Mid Travel BS 2.0
Discussion in 'Suspension' started by 2ndGenJonny, Jan 12, 2016.
  1. Sep 22, 2016 at 5:54 PM
    #3981
    Supra4x4
    Supra4x4 IG: hash_brown55
    Andrew
    SoCal
    MGM 2011 DCLB 4X4 Long Travel'd
    Whole lotta stuff
    I agree, that makes sense. However, wouldn't there be a risk (limit straps aside) of the coil coming off-seat at full droop?
  2. Sep 22, 2016 at 6:16 PM
    #3982
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    I....I....ok. I got this. Breath in.
    :gossip: that's what the preload collar is for (the little spinny thingy at the top of the shock body where the body is threaded). Spin that till it snugs to the coil and u have zero preload. Spin more to add additional preload.
    Genuine question: Have you thought this whole long travel thing through?
  3. Sep 22, 2016 at 6:52 PM
    #3983
    Supra4x4
    Andrew
    SoCal
    Whole lotta stuff
    You can do it.:curls:
    Lol, I'm on 5100s atm, not used to having this kind of adjust-ability. I see what you mean, thanks. I'm hoping I won't need to add much preload after, but this is all going to be a learning experience.
  4. Sep 22, 2016 at 7:32 PM
    #3984
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    If you get 16" coils with no front bumper or winch typically there isn't a need for preload. Just snug the "spiny thingy" down tight. ;)
  5. Sep 22, 2016 at 7:47 PM
    #3985
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    I'm about to change mine. They're still tight but are getting really loud even with tri-flo. Been about 1.5 to 2 years.
    taconick89[QUOTED] likes this.
  6. Sep 22, 2016 at 8:16 PM
    #3986
    Supra4x4
    Andrew
    SoCal
    Whole lotta stuff
    I plan on an aluminum pelfreybilt plate with winch, my only concern would be be having to add more preload on top of added weight for the lift I want to achieve; that being round 3". In theory, having longer A-arms will increase lift though too.
  7. Sep 22, 2016 at 8:18 PM
    #3987
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Aaaaand I'm out
  8. Sep 22, 2016 at 8:20 PM
    #3988
    Supra4x4
    Andrew
    SoCal
    Whole lotta stuff
    :wave:
  9. Sep 22, 2016 at 8:27 PM
    #3989
    T4RFTMFW
    T4RFTMFW Well-Known Member
    thebeeler, stroM-, tacomgee and 2 others like this.
  10. Sep 22, 2016 at 8:30 PM
    #3990
    Bentrodder
    Bentrodder PeeRunner Fanboy
    Peter
    Cotati, CA.
    2015 DCLBFTMFW TRD Sport
    Kings and a TW DECAL!!!
    Do you have the top plates? I don't see any in the pics.
  11. Sep 22, 2016 at 10:40 PM
    #3991
    tacomgee
    tacomgee just ain't care....
    Blake
    NorCal - Ukiah
    2009 DCLB SAS in the works
    @Supra4x4 feeling like.....
    jberry813 likes this.
  12. Sep 22, 2016 at 11:09 PM
    #3992
    Boomkanani
    Boomkanani Well-Known Member
    Goldsboro, NC
    2009 TRD OffRoad DCSB - 6 Speed
    Some stuffz
    If you're serious, you have a lot to learn. Nobody was born with suspension knowledge, so no hard feelings. But I would do A LOT more research and think about why you actually want an LT setup before you buy any more parts.
    jberry813 and Mr.PowerTrays like this.
  13. Sep 23, 2016 at 1:27 AM
    #3993
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    LT does not provide any lift, that is entirely dependant on your coilover setup.
    Gramps likes this.
  14. Sep 23, 2016 at 1:48 AM
    #3994
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    2ndGenJonny[OP] likes this.
  15. Sep 23, 2016 at 3:13 AM
    #3995
    Supra4x4
    Andrew
    SoCal
    Whole lotta stuff
    Already read it. And I've googled to find which springs to run with my specific coilovers will little luck, only came here to ask about a spring. Luckily camburg has a nice PDF that they with willingly share, lest my question be posted on TacomaWorld-Oh the horror! :facepalm:
    And for the rest of you, the angle of the upper and lower control arms will place the wheel lower than with stock length upper and lower control arms depending on their angle as set by the coilovers, not too hard to understand, I should have said clearance. I'm a 2wd trying to get the most out of the truck, I got these coilovers for sub-$500 rather than spending 2k on kings or ADS, and Icon is local to me. I've read this thread and some of the LT threads in their entirety. If my questions and curiosity bother your conscience all that much, I'll be on my way.
    Bu-bye. I'll post here when the IFS is done.
  16. Sep 23, 2016 at 5:18 AM
    #3996
    Gramps
    Gramps
    07 TRD DC 4x4
    Don't run away. I am recent to this thread too and still endure some shit beatings because of questions I ask or comments I make. :)
    But in all seriousness a couple of things, a comment mentioned earlier about the top plates. Do you have them to go on the ICON'S? If not you will need to source them before you can install those. Now if you are planning on a plate bumper and winch and want to keep the preload down you need to run a 700lb coil. From what I have seen on TW those running a 700lb 16" coil from KING typically have to set in about a 1/2" to 3/4" of preload (threads exposed) to maintain about a 3" lift. That amount of preload does not affect the ride. I am running a 14" 700lb Eibach spring on my ICON'S and run about 1.25" preload for 3"s. The ride is fine for me. But it's ICON. It rides differently then others.
    LT or stock length your lift is entirely controlled by the coilover or body lift. In theory yes you could get over 3"s of lift with LT but your preload would be so much that the ride would suffer.
  17. Sep 23, 2016 at 8:26 AM
    #3997
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Just be careful where you get your info from - not sure where you read that LCA's provide lift.
  18. Sep 23, 2016 at 8:30 AM
    #3998
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Your "theory" of adding lift just by having longer A arms would be true only if you assumed you had the same upper and lower coilover mounting points, and still using the same coilover as stock length arms. Neither of those are true. With LT arms, the lower coilover mount is pushed out farther towards the spindle and you have a completely different coilover. Ride height is based off the spring rate/preload combination and the weight of your truck.
  19. Sep 23, 2016 at 8:33 AM
    #3999
    2ndGenJonny
    2ndGenJonny [OP] Well-Known Member Vendor
    Jon
    Gilbert, AZ
  20. Sep 23, 2016 at 8:40 AM
    #4000
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    Gramps, the spring rate equation changes with a long travel set up because the leverage ratio changes ( decreases ) A 700lb spring would be really stiff with with LT.
    Gramps[QUOTED] and jberry813 like this.
