Mid Travel BS 2.0
Discussion in 'Suspension' started by 2ndGenJonny, Jan 12, 2016.
  1. Dec 5, 2016 at 6:24 PM
    #4321
    snowboard704
    snowboard704 Well-Known Member
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    How much of a difference is it going to make if I fill the rear smoothbody shocks with nitrogen at ride height as opposed to fully extended?
  2. Dec 5, 2016 at 9:59 PM
    #4322
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    a ton...as soon as the shock extends past that point your going to have an air gap in there and it will cause the oil to foam up ( IE: get carbonated looking ) which you can't fix without taking the shock apart to dump the oil and replace it.
  3. Dec 6, 2016 at 6:24 AM
    #4323
    snowboard704
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    Well looks like I'm going to have to replace the oil in both shocks now :bananadead::frusty:
    Mr.PowerTrays likes this.
  4. Dec 6, 2016 at 6:44 AM
    #4324
    Rattletrap66
    Rattletrap66 (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
    stumbles and Acerwin like this.
  5. Dec 6, 2016 at 6:57 AM
    #4325
    snowboard704
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    In theory though wouldn't the nitrogen just decrease a small amount in pressure once the shock is extended fully if filled at ride height?
  6. Dec 6, 2016 at 7:08 AM
    #4326
    TACOVRD
    TACOVRD I Identify As A Prius
    TW Addict
    AZ/WA
    2019 T4R ORP - Formerly 2013 DCSB OR Spruce Mica
    Workin' on it....
  7. Dec 7, 2016 at 10:34 AM
    #4327
    heffer
    heffer Well-Known Member
    Jeff
    Los Angeles
    '15 Magnetic Grey 4X4 TRD Off Road
    Icon Extended Travel, SPC control Arms, OME Dakars, B110's
    Finally got my suspension all put together. Was trying to go for a budget kind of build and ended up with
    Icon Extended travel ($600)
    LR UCA's ($125)
    24" extended brake lines ($60)
    Bilstein b110 ($190)
    Deaver u402 ($250 plus re-arching $150)
    I like to think I did a good job. But does this all put me in the mid-travel club now? Lol.
    Hoping to get the BAMF shock relocate by next summer. I want to get more armor first.
    Also, with a full tank of gas, my rear driver side sits about an inch lower than the passenger side. Should I switch the leaves around or does it not matter? I know the driver side is heavier but I didn't think it would make an inch of difference.
    Spent a lot of time lurking on this thread. Thanks for all the help/advice
  8. Dec 7, 2016 at 10:37 AM
    #4328
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    Skip the BAMF shock relocate and go with a better shock mount where you can fit 14" shocks
    https://www.tacomaworld.com/threads/a-different-approach-to-rear-shock-relocation.461500/
    heffer[QUOTED] and DannyBFresco like this.
  9. Dec 7, 2016 at 10:37 AM
    #4329
    DannyBFresco
    DannyBFresco King Taco
    Danny
    NorCal (Martinez) & LA
    06 Tacoma 4x4 TRD Sport SWB
    Baja Kits +2 LT, Kings, 35" Falken AT3s, SUA
    Rattletrap66[QUOTED] likes this.
  10. Dec 7, 2016 at 10:41 AM
    #4330
    heffer
    Jeff
    Los Angeles
  11. Dec 8, 2016 at 12:00 AM
    #4331
    Boomkanani
    Boomkanani Well-Known Member
    Goldsboro, NC
    2009 TRD OffRoad DCSB - 6 Speed
    Some stuffz
  12. Dec 8, 2016 at 6:37 AM
    #4332
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    The clearance is the same as the BAMF kit, you'll need 3.5 Backspacing or more for your wheels
  13. Dec 8, 2016 at 6:58 AM
    #4333
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    @Rattletrap66 Without cluttering up your other thread, Curious if you noticed any flex on those towers at all? I couldn't see well if the back part of the tower overlaps on to the top of the frame like the BAMF towers do or not. I'm sure they're fine for low speed stuff, but wonder what kind of flex you'd see for anything high speed or hard hits.
    Rattletrap66 likes this.
  14. Dec 8, 2016 at 7:10 AM
    #4334
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    Those shock towers don't overlap on top of the frame unless you add bracing yourself
  15. Dec 8, 2016 at 7:12 AM
    #4335
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    I didn't notice any flex but then again I am not doing any high speed stuff. The mounts don't wrap around the top of the frame but there is more surface area along the side of the frame than the BAMF towers. Maybe I'll mount a go pro under there and see if I can get some shots of it cycling
    TheNatural likes this.
  16. Dec 8, 2016 at 7:21 AM
    #4336
    VolcomTacoma
    Jeff
    NorCal
    Please! Like I said, I'm sure they're great for everyday use, just personal curiosity if it's a viable source for someone wanting to go spring under or something and keep the shocks out of the bed, as opposed to a shock hoop or something
  17. Dec 8, 2016 at 7:26 AM
    #4337
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    Definitely gotcha there! I'll be heading to the off road park this weekend so can definitely do it there
    VolcomTacoma[QUOTED] likes this.
  18. Dec 8, 2016 at 8:58 AM
    #4338
    DannyBFresco
    Danny
    Also interested :spy:
  19. Dec 8, 2016 at 9:05 AM
    #4339
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    LSK LT in Progress, custom bed cage, DMZ SUA kit with 2.5 kings triple bypass, kings bump stops, baja bumper, rear custom tube bumper, glass all around, Weather Tech Liners, wet okole seat covers, Cluster LED Swap, HU LED Swap, hood LEDs, bed LEDs, etc etc etc
    Beautiful
  20. Dec 8, 2016 at 10:44 AM
    #4340
    fishfinder
    fishfinder Whoever dies with the most toys wins
    Mikey
    Santa Barbara
    2015 MT DCLB
    CBI armor, Kings, 35s, Lockers
    Hey guys, I'm thinking about upgrading my LCAs, and would love to hear some differing opinions from other MT and even LT guys. Weighed my truck a couple months while on a trip in Oregon, and she came out to about 6,400 lbs loaded up. With all the extra weight, the main weak point up front seems to be the LCA ball joints. I've been researching the different LCAs available, and would love to hear from anyone who has stock-length aftermarket LCAs, and their experience with them. Slightly better articulation, ground clearance, uniball vs stock ball joints? Any info is helpful. Thanks guys!
