a tree stump is less that ideal. And the labor to replace the uniball is far less intrusive than a 15 mile hike at dusk to get out of the mountains, or trying to figure out how to get your truck up or down the hill your climbing when it breaks. If you keep your travel within the limits of the ball joint and strap your suspension then ball joint failures will be a rarity, and will more than likely come from a poorly picked line or driving mistake. Those failures aren't necessarily gonna be something you can predict by looking at the ball joints. Ask the 1st gen guys about that. They would love to have more uniball options and tend to have the most issues with ball joints.
    As far as a constant goes everything is give and take. You can trade ease of maintanence for reliability. Whether or not that realiability is necessary is up to you. 99% of all people will never have an issue with a ball joint, but I've seen what failure looks like both on the road and in the dirt. I'm not interested in being part of that 1% and experiencing that first hand. Nowadays I just build everything to go fast. If it can handle mistakes at speed it will more than likely handle anything you can do to it slow crawling.
  2. Jul 28, 2016 at 7:56 AM
    #3302
    Glueman
    Glueman Yersinia pestis
    Utah
    The Plague....
    6 inch Douche Bag lift...what else do I need?
    This is my basic approach to choosing suspension parts....
  3. Jul 28, 2016 at 12:17 PM
    #3303
    Chickenmunga
    Chickenmunga Nuggety
    Keizer, Oregon
    08 TRD Offroad DC 4x4 with stuff
    All the normal TW BS
    Thanks all, that last statement does make sense - it falls into the category of what I call, 'farmer logic' - break the answer down to no-nonsense, stone-cold logic. :)
    Another thing that maybe I read here (I don't know anymore, I'm burning out my brain between this and a large project at work): I believe it was mentioned that people were encouraging lubrication of uniballs and heims. Aren't these (at least the heims) teflon-lined spherical bearings? If so, lubrication would be bad. From Aurora Bearing:
    If any of those parts are steel-steel, why hasn't everyone replaced their joints with teflon-lined?
  4. Jul 28, 2016 at 1:07 PM
    #3304
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    I think the dry-lube is safe, and helps the Teflon lined bearings. Grease is certainly a bad idea for Teflon lined bearings though.
  5. Jul 28, 2016 at 1:12 PM
    #3305
    2ndGenJonny
    2ndGenJonny [OP] Well-Known Member Vendor
    Jon
    Gilbert, AZ
    As well as using brake cleaner or solvent on them is bad.
    Weve beaten the lube subject pretty hard :)
  6. Jul 28, 2016 at 2:21 PM
    #3306
    Adventurer_Alex
    Adventurer_Alex Generic mall crawler
    Alex
    AZ
    2013 Nissan XTERRA
    Where? That's something I need to read up on. Searching didn't really lead me to much
  7. Jul 28, 2016 at 2:29 PM
    #3307
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    :deadhorse::smash::smash::smash::smash::smash::smash::smash::smash::smash::smash::smash::smash::smash::smash::smash::smash::smash::smash::smash::smash::smash::smash::smash::smash::smash::smash::smash::smash::smash::smash::smash::smash::smash::smash::smash::smash::smash::smash::smash::smash::smash::smash::smash::smash::smash::smash::smash::smash::smash::smash::smash::smash::smash::smash::smash:
  8. Jul 28, 2016 at 2:48 PM
    #3308
    2ndGenJonny
    Jon
    Gilbert, AZ
    In this very thread atleast 3 times weve discussed ball maintenance
    Both the steel and flesh kind at that
  9. Jul 28, 2016 at 3:48 PM
    #3309
    Chickenmunga
    Keizer, Oregon
    Are you sure you aren't talking about the old MT thread? Search for 'teflon', 'uniball', and 'lube' and you only get this week's stuff. About the same when searching the entirety of the suspension sub-forum, unless those words are broken up into separate posts, which would make it very difficult to search on. Searching outside of TW, I'm still at odds. Read the green part from here on Aurora's opinion of the matter (they are the guys who made the part), whereas a member here just got off the phone with King and they recommend lubing the lower shock bearing upon installation (also a teflon spherical bearing). This might be case of application and or the assumed lube a person is applying.
    EDIT: nevermind, keep reading that thread link I posted to the bottom of the page. Better information from SKF
  10. Jul 28, 2016 at 4:30 PM
    #3310
    Adventurer_Alex
    Alex
    AZ
    2013 Nissan XTERRA
    Ive only been subd to this thread for a couple weeks
  11. Jul 28, 2016 at 5:03 PM
    #3311
    Arcticelf
    Gladiator
    What's the preferred way to take a solid coating of grease off a uni-ball? Had a CV boot slide off (clamp failed).
  12. Jul 28, 2016 at 5:24 PM
    #3312
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    I'm no expert, but I would just wipe it off really good with just a rag until you can't feel any residue on it. Any solvents might F-up the coating. Then coat with some Triflow Dri-lube in the drip bottle.
  13. Jul 28, 2016 at 5:29 PM
    #3313
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Simple Green and warm water.
    Gramps and Bentrodder like this.
  14. Jul 28, 2016 at 5:55 PM
    #3314
    2ndGenJonny
    Jon
    Gilbert, AZ
    Simple green is a good degreaser. What part water/solution do you use?
    LTDSC likes this.
  15. Jul 28, 2016 at 5:56 PM
    #3315
    2ndGenJonny
    Jon
    Gilbert, AZ
    Alex, your uniball uppers are still pretty new right?
  16. Jul 28, 2016 at 6:01 PM
    #3316
    Adventurer_Alex
    Alex
    AZ
    2013 Nissan XTERRA
    Yes, they don't squeak or anything. I'm just curious for future reference.
  17. Jul 28, 2016 at 6:12 PM
    #3317
    2ndGenJonny
    Jon
    Gilbert, AZ
    Just hold off until they squeek (if they even start to)
    When that happens head over to SDHQ and get either the small bottle of triflow dry lube for about 7$ or drop the 30$ on the can of Bel-Rey Moly lube. Ive had better luck with the Bel-Rey here in AZ in the winter and summer.
  18. Jul 28, 2016 at 6:13 PM
    #3318
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    50/50 for basically everything
  19. Jul 28, 2016 at 6:13 PM
    #3319
    Arcticelf
    Gladiator
    Welp fuck. I guess we'll find out how bad brake cleaner is...
  20. Jul 28, 2016 at 6:14 PM
    #3320
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    It's good for starting fires and removing paint :notsure:
