Mid Travel BS 2.0
Discussion in 'Suspension' started by 2ndGenJonny, Jan 12, 2016.
  1. Apr 10, 2017 at 8:19 PM
    #4561
    FPpanchhh
    FPpanchhh Well-Known Member
    Francisco
    Los baños CA
    2005 Tacoma RC
    King coilovers, all pro leafs, bilstein 5160
    As of right now I have an all pro standard leaf pack with 5160s out back
  2. Apr 10, 2017 at 10:58 PM
    #4562
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    I disagree with this. Even a +2 kit with dual shocks is way beyond a MT rear in terms of keeping up. I would go rear LT with MT front any day over the reverse.
    jeff b likes this.
  3. Apr 11, 2017 at 6:05 AM
    #4563
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    I was more recommending that because if he is on the fence for it, he might not want to go through the bed and have a rear cage, and this would be a decent compromise. Plus if his front end needs replacing anyways, at least give it a little upgrade with the potential to add the secondary down the road.
  4. Apr 11, 2017 at 6:08 AM
    #4564
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    Does anyone make a SUA leaf pack similar to the Dakar pack in terms of weight carrying capability? I'm not ready to go for a full on custom leaf pack yet.
  5. Apr 11, 2017 at 9:36 AM
    #4565
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    I am not sure about way beyond, but technically you should have your rear built way beyond the front so this is still solid advice. The rear end should easily absorb anything that is a nasty hit on the front, if you hit something and its bone jarring on the front and rear its not going to be a fun ride. If the front absorbs better and the rear takes the hit even worse then I hope you have a roll cage
  6. Apr 11, 2017 at 9:46 AM
    #4566
    glorifiedwelder
    glorifiedwelder IG= @Liquid_Torch
    jason
    Santa Clarita, ca
    double cab trd sport
    The rear should be built, but if your gonna be buying stock length lowers you might as well upgrade to the +2 kit. Only really difference in price is the cost of axles, but for another few hundred bucks you pick up a couple extra inches of travel which is well worth the money, even if you have to wait till you do the rear to be able to take full advantage of the front suspension.
    tetten likes this.
  7. Apr 11, 2017 at 9:50 AM
    #4567
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    thats what i have as well, just the Race arms for lowers. I thought i did pretty good with Jeff this weekend, definitely not in the LT realm but for what i do and what i did i was very happy with it. 60MPH was my top speed this weekend in Pismo and to me thats fast enough or even too fast without caging and whatnot.
  8. Apr 11, 2017 at 9:51 AM
    #4568
    tyfoon11
    tyfoon11 Raguel
    J
    Where bald eagles roam, Ca
    garden shed
    You should just give me your lowers and go LT
    Silver02Taco, tacomgee and LTDSC like this.
  9. Apr 11, 2017 at 9:52 AM
    #4569
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    It's actually only an extra inch of travel w/ a +2 kit if you're 4wd because the CV's bind looooong before the CO's or uniballs run out of travel...but that being said the extra width is nice and if you did the same mod that Dirt King offers to the CV's you could turn it into 2 extra inches of travel...I think.
  10. Apr 11, 2017 at 9:52 AM
    #4570
    tetten
    tetten Cynical Twat Waffle
    Andy
    Socal
    Very much this, unless you can get the LCA used for an awesome price don't bother, a lot of people on here made the mistake of getting lowers and then realizing they they just should have got a +2 kit and been done with it. If you go with TC their plus 2 kit and 3.5 kit use the same shock, so you could keep the shock and change out the LCA,UCA, CVs if you decide later that you want more travel
  11. Apr 11, 2017 at 9:59 AM
    #4571
    tetten
    Andy
    Socal
    Dirt king CV mod?
  12. Apr 11, 2017 at 10:03 AM
    #4572
    glorifiedwelder
    jason
    Santa Clarita, ca
    Dirt king machines out part of the inner cv to allow for more articulation
  13. Apr 11, 2017 at 10:04 AM
    #4573
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    They offer an upgrade with their 3.5 kit which is a modified inner ( IE: clearanced ) much like what 1st gen guys do with Tundra inners I think.
    Here is a copy from DK's website :
    Additional 4WD info: To achieve the maximum amount of travel on 4WD models we offer 1” diff drop spacers and the inner CV’s must be internally machined for clearance at full droop. Dirt King offers pre-machined inner CV cores that can be swapped for an additional $120. You have the option to buy just the extend chromoly axle shafts for $649 or a complete long travel axle assembly with machined inner CV’s, new boots, new seals, and packed with Lucas Oil heavy duty grease for $1085. The cost will drop to $975 if you send in your undamaged OEM axles as a core. We provide these options to make the axle installation painless and no special tooling needed.
  14. Apr 11, 2017 at 10:10 AM
    #4574
    tetten
    Andy
    Socal
    Neat, sounds like they just bevel the inside of the tripod cup. too bad it wouldnt help a TC +2 kit.
  15. Apr 11, 2017 at 10:11 AM
    #4575
    Arcticelf
    Gladiator
    Don't forget new front fenders to clear your 4" to 7" wider truck...
    LTDSC likes this.
  16. Apr 11, 2017 at 10:23 AM
    #4576
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    Actually I believe it would technically help any kit as long as your CO and uniballs have the travel available too.
    Arcticelf and 4Running Daily like this.
  17. Apr 11, 2017 at 10:25 AM
    #4577
    4Running Daily
    4Running Daily Long Live ZS
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    That's exactly what they do
    LTDSC likes this.
  18. Apr 11, 2017 at 10:25 AM
    #4578
    tetten
    Andy
    Socal
    Uniballs are the problem, misalignment spacer is set at TCs recommended spec and CV still spins fine
  19. Apr 11, 2017 at 10:28 AM
    #4579
    glorifiedwelder
    jason
    Santa Clarita, ca
    Glass isn't any more necessary with a plus 2 kit than with a well sorted out mid travel setup. The only glass I'd consider with a plus 2 kit is the McNeil plus 2 glass but that works well with a mid travel setup as well
  20. Apr 11, 2017 at 10:31 AM
    #4580
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    meh...they sell spare misalignment spacers and it looks cool when you scar em' up good JK ... it sucks when you bend the through bolt and can't get that bitch out...and that kids is the story of why you should always run straps.
    jubei and LTDSC like this.
