Mid Travel BS 2.0
Discussion in 'Suspension' started by 2ndGenJonny, Jan 12, 2016.
  1. Oct 15, 2016 at 12:09 PM
    #4061
    Mr.PowerTrays
    Mr.PowerTrays Well-Known Member Vendor
    Maverick
    Colorado
    2011 dcsb trd or
    does any one have any info on the total chaos heim joint uppers? how many turns equal how many degrees kind of thing?
  2. Oct 16, 2016 at 6:41 AM
    #4062
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    I believe 1/4 inch of threads = .5°
    I have dirt king hiem arms but it should be the same
    Mr.PowerTrays[QUOTED] likes this.
  3. Oct 16, 2016 at 11:12 AM
    #4063
    Mr.PowerTrays
    Maverick
    Colorado
    2011 dcsb trd or
    ok so i think what your saying is if only the rear side is moved out 1/4 inch, then it equates to .5° caster.. (i understand this will affect camber as well and that ill have to get an alignment before i see any real benefits) im just trying to push the wheel forward to alleviate the rubbing..
    EDIT also my lowers are not hard mounted
  4. Oct 16, 2016 at 11:32 AM
    #4064
    Goobersbro
    Goobersbro Well-Known Member
    Jon
    North of Sacramento
    2015 dcsb o.r
    Locker anytime mod Pelfrey armor Warn recovery
    Been doing a ton of research for my 15' dcsb suspension set up and I think I have settled on King 2.5s up front with light racing upper control arms.
    In the rear a 3" Dakar leaf pack with fox 12" 2.0s relocated with shackle flip and xj shackles. Limit straps and extended brake lines to accommodate.
    My question is how can I do this and achieve a semi level vehicle? Should I plan on removing the 3rd leaf in the Dakar pack to lower the rear a little to accommodate the lift that will be gained from the shackle flip? In doing so will I lose travel by removing a leaf?
    I want to run 285s and primary use for the truck is crawling. In a few years I'm going to sas the front but I need a set up to get me by for now.
  5. Oct 16, 2016 at 12:40 PM
    #4065
    SconnieHailer
    Marc
    No. When adjusting the hiems if you screw them in or out 1/4 of an inch it will change camber by .5°. each truck will be different.
  6. Oct 16, 2016 at 1:45 PM
    #4066
    2ndGenJonny
    2ndGenJonny [OP] Well-Known Member Vendor
    Jon
    Gilbert, AZ
    If you really intend on doing a solid axle conversion up front then why not do something inexpensive for now (or nothing at all) and save some cash. You're going to need it.
    Also, read this. Very informative post regarding flipping the shackles and leaf packs.
    https://www.tacomaworld.com/threads...012-dcsb-antibrix.455075/page-5#post-13411036
  7. Oct 16, 2016 at 2:34 PM
    #4067
    Goobersbro
    Jon
    North of Sacramento
    2015 dcsb o.r
    I don't want to sas the truck until it's paid off and I have another 4 years left. That will give me time to acquire parts to do it right but in the mean time I still want a capable rig for moderate trail abuse.
    Dalandser likes this.
  8. Oct 16, 2016 at 5:16 PM
    #4068
    snowboard704
    snowboard704 Well-Known Member
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    No I just used the little metal universal resi mounts and welded them to the sheet metal right behind where the resi is pictured. It's strong enough and was going to add a support rod from the frame to the backside of the sheet metal but don't think there is a need after having no issues
    Silver02Taco likes this.
  9. Oct 16, 2016 at 5:31 PM
    #4069
    snowboard704
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    Where were yours mounted before?
    I checked the mounting location without the coil in when I cycled the front at full turn/bump to assure to rubbing.
    I had to relocate/remove the windshield wiper fluid container
  10. Oct 16, 2016 at 5:56 PM
    #4070
    snowboard704
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    Pic didn’t show for some reason?
    Theres some great write ups on the relocation as well.. mines completely removed for now but may make my own make my own container for the fluid out of pvc piping like others have done
  11. Oct 16, 2016 at 7:17 PM
    #4071
    snowboard704
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    Yea that was my preferred setup but my wheels/tires weren't having it.... threw them up an out of the way, plus the resi is still visible for that mall crawler effect:rofl::thumbsup:
  12. Oct 18, 2016 at 9:03 AM
    #4072
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    You can remove leaves from the Dakar pack for lower ride height, and lower weight capacity.
    I'm not sure about negative arch issues though, but that won't be affected by home many leaves you take out.
    Quick math: Dakar is +3 to 5 inches of lift, shackle flip is another 3"? You can probably wring 3" out of the front, leaving you 3" or so bed high, with 300# in the bed. Of you pull a leaf from the dakars that's probably an inch or two less.
  13. Oct 18, 2016 at 9:22 AM
    #4073
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    I don't think the Dakar's are going to give you 5 inches of lift.... Not after they settle. But idk.
  14. Oct 18, 2016 at 11:40 AM
    #4074
    Goobersbro
    Jon
    North of Sacramento
    2015 dcsb o.r
    Dakar should net me 2" if I remove the 3rd leaf and the shackle flip is 3/4", slightly longer shackles will give me an additional 1/2"-1" so in theory I should be at
    3 and a 1/4 to 3.5 in the rear? This is all just based off of searching threads
    Kings will net me around 3-3.5 up front
  15. Oct 18, 2016 at 11:51 AM
    #4075
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Longer shackles will only give you lift if you have a shackle flip kit
  16. Oct 18, 2016 at 11:56 AM
    #4076
    Goobersbro
    Jon
    North of Sacramento
    2015 dcsb o.r
    Right which I'll have and for every 1" gain in length in shackle over stock you gain 1/2" of lift correct?
    Least that was the rule of thumb on my jeep
  17. Oct 18, 2016 at 12:32 PM
    #4077
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    It depends on your shackle angle, the 50% ratio is based on a 45 degree shackle angle.
    Might also loose some lift the the pack itself due to the additional preload on the springs.
  18. Oct 18, 2016 at 6:46 PM
    #4078
    Goobersbro
    Jon
    North of Sacramento
    2015 dcsb o.r
    Gotcha good to know I guess I'll just have to play with it and see where it ends up then. Anyone know what brake line length With Will 24" be long enough
  19. Oct 18, 2016 at 6:47 PM
    #4079
    cmack
    cmack Well-Known Member
    18 Burrito
  20. Oct 19, 2016 at 12:33 PM
    #4080
    Arcticelf
    Gladiator
    That's worst case, with no load on the back of the truck. Mine (well used) are over 4" of lift with the bed empty.
