Mid Travel BS 2.0
Discussion in 'Suspension' started by 2ndGenJonny, Jan 12, 2016.
  1. Aug 19, 2016 at 11:51 AM
    #3841
    BenTheMan
    BenTheMan Well-Known Member
    Ben
    Portland
    2012 TRD Sport 4x4 AC
    Truck Nutz
    Gotcha. That makes sense. Thanks for the info.
  2. Aug 19, 2016 at 12:43 PM
    #3842
    zscott
    zscott Well-Known Member Vendor
    Zach
    Utah
    13 DCSB Off-Road 4x4
    Anyone running a mid travel front with a mild long travel SUA rear? My front setup is performing really well as is, but the rear with the stiff dakar springs can't quite keep up. I about did a shock relocation to get a long shock in there but decided against it because my leafs are the limiting factor in the up travel which is more important to me than the down travel for the type of driving I like to do. SUA seem to be the way to get the results I want in the rear but I have two reservations about it.
    1) My rear end is heavy, am I going to be able to get a spring pack that will support the weight. I know when @sytfu510 went to spring under he had to go on a major diet to get the rear end to level out.
    2) Is the SUA worth it for a daily driver/weekend warrior type truck with only a mid travel front. I am concerned I am just sliding down a slope to the pit of long travel.
    sytfu510 likes this.
  3. Aug 19, 2016 at 12:55 PM
    #3843
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    I used to be MT front with SUA rear.
    My truck has a fat ass too and I'm on LT leaf pack number 3. 3rd time was the charm for me with customizations. Go custom leaf pack or don't bother.
    You will probably graduate to LT front once you realize the rear outdrives the front and it's just so much damn fun.
  4. Aug 19, 2016 at 2:56 PM
    #3844
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    @jberry813 have you started drinking early ? ...'cause you answered those questions with a remarkable lack of verbal abuse, threats, death or internet destruction...frankly I'm a bit dissapointed :cool:
    tacomgee, gray223, Arcticelf and 5 others like this.
  5. Aug 19, 2016 at 3:06 PM
    #3845
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    You spelled "fuck you" wrong.
  6. Aug 19, 2016 at 3:16 PM
    #3846
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    whew...the balance has been restored to the force
  7. Aug 20, 2016 at 7:21 AM
    #3847
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    Any words of wisdom on building a custom leaf pack for fat tacos?
  8. Aug 20, 2016 at 8:16 AM
    #3848
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    Load up your truck as close to what your expo load is going to be, find a truck scale and get a rear axle weight. Call Deaver and give them your rear axle weight and how much lift you have / want to maintain. Wait 6-8 weeks for them to be built.
  9. Aug 20, 2016 at 8:30 AM
    #3849
    Arcticelf
    Gladiator
    That's easy. How did @jberry813 go through three packs to get it right?
  10. Aug 20, 2016 at 8:40 AM
    #3850
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    I'm not sure but my guess would be that he had mid travel first then went LT with an over the counter leaf pack and then dialed it in from there...or maybe when he built his trailer and moved all of that equipment to the trailer he had to readjust from the loss of weight.
    When it comes to leafs look at it this way - they are no different than your front coil springs they are just a flat spring. You dial in the load handling you need = spring rate and then valve your shocks to fine tune performance. A lot of folks don't realize that you can actually tweak your spring rate a bit with a leaf pack simply by playing with your shackle angles too. An incorrect shackle angle can make your leafs much stiffer...or weaker. Google it, you'll find a ton of info but ultimately you want to get the leafs right and be able to run an optimal shackle angle.
  11. Aug 20, 2016 at 8:51 AM
    #3851
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    ...or get a leaf pack designed for your empty weight and just add airbags. Daily driving unloaded on an expo pack isn't exactly fun IMO...that's one of the things that steered me into links...I just could not find a happy medium.
  12. Aug 20, 2016 at 8:52 AM
    #3852
    Arcticelf
    Gladiator
    Thanks. I'm not even sure what questions I need to be asking. Now i have some.
    Off to the rabbit hole of Google.
  13. Aug 20, 2016 at 8:54 AM
    #3853
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    I should clarify too that you can get custom airbags and build custom mounts for them just as if you were fitting custom shocks. You don't just have to stick to the over the counter airbag kits that are meant for picking up a load of mulch on the weekends.
  14. Aug 20, 2016 at 8:55 AM
    #3854
    Arcticelf
    Gladiator
    That's kinda where I am with Dakats now. On the other hand it's great loaded, and the rest of the time; it rides like a truck. So live with it? Much like race truck parts, race truck noises....
  15. Aug 20, 2016 at 8:57 AM
    #3855
    Arcticelf
    Gladiator
    Are air bags ever going to compete with the right springs and shocks to hammer washboards with weight in the truck though?
  16. Aug 20, 2016 at 9:02 AM
    #3856
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    Nope
    Arcticelf[QUOTED] likes this.
  17. Aug 20, 2016 at 9:04 AM
    #3857
    Arcticelf
    Gladiator
    That rules them out then...
  18. Aug 20, 2016 at 11:30 AM
    #3858
    YotaLife
    YotaLife Well-Known Member
    Cory
    Seattle
    11 DCLB Sport
    King 2.5 w 700lb coils, bamf rear mount and sliders, alcan rear springs, 12 inch king smoothies, allpro front bumper, allpro uca, 34x10.50 bfg at ko2, total chaos gussets
    So I'm finishing up my rear today (bamf shock tower, king 2.0 12's, alcan 2+200lbs, and archive shackle flip) and just wondering what do you all use for a shock reservoir mount?
    I see majority seems like zip ties but anybody got anything better?
    Was considering cutting a piece of tube lengthwise and welding it to the frame with some hose clamps to hold the resi.
    2ndGenJonny[OP] likes this.
  19. Aug 20, 2016 at 12:47 PM
    #3859
    stumbles
    stumbles 1 eye
    bryan
    mesa
    2002 White Double Cab
    YotaLife and 2ndGenJonny[OP] like this.
  20. Aug 20, 2016 at 5:46 PM
    #3860
    lockwire24
    lockwire24 Well-Known Member
    Mark
    Vancouver
    2012 MG DBL cab LB TRD sport
    Cobra CB, Firestik II w/ Relentless hood mount, 4x Innovation sliders, Level 8 tracker pro, TRD exhaust, home made grill insert, Leer XR, led bed lights, King shocks, LR uca, Pelfreybuilt front/rear bumpers and skid plates, B.A.M.F. rear shock relocate.
