Mid Travel BS 2.0
Discussion in 'Suspension' started by 2ndGenJonny, Jan 12, 2016.
  1. Aug 10, 2016 at 10:47 AM
    #3681
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    So Dirt King vs. Total Chaos stock length lower arms. Both have a uniball end but one has poly bushings the other has deralin bushings. I am looking for thoughts, opinions, fact or experience on either arm and how that difference in bushing may affect my overall front suspension performance. Note that I have no need for LT with what I do so I am looking at stock length options. the balance of my front end is:
    • ICON 2.5's extend Travel coilovers with resi(no CDC) and Eibach 700lb springs.
    • Rokmen Pro-Series UCA's
    • So to be brand new spindles with TC gussets
    • Longer stainless steel brake lines - for no reason at all other then they were free.
    Also I know that the non race TC lowers have a drop in Uniball that is easier to replace then the race series which is what I would want but I have not researched the DK version yet. Anyone know off hand if the DK is press in or drop in? If not, no worries I do know how to search.
  2. Aug 10, 2016 at 10:55 AM
    #3682
    Mademan925
    Mademan925 Senor Taco
    Nick
    Discovery Bay, CA
    2014 4x4 TRD OFFROAD DCSB
    enough to go over stuff
    Didn't know this thread existed. My name is Nick and I am glad there is a safe place for me to learn about MT & LT.
  3. Aug 10, 2016 at 10:56 AM
    #3683
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
  4. Aug 10, 2016 at 11:20 AM
    #3684
    tubbsisland
    tubbsisland I took snowtanks beer
    Cliff
    Arizona
  5. Aug 10, 2016 at 11:26 AM
    #3685
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    been watching him test those on his tundra daily. Looks so awesome.
    VolcomTacoma likes this.
  6. Aug 10, 2016 at 11:46 AM
    #3686
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    In my experience Delrin bushings are a bit firmer but last longer and make zero noise. My previous DK kit was awesome and I really liked the Delrin bushings, my current Solo kit has poly bushings and I am running the F back to Delrin ASAP. Delrin bushings alone cost $200 so the DK's are a good value.
    I think you might be mixing up " race style " and " non race " style LCA's because TC makes both. There is no " drop in " uniball, the non race style TC lower uses an external uniball adapter which sure may save you 5 minutes replacing replacing a uniball but the downside is that the adapter lessens ground clearance under the LCA by a couple of inches. I personally would never suggest the non race LCA's and I would suggest DK over TC because the DK's do not have all of the little clearance / fit issues that a lot of folks run into with the TC's.
  7. Aug 10, 2016 at 11:55 AM
    #3687
    TMFF
    TMFF Well-Known Member
    Tim
    Thornton, CO
    01/02 DCLB
    Stuff and junk and things...
    For those that want to replace uniballs with out taking the arms off the truck.
    https://www.allgermanmotorsports.com/tools/uni-ball-tool/uni-ball-tools
    Or get a ball joint or front end service kit to press the uniball in and out.
    Large likes this.
  8. Aug 10, 2016 at 12:02 PM
    #3688
    Gramps
    Gramps
    07 TRD DC 4x4
    Thanks! And yeah I was mis-speaking in reference to the drop in uniball. I was just on TC's site and see that it is adapter with a uniball in it. I am assuming that uniball press tool is needed to make changing out a uniball quick? I suppose that wouldn't be bad and adding another tool to the garage is never a bad thing. :D
  9. Aug 10, 2016 at 12:04 PM
    #3689
    Gramps
    Gramps
    07 TRD DC 4x4
  10. Aug 10, 2016 at 4:01 PM
    #3690
    Glueman
    Glueman Yersinia pestis
    Utah
    The Plague....
    6 inch Douche Bag lift...what else do I need?
  11. Aug 10, 2016 at 4:07 PM
    #3691
    tubbsisland
    Cliff
    Arizona
    There are some differences, the big ones being a jump to a 1.25" Uniball and 7/8" Inner heims.
    motoxscott and Glueman[QUOTED] like this.
  12. Aug 10, 2016 at 4:45 PM
    #3692
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Plus the big difference, they aren't Icons :rofl:
    NorthwestCruiser likes this.
  13. Aug 10, 2016 at 4:46 PM
    #3693
    DannyBFresco
    DannyBFresco King Taco
    Danny
    NorCal (Martinez) & LA
    06 Tacoma 4x4 TRD Sport SWB
    Baja Kits +2 LT, Kings, 35" Falken AT3s, SUA
    @LTDSC cough cough hack cough cough
    Bentrodder and LTDSC like this.
  14. Aug 10, 2016 at 4:51 PM
    #3694
    VolcomTacoma
    Jeff
    NorCal
    He's only half Icon now :D
  15. Aug 10, 2016 at 5:17 PM
    #3695
    motoxscott
    motoxscott Well-Known Member Vendor
    Scott
    Socal -> Hurricane, UT
    2017 Tundra - 2008 Tacoma
    How Similar
    - CNC machined
    - Aluminum
    - Uses uniballs
    - Uses heim joints
    - Bolt on uniball caps
    - Fits 05-16 Tacoma's
    How Different
    - Larger & stronger FK uniballs (more expensive)
    - Larger & stronger FK heim joints (more expensive)
    - Completely different geometry
    - Offers a standard and high caster setup using supplied heim spacers that don't affect camber (3-5.5 degrees)
    - Uses higher quality and stronger hardware
    We were the first company to bring billet upper arms to market 10+ years ago. It made sense to bring them back to our product line now since we do a lot of CNC machining in-house.
    When you guys see these things in person you'll be really impressed. We spent a lot of time designing and refining these to get them to this point.
    Icon makes nice parts as well.
    - Scott @ Camburg
    Nickel, LTDSC and Glueman[QUOTED] like this.
  16. Aug 10, 2016 at 7:04 PM
    #3696
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    Rears are fox's. I'm zero icon now :)
    Bentrodder likes this.
  17. Aug 10, 2016 at 7:11 PM
    #3697
    VolcomTacoma
    Jeff
    NorCal
    Oh, well now you're a real boy
    LTDSC[QUOTED] likes this.
  18. Aug 10, 2016 at 7:32 PM
    #3698
    TMFF
    Tim
    Thornton, CO
    01/02 DCLB
    Scott! You need to send me a set to "field test" a set on a 5th gen 4Runner trail. Just to make sure they work with the KDSS.
    FYI my OG 'Burg arms on my 1st gen taco have been flawless, I have only replaced the uniballs once.
    motoxscott[QUOTED] likes this.
  19. Aug 11, 2016 at 6:48 PM
    #3699
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    I have DK, so there's my vote:).
    Reasons I went that way:
    I don't need a second shock
    I do need a limit strap mount.
    I like the stainless steel stop for the steering stop to contact
    I like the uni-ball geometry
    I like the drelin bushings
    Matching DK uppers with heim joints
    Good sale price through a GB.
    Manual man74 and LTDSC like this.
  20. Aug 11, 2016 at 6:51 PM
    #3700
    NorthwestCruiser
    NorthwestCruiser Well-Known Member
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Custom 3 link, 40's etc..
    I wish my TC lowers had a steering stop plate... But other than that I love it
    LTDSC likes this.
