Mid Travel BS 2.0
Discussion in 'Suspension' started by 2ndGenJonny, Jan 12, 2016.
  1. Jul 19, 2017 at 6:00 AM
    #4981
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    I know Delrim is harder than poly, but thought they were noisier?
  2. Jul 19, 2017 at 7:12 AM
    #4982
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    It's self lubricating, mine LCA bushings are Delrin, no noises so far. But I also have grease on everything.
  3. Jul 19, 2017 at 7:32 AM
    #4983
    Boomkanani
    Boomkanani Well-Known Member
    Goldsboro, NC
    2009 TRD OffRoad DCSB - 6 Speed
    Some stuffz
    I've never had a squeak from the poly bushings in my UCAs/LCAs. The uniballs on the other hand...:lalala:
    Arcticelf likes this.
  4. Jul 19, 2017 at 9:13 AM
    #4984
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    Uni's and heims for me
  5. Jul 19, 2017 at 11:07 AM
    #4985
    Arcticelf
    Gladiator
    It's only the lower uni-balls that make noise on mine, I think the brake dust eats them alive, and the uppers are clear.of that.
  6. Jul 19, 2017 at 12:14 PM
    #4986
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    Already had to replace a uni on UCA...grrr
  7. Jul 19, 2017 at 12:18 PM
    #4987
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    How many miles did you get out of it? Seems like I got a ton of miles from my old uca's before needing to replace them. I can't imagine what's gonna make noise first on the LT kit with heimed uppers and uniballs on uca's and lca's
  8. Jul 19, 2017 at 6:25 PM
    #4988
    Arcticelf
    Gladiator
    What did you do to it?
  9. Jul 19, 2017 at 6:32 PM
    #4989
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    About 20k miles on them at the time of Uniball failure. During routine maintenance/cleaning I noticed the movement in the Uniball. Apparently the PTFE liner decided to change zip codes. No squeaking from it prior to failure. Never used any lube on them. Just water to keep them clean.
  10. Jul 19, 2017 at 9:21 PM
    #4990
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    Not supposed to lube delrin
    G.T. likes this.
  11. Jul 19, 2017 at 9:30 PM
    #4991
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    Zero noise in my experience, yes harder and will transfer a few more road vibes but nearly bomb proof vs poly
    Arcticelf and stairgod[QUOTED] like this.
  12. Jul 19, 2017 at 9:56 PM
    #4992
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    I need to upgrade all my shiz to delrin
    Bentrodder likes this.
  13. Jul 20, 2017 at 3:34 AM
    #4993
    Arcticelf
    Gladiator
    Boomkanani likes this.
  14. Jul 20, 2017 at 5:53 AM
    #4994
    Boomkanani
    Goldsboro, NC
    Some stuffz
  15. Jul 20, 2017 at 6:04 AM
    #4995
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
  16. Jul 20, 2017 at 6:07 AM
    #4996
    Arcticelf
    Gladiator
    Yup, right in the middle of the alignment cam bolt bushing.
  17. Jul 20, 2017 at 6:08 AM
    #4997
    Arcticelf
    Gladiator
    True. I haven't had any issues with the royal purple synthetic, but it could be softening up the Delrin, and I probably wouldn't notice
  18. Jul 20, 2017 at 6:10 AM
    #4998
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    hmm weird because the cam bolt sleeve is solid so no grease would get in to that and delrin does not use grease ? I wonder if they out the zirks in for people that swap to poly bushings maybe ?
  19. Jul 20, 2017 at 6:31 AM
    #4999
    Arcticelf
    Gladiator
    That grease goes between the Delrin and the bolt sleeve, and between the Delrin and the LCA (based on where it squirts out).
    I also have a grease fitting on my cam bolt, so I get grease between the bolt and sleeve, which is where the articulation happens.
  20. Aug 1, 2017 at 2:53 PM
    #5000
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    And sticking mt in the rear was short lived. Ordered up rear LT today. So anyone interested in any of my rear mt setup pm me.
    BAMF relocation
    12" 2.0 remote resi kings
    Sos concepts shackle flip with adjustable/ longer shackles
    Extended brake lines
    Ubolt flip kit
    Allpro standard leaf springs
    jc11taco89 and LTDSC like this.
