Mid Travel BS 2.0
Discussion in 'Suspension' started by 2ndGenJonny, Jan 12, 2016.
  1. Aug 17, 2016 at 1:48 PM
    #3821
    BigRedToy
    BigRedToy ¯\_(ツ)_/¯
    Colorado
    07 Regular Cab SR5 4x4
    IT does not line up perfect and will require modification.
  2. Aug 17, 2016 at 1:49 PM
    #3822
    sasquatch95
    sasquatch95 Well-Known Member
    Hunter
    nanaimo BC
    07 DCLB sport
    Or $295 for the RCI one
  3. Aug 17, 2016 at 1:49 PM
    #3823
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    I have the technology. I can rebuild it.
  4. Aug 17, 2016 at 2:35 PM
    #3824
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    The only issue I see with this one is that the force of a hit still goes into that paper thin dif cover, instead of the body of the axle housing.
    It's certainly a hell of a lot better than nothing, but I don't think in the same realm as a full dif diaper.
  5. Aug 17, 2016 at 2:49 PM
    #3825
    VolcomTacoma
    Jeff
    NorCal
    I support local fabricators. BAMF is about 5-10 minutes from me lol
  6. Aug 17, 2016 at 3:24 PM
    #3826
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    Before you buy one like that you make some decisions around if you are going to truss your rear axle. All of those bolt on / clamp on diff guards will be useless with a top or back truss...ask me how I know :)
    LTDSC likes this.
  7. Aug 17, 2016 at 4:02 PM
    #3827
    Nimby
    Nimby Well-Known Member
    How do you know :confused:
  8. Aug 17, 2016 at 5:15 PM
    #3828
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    Had one on order when we started building the ass end of my truck, started welding the truss bits on and said ruh roh raggy that ain't gonna fit no more. Luckily it had like a 4-6 week lead time so when I realized it I called them up and they let me cancel the order.
  9. Aug 17, 2016 at 5:23 PM
    #3829
    VolcomTacoma
    Jeff
    NorCal
    Well crapzilla. Might have to cancel mine as well. I've been staring at this Ford 9" in the garage for a while, debating if I wanna run it or not. It's gonna cost me a couple grand to get a diff for it with a locker, and then retrofit all the FJ disc brakes on it and figure out the brake proportioning shit. Ugh.
  10. Aug 17, 2016 at 5:59 PM
    #3830
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    Hey guys, does anyone know who the TW member is that sells good quality wiring w/ a TW discount. I've seen some group buys before etc from him but of course I can't find it now :/
  11. Aug 17, 2016 at 6:00 PM
    #3831
    2ndGenJonny
    2ndGenJonny [OP] Well-Known Member Vendor
    Jon
    Gilbert, AZ
    @HeliMedic ?
  12. Aug 17, 2016 at 6:05 PM
    #3832
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    I thought about him too but it was just me of the stereo guys that offered high end wire by the foot
  13. Aug 18, 2016 at 2:54 PM
    #3833
    Rehak90
    Rehak90 Member
    Kyle
    NE Nevada
    2006 SMS DCSB Tacoma TRD OR 4x4
    Hey guys. I got my front setup in last week without too much trouble and I am putting on the rear today. Does anybody have any experience with the all pro standard springs? I got one of my old leafs out and I just went to install the shackle on the new spring and there is a lot of play between the bushings and the shackle, and from the bolt going through the bushing as well. Is some play normal/expected? I haven't tightened the shackle down yet, not sure if that will help with the first issue.
    Any help is appreciated, the truck is my daily so I'd like to have it off the stands as soon as I can.
  14. Aug 18, 2016 at 3:19 PM
    #3834
    Rehak90
    Rehak90 Member
    Kyle
    NE Nevada
    The play between the bolt and the sleeve doesn't seem to be too far out of the ordinary compared to the stock bushing sleeves. Now I'm just wondering if I should hunt down some washers to kill the play between the spring bushings (too narrow?) and the shackle .
  15. Aug 19, 2016 at 9:41 AM
    #3835
    FPpanchhh
    FPpanchhh Well-Known Member
    Francisco
    Los baños CA
    2005 Tacoma RC
    King coilovers, all pro leafs, bilstein 5160
    I just did the install a few weeks ago.. I had a little bit of play but as soon as I tightened up the bolt it went away.. Haven't had any issues so far
    Rehak90 likes this.
  16. Aug 19, 2016 at 10:42 AM
    #3836
    BenTheMan
    BenTheMan Well-Known Member
    Ben
    Portland
    2012 TRD Sport 4x4 AC
    Truck Nutz
    Got a question for y'all that's been bouncing around in my head for a while. I think I read in this thread somewhere that spring rate will affect lift more than spring length. For example, a 13" 650# spring will give the same lift as a 14" 650# spring. Is this correct?
  17. Aug 19, 2016 at 10:57 AM
    #3837
    FPpanchhh
    Francisco
    Los baños CA
    2005 Tacoma RC
    I'm not to sure about them being the same spring rate and different length.. But a 600# and a 650# of the same length should in theory give you different heights.. Since the 650# is a heavier spring rate it will compress less then the 600# and give you a bit more height
  18. Aug 19, 2016 at 11:20 AM
    #3838
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Spring rate is spring rate. It's a constant and the only thing (paired with preload) in the coilover that determines ride height. If you had one 13" spring and one 14" spring on each side of the truck with the preload collar snugged down to the point where there was no loose play in the coil, and zero preload, they would provide the same amount of lift (assuming 50/50 weight distribution left to right).
  19. Aug 19, 2016 at 11:31 AM
    #3839
    BenTheMan
    Ben
    Portland
    Truck Nutz
    Ok so this leads me to the second part of my question. OME offers the 885 and 887 spring. Both are the same spring rate, but the 887 is 1/2" longer. On the OME thread it is constantly recommended to people to run the 887 to achieve a full 3" lift compared to the 885 which is said to give 2.5". If spring rate determines lift, is there a bunch of mis-information being spread?
  20. Aug 19, 2016 at 11:34 AM
    #3840
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Different beasts. With OME/Bilstein, you have to preload the coils on the shock in order to put the top plate on the coilover assembly. The extended shock top stem is a fixed length. Meaning if you have a 1/2" longer spring, you have to preload the 887 spring 1/2" more than you would the 885. More preload = more lift.
    With coilovers like king, fox, ads, icon, you have a threaded collar on the shock body to allow for different length springs and different amount of preload.
