Mid Travel BS 2.0
Discussion in 'Suspension' started by 2ndGenJonny, Jan 12, 2016.
  1. Jan 14, 2016 at 7:06 PM
    #421
    Acerwin
    Acerwin The unNORM NORM
    Andrew
    South Carolina
    Toyota Tundra
  2. Jan 14, 2016 at 7:14 PM
    #422
    2ndGenJonny
    2ndGenJonny [OP] Well-Known Member Vendor
    Jon
    Gilbert, AZ
    Not a bad setup for someone looking to upgrade. Maybe work out a package deal.
  3. Jan 14, 2016 at 7:28 PM
    #423
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
  4. Jan 14, 2016 at 7:31 PM
    #424
    TacoSTIG
    TacoSTIG Untamed Member
    Jeremy
    WA, Issaquah
    2005 AC, TRD OR
    Great thread so far, in just 22 pages I've been refreshed on more concise info than I was able to gather in 300+ pages of other threads.
    :cheers:
    Stryker420, LTDSC and Acerwin like this.
  5. Jan 14, 2016 at 7:33 PM
    #425
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Give us a couple days and I'm sure we can fuck it up
  6. Jan 14, 2016 at 7:35 PM
    #426
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    A couple days...? Sir you underestimate the power of TW
    Stryker420 likes this.
  7. Jan 14, 2016 at 8:15 PM
    #427
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
  8. Jan 14, 2016 at 9:18 PM
    #428
    Mitch
    Mitch Somebody call for a Wambulance?
    Mitch
    Spokane, WA
    2007 Access Cab SR5 4x4
    Lights, Siren, Drugs, Needles, Electricity
    22 pages is a lot easier to read through then the 300+ old thread
  9. Jan 14, 2016 at 9:55 PM
    #429
    Kerleyfries
    Kerleyfries Idk what the hell I'm doing
    Zack
    Lebanon
    ‘17 F150 and SAS ‘98 4runner
    Did someone mention fucking stuff up? I love doing that.
    Bentrodder likes this.
  10. Jan 15, 2016 at 11:19 AM
    #430
    Mcdees84
    Mcdees84 Well-Known Member
    Tallahassee, FL
    2014 MGM DCSB-TRD O/R
    Thanks. I meant more so as another bit of information to add to the first page. I went with LR UCAs, so I personally don't know the maintenance required for the uniballs. I went ahead and googled and found out for myself, but though others may have that same question. Since there is a lot of hands-on experience in here, I thought maybe it would be worth adding up front. But maybe not. Like I said earlier, I'm just here for more hang gliding lessons;)
  11. Jan 15, 2016 at 11:24 AM
    #431
    2ndGenJonny
    Jon
    Gilbert, AZ
    I'm going to try to spend some time on Sunday getting more links up if my lady is done with her homework and the laptop. I will need to get my frame plating project posted on my page also.
    The MT lift is based on the uniball uppers and the EXT Travel COs. The BJ ones don't add that extra inch o droop.
    I will have to add ball maintenance to this I guess but it seems to be a personal preference topic. Not all lube the UBs, they keep them dry. Out here in AZ, that shit won't fly. They scream after a few months with no lube.
  12. Jan 15, 2016 at 11:36 AM
    #432
    zscott
    zscott Well-Known Member Vendor
    Zach
    Utah
    13 DCSB Off-Road 4x4
    LR UCAs supposedly allow for extra droop and can be used with extended travel coilovers. Not sure how long they will last. @SMKYTXN had them with his kings and no issues.
  13. Jan 15, 2016 at 11:37 AM
    #433
    2ndGenJonny
    Jon
    Gilbert, AZ
    @Moose1988
    How did the LRs work with your ext travel Kings? I know you have Camburg now.
  14. Jan 15, 2016 at 11:49 AM
    #434
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    i know since the BJ mounts below the arm it allows more "height" to be cranked out of it. I had to lower my coilovers when i swapped from LR to TC.
  15. Jan 15, 2016 at 12:38 PM
    #435
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    LR UCAs work just fine with extended travel Icons. they actually have a good bit more travel than the shocks will allow. had them paired with icons for 6 years now. replaced the bushings and balljoints a few years ago when they redesigned both. other than that, I haven't had to worry about them.
    Rattletrap66 likes this.
  16. Jan 15, 2016 at 1:26 PM
    #436
    AZ2013
    AZ2013 Well-Known Member
    Blake
    2014 Spruce Mica DCSB
    Did you have to run bumps or limit straps with that set up?
  17. Jan 15, 2016 at 2:20 PM
    #437
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    not a single issue, and had my Kings cranked to at least 3" up front. Mine were the older style so when they came off, they were in need for bushing upgrade, but thats it. The BJ was still fine. As @LTDSC mentioned.. My UCA angle now with the Burg arms seems to be more extreme compared to the LR's angle. no issues still though.
  18. Jan 15, 2016 at 2:27 PM
    #438
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    No, though neither are a bad idea. stock bump limits compression, and the shock limits extension.
  19. Jan 15, 2016 at 2:32 PM
    #439
    AZ2013
    Blake
    Thanks. I'm putting the exact same set up on my truck whenever the shocks finally get here. I planned on getting everything installed and then testing them to see if I'll really need them. Figured I'd ask too.
  20. Jan 15, 2016 at 4:53 PM
    #440
    Rattletrap66
    Rattletrap66 (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
    No, you just don't have da droop to need extended
    2ndGenJonny[OP] likes this.
